Old 11-01-2001, 12:04 PM   #256
Funny thing happened the other day racing. I was running my car for the first time in a number of weeks and had to get used to it again. Anyhow, my first two qualifiers were pretty good but the car still seemed to be slower than I was used to. I changed my body from Accord to Stratus and the rear of the car loosened tremendously , after all loose is fast right. I decided this was better than before, so I dropped the shocks down a notch and went with it. Well now I was on pace with pack and would have finished high in the A but my qualifiers regulated me to the C. Will see about this weekend as I try a front one-way and rear sway bar.
damo is offline   Reply With Quote
Old 11-02-2001, 11:45 AM   #257
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
I will try my first Protoform Stratus body this weekend. The body served as a sampler for my first time air brushing anything. I do not like the detail so I am guessing that I need to run more than 40 PSI or finer nozzles.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 11-02-2001, 11:52 AM   #258
Good luck to you both ( RCCadet, and Damo ) I'm also intrested in both of your setups too.
milf is offline   Reply With Quote
Old 11-02-2001, 11:56 AM   #259
My set up is on my site at the bottom of my RC page.
V-Dezign 4.0
Old 11-06-2001, 04:32 PM   #260
Well I didn't make it out to the track the other day, but I am going for a test session today. We'll see how it goes. I am taking my Orion lap counter to compare times using a few different factors. I will test tires, one way pulley, and wheelbase today. Not enough time for full testing. Also this will be with a one-way up front the entire time. Does anyone know where to find the molded bulkhead bearing carriers? Also how did you guys let this thread slip to the 2nd page? No new news?
Old 11-06-2001, 04:39 PM   #261
STLNLST's Avatar
Trader Rating: 21 (100%+)
damo- What up fool? How long have you been running this car? I'm going to talk to Mo and see if everyone is going to make another Socal trip. This time we are going to bring all da homies. Dujuan will be up that way on vacation in about a week but if he were to try and bring any RC stuff he may be killed on site. I'll keep you posted.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 11-06-2001, 06:52 PM   #262
Sorry about letting this slip. I had an awesome weekend. My car was on rails. I had the trigger at full throttle 98 % of the time and the Takeoff WS-B tires never broke free! I finished fourth in the A-main and after temping the motor discovered that I could have easily gone up two teeth on the pinion.
V-Dezign 4.0
Old 11-07-2001, 07:20 AM   #263
Manticore's Avatar
R/C Tech Charter Subscriber
anybody tried the metal front upper arm mount? what setting you run and what is the result?
I run the max angel lean to the front and no kick up on lower a-arm. the car has smoother cornering characteristic.
Manticore is offline   Reply With Quote
Old 11-07-2001, 11:21 AM   #264
I have been running this car only since it came out. I hope you guys can make it down.
Running the one-way was quite an experience. I didn't have the time to play with it like I would have liked though, so no official test results. I just reassembled the car and it spins going on throttle turning right. Maybe I need to check the center pulley. Anyhow, with the new belts, one-way pulley and front oneway, the damn car rolls forever. Difficult to judge initially. I only did one pack on this setup so no official results. I am going out again tomorrow, so I will test more extensively then.
Old 11-07-2001, 08:40 PM   #265
The setting you indicated above is great but since then I've used the lowest (nearest to the chassis) setting. I like the aggressive and very responsive suspension. I had a blast this past weekend. I never let up on the trigger unless I was avoiding a backmarker.
I made the essentric pin holders myself, I did not want to wait for them.
V-Dezign 4.0
Old 11-07-2001, 08:48 PM   #266
Manticore's Avatar
do you still use kick up with your setting?
Old 11-07-2001, 08:58 PM   #267
Yes, I left that setting alone. The track I race on is not perfectly flat but close to it.
V-Dezign 4.0
Old 11-07-2001, 09:01 PM   #268
Manticore's Avatar
how did you manage to drill the new holes on the plastic one ? unless you have a high precision machine to do that?
Old 11-07-2001, 09:42 PM   #269
I used my Dremel and one of the special bits it came with. It penetrated and discharged the plastic with little effort.
V-Dezign 4.0
Old 11-07-2001, 09:44 PM   #270
Manticore's Avatar
but how can you asure they come in asymmetical to each other with hand tool?
