Old 03-18-2003, 05:11 PM   #2881
Neil Rabara's Avatar
How new is that body? Or are you selling a brand new, never been used one?
Neil Rabara is offline   Reply With Quote
Old 03-18-2003, 05:29 PM   #2882
safaridog's Avatar
I have one that is brand new. Only the mounting holes have been drilled. The wing and wheel openings still need to be cut.
safaridog is offline   Reply With Quote
Old 03-18-2003, 08:49 PM   #2883
Elk666's Avatar
That is one beautifull body, great job!!
Elk666 is offline   Reply With Quote
Old 03-19-2003, 11:17 AM   #2884
What are you asking for the new body? Is it the same design?
Old 03-19-2003, 01:09 PM   #2885
mab_man20's Avatar
Send a message via AIM to mab_man20
Im working on a project and am wondering what the tranny ratio for the X-ray is? If the tranny ratio's vary from version to version, what is the newest ratio.
thanks.
EDIT: I found the ratio for the EVO2 (2.125) anyone know if the new one will be the same??
mab_man20 is offline   Reply With Quote
Old 03-19-2003, 02:00 PM   #2886
rc-zombies's Avatar
Should be the same.. all versions use the same diff and parts..
Old 03-19-2003, 03:01 PM   #2887
safaridog's Avatar
I may have not been too clear in my previous post. I have a nice xray painted body like the one in this web site. http://www.kmaynespaint.com/Pages/RCBodies/RogX.html
It is painted by the same artist. Only the monting holes have been drilled, the wing and wheel opening still need to be trimmed.
I like $50us shipped. I'll also trade for 2 190mm 300m bodies.
If you want pic's of the body email me at [email protected]
Dennis
Old 03-19-2003, 03:28 PM   #2888
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
I have a sealed bag of 22 MM SS Hex hubs for the C-hub, is that what you're after?
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 03-19-2003, 04:19 PM   #2889
safaridog's Avatar
Wheel Axle Front With Hex Hub - Spring Steel (2)
#305215
If that's what you have that's what I'm looking for.
Old 03-19-2003, 05:10 PM   #2890
mab_man20's Avatar
Thanks rc-zombies!!
Old 03-19-2003, 05:31 PM   #2891
#305215
No, sorry.....I have #305315. I don't use PB.
V-Dezign 4.0
Old 03-20-2003, 02:13 PM   #2892
rayhuang's Avatar
Default Need helsp asap!!!
Guys,
Need help and fast!!! With the C-hub, composite C-hub and soft arms, hard arms, etc... all comingout at once, is it at all possible that a regular old T1 EVO2 PB car can be competitve on Carpet w/ foam tires?
I am dealing with a RCTech regular on a deal and I cannt decide on the PB car (new) or the C-hub (alum) but used and a lot more money.
Please-any advice would be great.
I can buy his PB car and for only $49 have the full Composite C-hub on it. I am pretty easy on front end parts so I am not too worried about the Composite caster blocks breaking. That and i can buy a set of optional 6-degree caster block cheap-instead of $54.00!!!
HELP,
Ray
Old 03-20-2003, 02:24 PM   #2893
rc-zombies's Avatar
Ray...
I'm just worried about the amount of flex on the composit C-hubs and soft arms. For Carpet you'd want it fairly stiff...I have the aluminum C-hubs and there is still some flex on the arms..now I'm waiting for the Med. Arms to be released. I find the aluminum ones more durable. may cost more but worth it. my 2centabos.
Old 03-20-2003, 02:29 PM   #2894
rayhuang's Avatar
rc-zombies- One shop I deal with said-on the plus side that the Composite C-hub set is SOOO light!!! So he said-better order a lot of spare Caster blocks !! They dont feel like they can take too much abuse!!!
He also recommended the composite steerng knuckles matted to the aluminum casterblocks. Saves weight-but is still super durable.
I just cannot get over $54 for a pair of 6-degree caster blocks-which I know I'll need because I always run 5 to 8 degrees of caster in my cars!!!
I think I may have to change my handle to "confused".
Old 03-20-2003, 02:54 PM   #2895
rc-zombies's Avatar
Well with the stock 3deg C-blocks and 3deg kick-up..that will give 6deg of total caster which should work out great for carpet.
