Old 12-03-2002, 12:53 PM   #2116
You are welcome Johnny
Tomorrow evening i`ll go to my local club and make a some test with my new parts for T1 and if i`m lucky Teppo will be there also, so it`s much easier when i can talk with him and make some adjustment for my car in same time
I think that, at new solid axle system will be a hot thing in near future after the one-way especially in carpet. I talk with some guys about one-ways and they agree that at some of those one-ways are grap (bearings are too weak) ie solid axle.
What you guys think about that?
Proto pilot is offline   Reply With Quote
Old 12-03-2002, 01:01 PM   #2117
mike_Webb's Avatar
Send a message via AIM to mike_Webb
I have not had any problem with the Mid-Shaft one way. As long as I lube it, it is good. I always run the Mid-One Way loose on my carpet track. I also run a really tight Front Diff... Not solid but pretty darn tight.
mike_Webb is offline   Reply With Quote
Old 12-03-2002, 01:28 PM   #2118
Mike. I have had a several touring cars (almoust 8 years now) and i mean that front one-way problem especially when i used Yokomo or Associated and i tryed to maintenance and lubricate them, but not any succesful.... i even change new bearings to them.. so i was very buored, because i bought a meny new one-ways and spent a lot of cash. After those i bought a new T1 and no any problems with one-ways, until today many of those manufactures make a bigger bearings now, at they are stonger than before, what is the right way. Now i try to use that new solid diff and center axle system to ficure how different/faster it`s to drive.
Old 12-04-2002, 04:49 AM   #2119
RC Nitro's Avatar
Proto: I ran 1 way and solid axle in my 1/8. That is a fast setup but touchie!! Not for unsmooth drivers like me LOL I am not the fastest, but I build a good motor and have a good setup. Run tight diff's on my car, but no 1 way. I think I am getting one for christmas from the wife . I run the front mid tight as I do not want to blow it up Heard of all the troubles, and I have to mail order parts as there are none local.
I digress. What was told to me the 1/8 guru (Art Carbonel). "The solid axle is not a drawback for 1/8 as the 2.5 hp+ motors will over come any losses. There is enough power there to turn the tires over and not give any losses." That made a lot of sense to me. Question, do you run stock or mod? I would be intrested in your feedback on this!!
RC Nitro is offline   Reply With Quote
Old 12-04-2002, 07:11 AM   #2120
Smile
Rc Nitro: Yep. I run mod touring some years now and sometimes mod off-road in summertime when sun is shining Sorry, i can`t give you any feedback about gas car systems etc, because i run only electrics 1/10... or what you mean by that..?
Old 12-04-2002, 07:17 AM   #2121
RC Nitro's Avatar
Hi Proto: I have actually sold all my nitro. I meant electric cars. But I do know that the power of a mod is considerably more that stock and that is why I think mod would work better with straight axle than stock. Stock lacks that extra punch of a 10 single
Old 12-04-2002, 08:31 AM   #2122
Smile
I`ll tell you more about my feelings after tonight when i`ll test those parts
Old 12-05-2002, 01:09 AM   #2123
Talking Test results
Solid-diff and center solid axle together is way to go on carpet!!! Our club track is technical, but fast and grip is quite good especially after several guys drove with foam tires. I`m not sure how it works when grip is lower, because i don`t test somewere else (yet), but yesterday evening my T1 was like a dream to drove. I have also c-hub kit and new Xray shoks in my car and it`s feel very good to drive with cs-22 tires - fast and easy -. I recommend to try this combination with your T1 or Evo2. Those new solid parts are`t even expensive and you can buy them directly from shop. I heard yesterday from other guys, how drive a another cars, they have to make those lockdiffs by themselves....!!!
Old 12-05-2002, 04:59 AM   #2124
RC Nitro's Avatar
Thanks Proto: You like the solid front diff better than the 1 way?
Old 12-05-2002, 05:31 AM   #2125
Thumbs up
Yeah. That`s my way now and forewer.... and i like it
Btw. I have a good set-up for that.
Rc Nitro: Do you want one?
Old 12-05-2002, 05:53 AM   #2126
RC Nitro's Avatar
YEs I think I do. What is the cost on that? Have to clear the funds with the "Big Boss" ie wife. LOL
Old 12-05-2002, 07:20 AM   #2127
Post
Ok then. Go to MyTSN.com and set-up section and you`ll find my newest set-up up there (i made it today) It`s named solid part test or something...
I made some changes after i look my set-up sheet, sorry
Old 12-05-2002, 01:51 PM   #2128
stormperson's Avatar
Send a message via AIM to stormperson
i am currently running the c-hub front and pivot rear on my evo 2, and i realized that with the stock setting for the camber links and all, that the suspenion has camber change, but its positive. i think this might explain why my car bucks up and down in the high speed, high load corners, where the front suspenion would compress, also the outside edge of my tire is kinda ripped up (not chunked as much though, more like it was ridding on it), all of this would lead me to assume that its the positive camber change that is causing this, how do i make it so its negative camber change? (ie, the more the suspenion compresses the more camber)
any help would be great! thanks!
stormperson is offline   Reply With Quote
Old 12-05-2002, 02:43 PM   #2129
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
I belive that a shorter and higher camber link would solve this problem very quickly. I do not know if i am totally correct. I would make a guess that this should help fix it.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 12-05-2002, 03:05 PM   #2130
higher overall, or just on one side? right now its on the bottom middle on the inside, and i have one shim under the ballstud on the outside. so i should move to the upper outside and maybe add a shim under the ballstud?
