Old 01-15-2003, 01:22 PM   #2281
Neil Rabara's Avatar
I run the dual servo saver using the inside holes. I've discovered that this setting has no bump steering, good Ackerman. This also allows you to extend the ball cups out a little more to prevent flexing.
Neil Rabara is offline   Reply With Quote
Old 01-15-2003, 04:10 PM   #2282
mo
mo's Avatar
Speedworld Raceway now has X-ray cars and parts in stock. They are selling EV0-2's for $299.99. www.speedworldraceway.com or 916-783-8864
TLR, Spektrum, Tekin, SMC, MO-GRIP, www.factory-rc.com https://www.shapeways.com/shops/MPP
mo is offline   Reply With Quote
Old 01-15-2003, 07:03 PM   #2283
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Sweet, I am looking forward to seeing their online prices on 1/20/03.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 01-16-2003, 12:52 AM   #2284
Carbon_Fibre3's Avatar
hi, i only just completed my xray, and am only new to forum.. so havent read past things, but the scale diagrams of the steering rods n stuff, seem a bit off.. ie to long..
anyone else discovered this?
Rob Storey
Carbon_Fibre3 is offline   Reply With Quote
Old 01-16-2003, 01:00 AM   #2285
Hmmmm.....I used my calipers and things went together fine. Were all your turn buckles the wrong length?
V-Dezign 4.0
Old 01-16-2003, 01:01 AM   #2286
i built them to the diagrams then cheked with calipers... .. .. 5mm out or something.. woops
Old 01-16-2003, 01:02 AM   #2287
wow, which were off?
V-Dezign 4.0
Old 01-16-2003, 01:18 AM   #2288
teh two steering ones..
i couldnt belive it.. the diagrams are 1:1 scale aswell... the guy in the CAD department made it to long me thinks...
Old 01-16-2003, 10:12 AM   #2289
Yeah, I think you are right about the length being too long for the steering setup.
V-Dezign 4.0
Old 01-16-2003, 06:37 PM   #2290
I'm sure when it was initially done, it was to scale. Putting it on paper does alter things.
Old 01-17-2003, 05:20 PM   #2291
rc-zombies's Avatar
receiving my EVO2 w/C-hubs next weeks..
anybody give me a good starting setup for high traction track.
using P2k2/Monster stock, and 8x2 motors.
thanks in advance.
Old 01-18-2003, 05:05 AM   #2292
Steevo's Avatar
Hello Everybody,
Just picked up an Xray T1 first version and there are a couple of things I wanted to ask.
Firstly I am having trouble fitting the carbon fibre Bumper upper plate. It is the one with the transponder cut out and it seems to sit a few millimetres above where it is suppose to sit on the front bulkhead. Is this suppose to be or am I missing something??
Secondly the measurement in the book for the steering rod that connects to the servo horn seems awfully long. If I was to leave it at the length stated in the manual the servo horn would not be able to sit perpendicular to the chassis. Have I done something wrong. Would it hurt if I used a shortened arm which allowed the servo horn to sit perpendicular to the chassis??
Any help is much appreciated
Steevo
Steevo is offline   Reply With Quote
Old 01-18-2003, 06:43 AM   #2293
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Zombies- What tires are u using, foam or rubber. ive got good setups for both
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 01-18-2003, 09:44 AM   #2294
rc-zombies's Avatar
Rubber tires mostly.
sorex 32R's and 36R's in the middle of summer. If it gets really hot 40's
thanks..
Old 01-18-2003, 09:59 AM   #2295
Moderator
FRONT
white springs
2 holes open
30 wt oil
0 dive
-1 camber
1 degree toe out
caster 1 small clip in front of arm
stock shock locations
45 degrees for roll bar
droop 1mm
REAR
white springs
4 holes open
30 wt oil
0 squat
-1 camber
2-3 degrees toe in
254mm wheelbase
2 mm roll bar
droop 2mm
SMC Racing
