Old 02-17-2003, 05:54 PM   #2551
wrxmy99's Avatar
I found the stock pillow ball setup a little too tail happy when using a one way diff.
One spring stiffer on the front was all that was required to dial it out...
Cheers
Andy
wrxmy99 is offline   Reply With Quote
Old 02-17-2003, 05:59 PM   #2552
wrxmy99's Avatar
Cheers
Andy
Old 02-17-2003, 08:39 PM   #2553
Neil Rabara's Avatar
I was studying the inline cooling tunnel on the T1R, I must say that it is a unique design that puts added air flow to the motor, and at the same time stiffening the tub chasis.
Neil Rabara is offline   Reply With Quote
Old 02-18-2003, 04:41 PM   #2554
theisgroup's Avatar
Default new xray questions
Hey all,
I am a new xray owner, or at least soon to be. I have an evo2 with the c hub conversion comming and was wondering if there are any other thing that I should order with it. I also have a few front arms and front one way with it.
any suggestions would be great.
thanks
theisgroup is offline   Reply With Quote
Old 02-18-2003, 04:49 PM   #2555
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Consider 22mm Spring Steel hex hubs. I have a set I am about to put on. The alu hex hubs will bend from contact with the axle. After that has happened it is a bear to remove the hex hubs and service the bearings. Are you racing at the new Dallas track this weekend? I can help you there.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 02-18-2003, 04:49 PM   #2556
antoniop's Avatar
I only run is asphalt and to be honest I didn't find any advantages of running the cool looking C Hub conversion that I installed in my T1.
This T1 is more like an EVO 1.5 due to the number of EVO 2 parts that were installed.
But regarding the hubs, I found out that the camber link positions on the rear cause the camber angle to be less than perfect when the car rolls. This caused the rear to loose grip.
I had to put a higher camber angle to compensate for this "flaw"
The pivot ball suspension is excellent for asphalt.
I got the yellow and blue springs, but you probably profit from the new spring set for finer tuning.
The rear roll center bridge also helped a lot in keeping the rear perfectly planted.
And of course the front one way...
antoniop is offline   Reply With Quote
Old 02-18-2003, 04:51 PM   #2557
theisgroup's Avatar
no racing this weekend for me. I have wifey things to do. going to houston for a wedding
next weekend though. Should have the car by then. Just wanted to make sure I had stuff to tune with. Do you thing I should get a spring set, or will my AE ones work for now?
Old 02-18-2003, 04:54 PM   #2558
theisgroup's Avatar
antoniop, thanks for the quick reply. Where is everyone getting xray parts now?
Old 02-18-2003, 04:54 PM   #2559
rc-zombies's Avatar
I use the AE springs... they fit just fine...mostly use the Reds, and blues for tuning. but you'll find that the stock white springs work well with the C-hubs.
The Roll-center bridge is included!
Old 02-18-2003, 04:54 PM   #2560
Your AE's will work. Antoniop touched on the rear roll and I also would recommend a Roll Center Bridge and I can show you how to make the adaptation I use on top of the rear hub carriers. Atomic showed me a short cut!
V-Dezign 4.0
Old 02-18-2003, 04:55 PM   #2561
theisgroup's Avatar
oh yeah, I guess rc-zombie would know best. since it is coming from him
Old 02-18-2003, 04:57 PM   #2562
You are set!
V-Dezign 4.0
Old 02-18-2003, 05:00 PM   #2563
theisgroup's Avatar
RCCadet,
Where are you running next week? I am thinking that jason and I would be out at lewisville on saturday. Depends on the series race if they go to austin this weekend or not.
and also was thinking about getting the spool that xray makes, since I run a spool on my tc3 right now. is it worth it?
Old 02-18-2003, 05:03 PM   #2564
The HTRLrc season begins March 1st, this weekend is the SWCS I thought?
V-Dezign 4.0
Old 02-18-2003, 05:04 PM   #2565
theisgroup's Avatar
yeah, if they get rained out this weekend in austin, jason wants to go to htrl next weekend (march 1)
