Old 01-18-2003, 10:03 AM   #2296
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Trinity :: Isn't that a carpet setup?
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 01-18-2003, 11:44 AM   #2297
Neil Rabara's Avatar
Almost, except for the springs, and the c-hubs. Some people like having the roll bars on, others don't. Depends on the track.
Neil Rabara is offline   Reply With Quote
Old 01-18-2003, 01:14 PM   #2298
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Sorry yellow springs for asphalt and possibly no roll bars. It depends on how u like to drive
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 01-18-2003, 02:07 PM   #2299
KINGZJ's Avatar
Send a message via AIM to KINGZJ
I bet it is a carpet setup. Stephan only runs on carpet (at least so far with this car)
KINGZJ is offline   Reply With Quote
Old 01-18-2003, 02:11 PM   #2300
Steevo's Avatar
Default CAN SOMEONE PLEASE HELP
Hello Everybody,
Just picked up an Xray T1 first version and there are a couple of things I wanted to ask.
Firstly I am having trouble fitting the carbon fibre Bumper upper plate. It is the one with the transponder cut out and it seems to sit a few millimetres above where it is suppose to sit on the front bulkhead. Is this suppose to be or am I missing something??
Secondly the measurement in the book for the steering rod that connects to the servo horn seems awfully long. If I was to leave it at the length stated in the manual the servo horn would not be able to sit perpendicular to the chassis. Have I done something wrong. Would it hurt if I used a shortened arm which allowed the servo horn to sit perpendicular to the chassis??
Any help is much appreciated
Steevo
Steevo is offline   Reply With Quote
Old 01-18-2003, 02:53 PM   #2301
Moderator
The setup above is for carpet, soften to yellow springs and no roll bar or a smaller one for the rear for asphalt. The setups on this car work well every where so far.
SMC Racing
Old 01-18-2003, 08:39 PM   #2302
dtm
dtm's Avatar
Send a message via ICQ to dtm
Default Re: CAN SOMEONE PLEASE HELP
Originally posted by Steevo
Hello Everybody,
The original foam is a little thicker than the gap between the brace. You can either cut the foam thinner or simply put the screws into the bulkhead and compress the foam, after a while the foam kinda takes on the new shape!
As for the linkages just measure up the car's toe-in after you have finished building it, the orginal geometry from the manual is "strange"! One word of advise the plastic used for the ball ends are tough. When building the turnbuckles it is best to thread the turnbuckle all the way into the ball end to cut the thread and then back off. It will be easier to adjust them later on without them popping off each time.
dtm is offline   Reply With Quote
Old 01-18-2003, 09:52 PM   #2303
Steevo's Avatar
Thanks for your help. I wasn't sure if these things were because of something I was doing wrong or not. I always use a "Tap" to make a thread in any plastic parts before putting in the screws. It helps a lot.
Steevo
Old 01-19-2003, 05:41 AM   #2304
dtm
dtm's Avatar
Steevo
When I built my first Xray I made up the assembly consisiting of the plastic bumper, foam bumper, graphite piece and front body post. Built it up and then used a muti grip (or vise would do) simple to flatten the foam....it helped a little....
Old 01-19-2003, 11:03 AM   #2305
rc-zombies's Avatar
THanks guys..I'll try it out next week.
Old 01-19-2003, 04:57 PM   #2306
Hi guys,
I just build my x-ray and i love the car it's great! But i noticed a large amount of play on the layshaft between the bulkheads. Is this normal? Or what did i do wrong.
Thanks.
sanitairgoof is offline   Reply With Quote
Old 01-19-2003, 05:14 PM   #2307
Carbon_Fibre3's Avatar
did you remember to put the washer in?? there is a washer that goes on b 4 the one way bearing.. that coudl be your problem
Carbon_Fibre3 is offline   Reply With Quote
Old 01-19-2003, 05:14 PM   #2308
The large amount of play is not normal. Disassemble and try again ensuring that the directions is followed and every piece is seated. Good luck.
Old 01-19-2003, 05:22 PM   #2309
I rebuild it a couple of times but the problem stays. Do you guys have play? or nothing at all?
Old 01-19-2003, 05:28 PM   #2310
I have very little play in the layshaft. Describe how much play you have?
