Old 03-28-2003, 09:48 AM   #3016
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
That does seem a bit high...I thought it would come in around 220ish.. What do I know...it was just a guess of mine. People that drove it say they love it....what a great way to get an xray for cheaper than a Evo II kit.
John Fontaine is offline   Reply With Quote
Old 03-28-2003, 09:52 AM   #3017
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
$220 was the street price I was qouted also. Ralph said $225.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 03-28-2003, 11:39 AM   #3018
Neil Rabara's Avatar
That is very affordable for those who can't pay for an Evo2.
Neil Rabara is offline   Reply With Quote
Old 03-28-2003, 10:45 PM   #3019
Hey guys,
I am very interested in the new T1R. Do any of you know if Associated TC3 springs will fit this car?
Thanks in advance,
Jeff
TKG 27 is offline   Reply With Quote
Old 03-28-2003, 10:55 PM   #3020
theisgroup's Avatar
AE springs fit the evo2, but a little bit shorter then xray springs. will just need a little more preload
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 03-29-2003, 12:05 AM   #3021
Jimmy Fukuyama's Avatar
Talking Hello Everybody?
I guess some of you might know me as the guy behind Team Fuku. I just wanted to show my appearance and say "HI" to ya'll.
Jimmy
Jimmy Fukuyama is offline   Reply With Quote
Old 03-29-2003, 12:21 AM   #3022
Originally posted by rayhuang
Guys,
Are the arms used in the #30 0900 composite C-hub suspension kit the exact same arms as in the older Aluminum C-hub kit? Are they the same material or are they softer plastic?
I was going to order it as my "spares" for the suspension system. I hate to use Serpent and Cheap in the same sentence-but its "cheap" to buy!!!!
Thanks,
Ray [/B]
Hi Ray,
The Lower Arms for that comes with the 300900 are the same as the Alu C-hub ones. The part # is 302150. They're of "Soft" composites. Works really well for all types of tracks. Hope this helps.
Jimmy
Old 03-29-2003, 12:24 AM   #3023
Default Re: THRUST WASHERS
Originally posted by SPACEBOY
DOES ANYONE HAVE A PART NUMBER OR KNOW WHERE I CAN FIND THE THRUST WASHERS FOR THE DIFF'S?
Part number# 309070
Jimmy
Old 03-29-2003, 12:35 AM   #3024
Originally posted by rc-zombies
Ray...
I'm just worried about the amount of flex on the composit C-hubs and soft arms. For Carpet you'd want it fairly stiff...I have the aluminum C-hubs and there is still some flex on the arms..now I'm waiting for the Med. Arms to be released. I find the aluminum ones more durable. may cost more but worth it. my 2centabos.
I'll have your med shipped by early next week.
Old 03-29-2003, 12:56 AM   #3025
Originally posted by Scrad
I've told you guys all along that the 2003 version has both suspension options. That is the kit that I have...
Anyways I raced my xray last night for the first time. I ran Mod. All I can say is damn it was fast, almost too fast for the track layout last night. The drivetran is soooo smooth. I could'nt get the car to slow down enough. It would coast all the way down the straights almost. I'm a drag brake person and I can't use the trigger for breaking very well. So I'm going to make the xray my rubber stock car for next week. The setup I used was pretty close, but since I'll be switching I'll have to change it around. So I'm very pleased with the car and my TC3 will be sold here shortly. That car is a piece, compared to the xray IMO.
What is the part number for the spring steel hex hubs you guys were talking about? I know you said something about getting rear only or something, because the front is not needed. I'll be selling my TC3, so I'll be buying parts for the xray. Anything you guys suggest. I think I'll be getting a spring package and a roll center bridge for sure.
Scrad,
Sorry for the late reply, but if you're running the C-hub then you'll need the the rear spring steel hub up in the front instead of the front hub because it's longer. Part # 305315
Jimmy
Old 03-29-2003, 08:58 AM   #3026
Caddzilla's Avatar
Send a message via ICQ to Caddzilla Send a message via AIM to Caddzilla Send a message via Yahoo to Caddzilla
I have a quick question for you guys. What final drive ratios are you all using. I have an original T1 and the kit comes with a 93t spur and a 24t pinion which gives you a final drive of 8.2344. This seems a bit low to me. I am planning to convert to 64 pitch spur gears and was just wondering if I should try and match this ratio or do I need to drop this down closer to a 7.0 final drive ratio. Any help or thoughts would be appreciated.
Caddzilla is offline   Reply With Quote
Old 03-29-2003, 09:34 AM   #3027
The final drive ratio is dependent on the type of motor you are running, track conditions, track type, driving style, etc. It's a good idea to have an assortment of pinions to choose from. If you go to a 64pitch gears, you will have more fine tuning of your car. Do you race your car?
Old 03-29-2003, 09:55 AM   #3028
Caddzilla's Avatar
I guess I left some info out of my post. I race stock class with a P2K2 Pro motor, outdoor on asphault. I haven't raced the car as yet, still waiting on a few parts that are on back order. I do race and run in the Florida electric state series. SInce we travel to a number of tracks all over the state, and we don't always get a chance to practice before the first round of qualifing. I guess what I was asking was is this a good place to start or is there a better ratio to start with. I just switched from a Yokomo special to the Xray.
Old 03-29-2003, 09:58 AM   #3029
rc-zombies's Avatar
Jimmy...
Hope you have a set for me too..DrTechno...prompised me a set. He'll tell you who I am
could use the front and rear composite bumper too.
thanks,
Old 03-29-2003, 12:23 PM   #3030
Jimmy...
thanks,
You betcha! We'll have it sent on Monday.
Jimmy
