Old 02-18-2003, 05:04 PM   #2566
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
You can borrow my spool to see if you like it. If you like it you can use it till yours arrives.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 02-18-2003, 05:08 PM   #2567
Suspended
Default as
asasasasas
mikshea is offline   Reply With Quote
Old 02-18-2003, 05:11 PM   #2568
rc-zombies's Avatar
I was thinking of getting the Spool as well..hows it handle compared to the front one-way?
Old 02-18-2003, 05:12 PM   #2569
theisgroup's Avatar
i am still a new drive, but I like the way the spool handles. It help me learn the lines on the corners and help me keep my speed around the turns. If i don't control my speed, you just spin out. So I have been using it as a learning aid.
theisgroup is offline   Reply With Quote
Old 02-18-2003, 05:18 PM   #2570
rc-zombies's Avatar
Originally posted by RCCadet
Consider 22mm Spring Steel hex hubs. I have a set I am about to put on. The alu hex hubs will bend from contact with the axle. After that has happened it is a bear to remove the hex hubs and service the bearings. Are you racing at the new Dallas track this weekend? I can help you there.
Yes..definately get the Spring steel axles/hex hubs. they will last forever.
theisgroup. the front hubs are brand new..I just replaced them. the rears are in still in new condition. I just cleaned and lubed it.
30wt oil all around. Pistons: 2 open front, 4 open rear.
you're all set to go racing!
Old 02-18-2003, 05:20 PM   #2571
theisgroup's Avatar
thanks all for the help and suggestions
rc-zombie- can't wait to get it. i have gotten tired of just replacing part on the tc3. nice car but seems to have a glass jaw.
Old 02-18-2003, 08:12 PM   #2572
Neil Rabara's Avatar
I'm having trouble trying to remove the stock wheel hubs, maybe the spring steel version is the way to go.
Neil Rabara is offline   Reply With Quote
Old 02-19-2003, 11:24 AM   #2573
Scrad's Avatar
How come I can never find anyone selling a used evo 2? I've looked everywhere and I rarely find one.
Scrad is offline   Reply With Quote
Old 02-19-2003, 11:40 AM   #2574
rc-zombies's Avatar
Yes the spring steel hubs are the way to go..they will last forever.
To remove the aluminum one...you'll need to disassemble the hub and place it on some support blocks or vice. but don't lock down on the wheel hub. should be free to move. now take a hammer and "gently" tap on the end of the CVD bones until the hub is out.
good luck.
Old 02-19-2003, 11:42 AM   #2575
rc-zombies's Avatar
Usually they are snatched up quickly or by word of mouth.
I just sold one...
email me at [email protected]
I know someone who is selling one.
Old 02-19-2003, 03:20 PM   #2576
If the hub does not pass through the bearings with 'lite' taps, you will have to file the part that is preventing removal. Too much tapping will damage the bearing races.
V-Dezign 4.0
Old 02-19-2003, 05:28 PM   #2577
good luck.
I've heard that is what I would have to do.
Old 02-19-2003, 05:38 PM   #2578
rc-zombies's Avatar
Actually the aluminum is so soft the it will break into small pieces before it damages the bearing races. if you do..you can get Blue high speed sealed bearing from Teambluestar.. there contact info can be found on ebay. the bearing cost about $1.60 each..I think shipping is free. I bought the complete set for the Xray..
the smoothest bearing I've every used...now I have them too on my Pro3 and TC3.
Old 02-19-2003, 05:48 PM   #2579
I wish that was true, I luckily had an additional pair of Blue sealed bearings. I had damaged two bearings. In the end I knew my SS hubs where on the way and so I grabbed the Alu hub with pliers and crushed them to free the hub and save my new bearings. One day on carpet and I end up scrapping Alu hubs.
V-Dezign 4.0
Old 02-19-2003, 05:54 PM   #2580
I haven't tried removing the hubs in the rear. Have you guys had problems with them?
