Old 03-30-2003, 10:11 PM   #3046
Jimmy Fukuyama's Avatar
Originally posted by RCInfinity
No hostility here, just curious.
That's cool! my bad.. Cheers.... You have my respect.
Jimmy
Jimmy Fukuyama is offline   Reply With Quote
Old 03-31-2003, 02:30 AM   #3047
safaridog's Avatar
I know some of you xray drivers run 1/12th as well. So here's the question. What are your lap times compared to your touring times? I ran .4 to .6 sec slower in 1/12th(4 cell mod) than mod touring at the last race.
I'm a bit curious on how other people do.
safaridog is offline   Reply With Quote
Old 03-31-2003, 06:58 AM   #3048
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
Hi Jimmy, Sent you an email regarding my address. Sorry there was confusion. Hopefully we can have it cleared up.
John F.
John Fontaine is offline   Reply With Quote
Old 03-31-2003, 07:52 AM   #3049
RandyB's Avatar
thats funny jimmy I just placed an order with Ralph for our hobby shop I have two T1 R 's on back order and your pricing is incorrect. Burch told me selling price is 225.00 check your numbers.
RandyB is offline   Reply With Quote
Old 03-31-2003, 09:24 AM   #3050
I'll check on that. Thanks for for the info.
Jimmy
Old 03-31-2003, 09:59 AM   #3051
Elk666's Avatar
Hi guys, can someone tell me how loose the front belt should be? right now i have about 3/4" of travel up and down, is this ok or should i reduce it?
thanks
Elk666 is offline   Reply With Quote
Old 03-31-2003, 10:19 AM   #3052
thanks
Your front belt should fine if it doesn't flip around on its own. Running the belt a little on the loose side is better anyway. If it gets excessively loose, then you might want to tighten up the Bulkhead Adjustment nut. I run mines really loose too.
Jimmy
Old 03-31-2003, 10:34 AM   #3053
rayhuang's Avatar
Jimmy and the boys,
One question and this sounds really Newbie-but I have had the button head screw come loose on my front wheels twice now.Its embarrasing!!!! I am running the stock wheels with the belleville washer on the correct way!!!
Do I need to use Blue Loctite one time??
Thanks,
Ray
Old 03-31-2003, 10:36 AM   #3054
rc-zombies's Avatar
Ray..
Haven't lost a wheel yet...but the blue locktite would not hurt. just don't use the red stuff..you'll never get it off.
Old 03-31-2003, 10:36 AM   #3055
RC Nitro's Avatar
I do, never had a problem since. Had the wheel come off like you did. They got me too!! LOL
RC Nitro is offline   Reply With Quote
Old 03-31-2003, 10:45 AM   #3056
I have had them come off once in the alum hubs but never once in the spring steel ones. I used locktite on the alum. Knock on wood, i'll probably have one slip on the spring steel
Old 03-31-2003, 10:46 AM   #3057
Originally posted by rayhuang
Jimmy and the boys,
Thanks,
Ray
Hi Ray,
I've had only one occasion running the CS27 which the washers won't fit. So what I did was exactly what you had in mind. I applied only a very small drop of loctite on the end of the wheel screw and once it's dry, it'll tighten up really good. Best if you run the Spring Steel Hex hubs because on the stock ALU, its a little harder to unscrew.
Another way of doing this is go to a hardware store and buy some smaller washers. Another suggestion is apply the wheel screw onto the wheel, then slide an o-ring on the other end of the screw before putting the wheel on, then tighten it a bit harder. The O-ring should help hold the screws tight against the hub. This is one of the gripes with the XRAY. Hope it helps and I'll experiment with it a little more today and see if there's a better solution. Happy Racing.
Jimmy
Old 03-31-2003, 10:50 AM   #3058
You're right on that Devin, The Spring Steel seemed to have a better thread and tightens down further then the ALU so it actually slightly squeezes the wheel against the hub. Although a drop of the blue loctite won't hurt. LOL
Jimmy
Old 03-31-2003, 11:09 AM   #3059
Jimmy
I'm glad I finally found someone who agreed with that theory...it's been a hard search. Thanks. I got your email and sent you back one.
Old 03-31-2003, 06:17 PM   #3060
Neil Rabara's Avatar
Originally posted by RCCadet
$220 was the street price I was qouted also. Ralph said $225.
RCC, I gave a hello to Tony Phalen for you mentioning what you told me before. He says hello also.
Neil Rabara is offline   Reply With Quote
