Old 12-05-2002, 05:49 PM   #2131
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
On the c-hub I raised the ball stud about 4mm and brought it inward about 5mm. The link overall is the same length if using the stock hole in the bulk heads and inner hole on the c-hub. I have the roll center bridge and use its upper hole with the c-hub mod I made. The rear is very planted. I've not experienced or not noticed the positive camber thingy.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 12-06-2002, 01:39 AM   #2132
Hey. I have to ask, how you guys raise those c-hub uprights than 5 mm, because there are only 1 mm space near to wheel? Do you make piece of something at you can change it 5 mm invard, or....what?? Is that make better rear end traction to raise them ie normal lower system? If it do that, i can try too
Proto pilot is offline   Reply With Quote
Old 12-06-2002, 05:40 AM   #2133
dtm
dtm's Avatar
Send a message via ICQ to dtm
You will get positive camber change if the outboard (hub) end of the upper turnbuckle is lower than the inboard end (imagine the turnbuckle sweeping a circular motion).
The reverse is of course true if the hub end of the turnbuckle is higher than the inboard end. ie. negative camber change.
dtm is offline   Reply With Quote
Old 12-06-2002, 11:08 AM   #2134
Thumbs up I found someting
Couple nice pictures from rear about that our conversation.
http://www.rczone.net/images/articles/istc_xray_1.jpg
http://www.rczone.net/images/articles/istc_xray_2.jpg
Btw: Those hub pieces, they look over 4mm higher to me?!
Old 12-06-2002, 11:20 AM   #2135
mike5009's Avatar
Send a message via AIM to mike5009
PROTO who's car is that? i had made the same pieces long ago but out of composit.
mike5009 is offline   Reply With Quote
Old 12-06-2002, 12:19 PM   #2136
Smile
Hey Mike. That was Jilles car.
More nice pics from Xray:
http://www.rczone.net/modules.php?na...rticle&sid=225
Enjoy
Old 12-06-2002, 12:32 PM   #2137
Unhappy Damn
Sorry, that does`t work?! Go www.rczone.net - there search - and then Xray Prototype & news parts 2002 IFMAR World Championships part 5 and you`ll find those pics
Old 12-06-2002, 10:57 PM   #2138
Those images of course show use of an alu piece screwed onto the hub where my version is milled out of woven graphite. From looking at the pictures, it appears that I may have the same roll center or near it. Atleast with my mod I can shim higher or lower to change the roll center.
V-Dezign 4.0
Old 12-07-2002, 04:11 AM   #2139
Forget about the roll center parts, what is the go with the lower arm mounts, they are alloy, and move the arm out further with the hings pin sitting inline with the bulkheads. i would have thought theis would make the car wayyyyy to wide, unless they also have shorter arms
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 12-08-2002, 07:10 AM   #2140
Smile New parts testing... Evo3..???
Okey, now i did that modification also for my T1, but i have to test it first later. I made it like a RcCadet does. I did those graphite pieces from my old original T1 front shock tower, because it`s wright shape Those tree holes ( holes are 5mm distance each other ) so i just cut with dremel and scape it and that`s it, fast and easy. Scruwed it with two scruw to hub and put enough motor shims under the ball link (raise it than 4mm). I used those old original rear links what are shorter than new ones and voi`la, it look like a Xray part
I had these extra old parts to use and destroyes them for this project, because i up-grated my T1 with c-hub system and most of old parts had to change.
Yesterday was test day and i have to say when grip is good the
original c-hub set-up in rear end is more than ok.
I have to ask, about that new modification, when you raise up and shorter rear link really increase rear traction when grip is low, right???
Old 12-09-2002, 08:55 AM   #2141
Send a message via ICQ to Ragman
Besercoe, they're prototype short wishbones. I think they were first tried at the worlds. From what I've heard they won't be going into production but who knows.
//Stu
Ragman is offline   Reply With Quote
Old 12-09-2002, 09:11 PM   #2142
I think I figured out the gearing finally. I still haven't fixed my electrical woes...I thought it was the speedo, but it wasn't. I thought it was the reciever, but it wasn't. I turned out to be my servo Last thing I need to work out is the fact that while the car is rock solid it really cones the tired real bad. I have around 6 degrees of caster and I think around 1.5 of camber on the front.
jesse370 is offline   Reply With Quote
Old 12-11-2002, 12:00 AM   #2143
Exclamation Something new?
What`s up guys? It`s quite silence here, but thats ok... i guess, one and half weeks hard working yet and after that it`s christmas holiday in countryside More testing with new parts next saturday and it`s done. Out winter series Finntrack 2003 begin early in January and then we`ll see how did homework well...
Old 12-11-2002, 04:10 AM   #2144
RC Nitro's Avatar
Proto: Good luck in the series. Like you I have 1 1/2 weeks left and then gone for the holiday. My 6 year old is ready now LOL.
RC Nitro is offline   Reply With Quote
Old 12-11-2002, 05:46 AM   #2145
Talking
Thanks Nitro!! My 7 year old is ready too.... and today is his birthday anyway!!! double
