Old 03-06-2003, 11:06 AM   #2746
rc-zombies's Avatar
Looks the same as the original C-hub conversion kit..but made with Plastic. The Aluminum C-block is the same though..
Old 03-06-2003, 11:55 AM   #2747
Regional Moderator
BHenderson's Avatar
Send a message via AIM to BHenderson Send a message via MSN to BHenderson Send a message via Yahoo to BHenderson
plus hes running the blade style front sway bar. I had heard that the factory guys were running a different front sway bar than that now.
BHenderson is offline   Reply With Quote
Old 03-06-2003, 12:34 PM   #2748
rayhuang's Avatar
Sorry guys.... I dont own one of these...YET-so I dont know one from Adam. So I went off the caption that said Dans car showing new front end pieces at the Nats....
Old 03-06-2003, 12:55 PM   #2749
Regional Moderator
BHenderson's Avatar
ray
nothing to be sorry about! I love checking out new stuff like the composite spindle like that one in the pic.
Old 03-06-2003, 08:49 PM   #2750
Default Shaft Drive
Ok, everybody else seems to be coming out with a shaft drive car.... When do we see an Xray Shaft Drive?
XrayEye is offline   Reply With Quote
Old 03-06-2003, 09:07 PM   #2751
Scrad's Avatar
Trader Rating: 15 (100%+)
Default 2003 Evo2
If anyone is looking for the new 2003 evo2 with c hub and pillow ball go here. www.teamfuku.com
Scrad is offline   Reply With Quote
Old 03-06-2003, 11:49 PM   #2752
Default Composite C-hub conversion
A friend of mine bought this. http://www.teamfuku.com/xray/xr300900.htm
It has everything the alu c-hub at 1/3 the price. Not a bad upgrade for people with older T1 and Evos who don't want to spend for the alu. It comes with front cvds and other bits to boot.
elnitro is offline   Reply With Quote
Old 03-07-2003, 09:02 AM   #2753
rc-zombies's Avatar
Default Re: Composite C-hub conversion
I know the owner at TeamFuku...very professional and friendly person.. you will not be dissappointed with all the items he sells plus he's got some great prices on Xray stuff....
Old 03-07-2003, 10:34 AM   #2754
Scrad's Avatar
He is the guy I got my car off of and I would definatly deal with him again.
How tight or loose should the belt be on this car. I've never had a belt car before . Is their a way to check. My belt seems a little loose. I built it like the manual says. It also seems to rub on the motor a little bit. Is that because it is too loose.
Old 03-07-2003, 10:42 AM   #2755
rc-zombies's Avatar
I run mine stock and loose. less binding on the drive train. If it's too close to the motor try running a larger spur and pinion. I use a 120t 64p on mine.
Old 03-07-2003, 11:01 AM   #2756
Scrad's Avatar
I've got a 128 spur 64 pitch. With a 25 tooth pinion. I just threw it on, because I don't know that to run yet for a gear. I'll be running a 10-2 motor.
Old 03-07-2003, 11:05 AM   #2757
rc-zombies's Avatar
I think that's too small of a pinion for that spur gear and motor..try using a pinion in the 30's
Old 03-07-2003, 01:15 PM   #2758
Scrad's Avatar
k, that could be my problem then. Thanks...
Old 03-07-2003, 02:23 PM   #2759
c-lyon's Avatar
Sometimes it touches the motor at rest, but not when under power.
c-lyon is offline   Reply With Quote
Old 03-07-2003, 04:42 PM   #2760
theisgroup's Avatar
Default question to the god of xray
I picked up the spring steel hubs. One set of rears and on set of fronts. It looks like with the c-hub conversion, I really need 2 sets of rears. Is that true?
thanks
theisgroup is offline   Reply With Quote
