Old 01-19-2003, 05:31 PM   #2311
about 2 mm
sanitairgoof is offline   Reply With Quote
Old 01-19-2003, 05:39 PM   #2312
Neil Rabara's Avatar
You definitely have a problem. You may have mixed up the components with others during assembly, or you were given an incorrect item at packaging (unlikely). Post your problem on myTSN.com, the HUDY/XRAY moderators will address your dilemma. Good luck.
Neil Rabara is offline   Reply With Quote
Old 01-19-2003, 05:41 PM   #2313
Okay, i going to do that. thanks.
Old 01-19-2003, 08:45 PM   #2314
i think there is a pair of concaved washers that go on the layshaft in opposite directions that are compressed when you tighten the oneway pulley, so make sure you have put those on in the proper orientation.
www.rikter-designs.com
[email protected]
Jarrod Langlois is offline   Reply With Quote
Old 01-19-2003, 09:38 PM   #2315
Those concave washers are for tension of the layshaft oneway. Even if the washers were put in the same direction, that would not effect the amount of play the layshaft moves between the bulkheads, it effects only the oneway's performance.
Old 01-20-2003, 12:42 PM   #2316
Who runs on an outdoor track?
Old 01-20-2003, 12:46 PM   #2317
rc-zombies's Avatar
What's the best gearing to start with using rubber tires:
P2K2?
new MosterStock? (probably 1 or 2 teeth less than the P2K2?)
and 8x2?
Old 01-20-2003, 12:57 PM   #2318
P2K2?
and 8x2?
You can try a 6.8FDR on the P2K2, a 7.5FDR for the MS, and a 8.4FDR for the 8x2. Adjust accordingly for your driving style and track size. Good luck.
Old 01-20-2003, 01:00 PM   #2319
Regional Moderator
BHenderson's Avatar
Send a message via AIM to BHenderson Send a message via MSN to BHenderson Send a message via Yahoo to BHenderson
Neil
I run on an outdoor track most of the year. This is my first season driving the Xray and our season doesnt start until march. Still searching for different setups to try out on our parking lot track with decent traction. Our track is roughly 130 x 50
BHenderson is offline   Reply With Quote
Old 01-20-2003, 01:12 PM   #2320
rc-zombies's Avatar
Thanks Neil..
Old 01-20-2003, 03:03 PM   #2321
Not sure if its OK to post this here so I apoligize in advance if I've broken protocol. If anyone know of anyone wanting to purchase a NIB Xray T1, please point them to this link.
Thanks,
Dennis
DennisA is offline   Reply With Quote
Old 01-20-2003, 03:15 PM   #2322
rc-zombies's Avatar
Thanks,
Dennis
Are you selling or buying...you may want to try the sell / trade forum.
Old 01-20-2003, 03:52 PM   #2323
Thanks,
Dennis
Have you tried eBAY?
Old 01-20-2003, 03:53 PM   #2324
Originally posted by PorscheSuperCup
Neil
I will be starting parking lot races in the spring and I just wanted to see some setups for outdoors. I normally run indoors on a high bite track.
Old 01-20-2003, 09:14 PM   #2325
mike5009's Avatar
Send a message via AIM to mike5009
try the base set up as its real close to what you need for out doors. they hit a very neutral set-up. then i run 45 shore front and 42 shore rear speedmind foams(btw these foams tend to run a little soft on the durometer) then tune to your driving style by adjusting shock rebound, droop, shock angle. i have yet to qualifiy out of the "A" with the box set up on asphalt. now carpet is a different story. you need to put a completly different set -up under the car. enjoy racing such a fine car
mike5009 is offline   Reply With Quote
