Old 02-04-2003, 09:20 PM   #2461
picco007's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
Default sanyo 3000hv's
I tried to run some 3000hv's and I had trouble putting the cells in my evo2. Does anyone else have this problem? Will the powers 3300's and the gp 3300's fit or will they be too big?
picco007 is offline   Reply With Quote
Old 02-04-2003, 10:09 PM   #2462
hv's should fit in fine, Gp's are a bit snug, but still fit in fine. I have not used sanyo 3300's. You just have to make sure that the alumium battery posts are absolutely square on the chassis, somtimes they can rotate out of alignment when building/used.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 02-05-2003, 04:08 AM   #2463
RC Nitro's Avatar
I have HV, SMH's, Sanyo 3300 and GP 3300. All fit. As stated GP's are tight. Sanyo 3300's are the same size as HV's.
What is asphalt???
RC Nitro is offline   Reply With Quote
Old 02-05-2003, 06:30 AM   #2464
You can allways ditch the Xray battery mounting system and just tape the batteries in.
This way the size of the battery won't matter and you won't torque the chassis to get the straps down.
Nanook is offline   Reply With Quote
Old 02-05-2003, 10:29 AM   #2465
Neil Rabara's Avatar
You can try taping the batts down, the problem lies with the batts on the right side. There is no slot to slip the tape through in the rear right.
Neil Rabara is offline   Reply With Quote
Old 02-05-2003, 11:14 AM   #2466
I use the opening underneath the motor, on both sides for the back and the next forward battery hole for the front.
Hasn't creates any problems for me.
Old 02-05-2003, 04:05 PM   #2467
DO NOT USE TAPE, that stuff has to be the most annoying stuff in the world, and it always breaks at the wrong time, like when you are leading a race.
if you need more clearance on the battery straps, you can just add a small washer under the posts to relieve the pressure, the xray straps are the best in the business, dont be stupid enough to get rid of them.
Old 02-05-2003, 04:19 PM   #2468
picco007's Avatar
Default Thanks
I am wondering if the thickness of the shrink wrap is the problem.....No one here has had problems but me....I will try to dremel the posts a little to see if that helps......I have made sure that they are square on the chassis.. I appreciate the advice.
Old 02-05-2003, 09:34 PM   #2469
I have a EVO2 with the C hub suspension. I've had it for about 5 months. Today I found that if I turn the steering full left or right the cvd bone will rub against the collar of the wheel hub. I have the spring steel wheel hubs front and rear. It hits a little more on the right wheel then the left. Has anyone experienced this?
I'm thinking that the cvd bone where it meets with the hub and where the pin sits with the barrel, has worn and have a little more play then usual. I'll find out tomorrow when I check it.
racingdc9 is offline   Reply With Quote
Old 02-05-2003, 09:59 PM   #2470
KMW
KMW's Avatar
The new car, again (from the nitro forum):
KMW is offline   Reply With Quote
Old 02-06-2003, 03:40 AM   #2471
warlord385's Avatar
Hey guys i'm using the light purple springs in the stock shock mount position and i can't get my ride height to 5mm. Am i doing something wrong. Should i move the shocks one hole vertical???. Also what springs should i use for carpet. i have the 5 spring set with dark blue, light blue, purple, blue green, light red springs.
warlord385 is offline   Reply With Quote
Old 02-06-2003, 03:51 AM   #2472
warlord385's Avatar
oh yeah this would be with a stock motor and foams
Old 02-06-2003, 04:09 AM   #2473
RC Nitro's Avatar
war: It is the droop screws. Raise them to the next # Ex: on C hub front the std setting is 1 mm. Raise it to 2 mm and check to make sure you have negitive suspension travel. ON the C hub there is a new front tower for the smaller foams.
Old 02-06-2003, 04:25 AM   #2474
-CriMinaL- |RC's Avatar
Send a message via AIM to -CriMinaL- |RC Send a message via Yahoo to -CriMinaL- |RC
What exactly is this new xray (pictured) supposed to be??
is it like an entry level kit ( ta04) or more like a budget version of
the current xray cars??
-CriMinaL- |RC is offline   Reply With Quote
Old 02-06-2003, 05:36 AM   #2475
It's a sport version of the T1........ BTW::::
NEWS FROM "THE BIRDS"!!!!!
Mario Hudy told a local Maryland racer that the est. street price for the T1R will be $229..........
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
