Old 10-23-2001, 01:05 AM   #196
Usagi's Avatar
Deleted and never posting in the thread again!
Usagi is offline   Reply With Quote
Old 10-23-2001, 04:15 AM   #197
David Galdo's Avatar
Trader Rating: 15 (100%+)
Send a message via ICQ to David Galdo Send a message via AIM to David Galdo Send a message via MSN to David Galdo Send a message via Yahoo to David Galdo
Usagi: I am apologizing again for the third time. Try to get past this if you can, it seems that you can't and I am sorry that it has burdened so much.
Hot Bodies | HPI Racing | HPI TV | Speedzone USA | Team Epic | Trinity | TRC
V-Dezign 4.0
David Galdo is offline   Reply With Quote
Old 10-23-2001, 04:19 AM   #198
Originally posted by dtm
No 'Japan edition' chassis yet... I'm not sure if I want it unless they switch the side where the batteries are placed!
Why are you concerned with the side the batteries are placed on? Just curious.
V-Dezign 4.0
Old 10-23-2001, 05:25 AM   #199
I have updated my setup sheet on my site. There is a reference to the position of the front upper arm. Until Team XRAY provides us with a new setup sheet I have determined that 1 is the position nearest the chassis, 2 is the position most you have now, and 3 is the highest position. There is a front and rear holder so I labeled it with F+R, therefore, 1+1 is my setting. I have used 1+3 and it yielded excellent steer-in results and stability.
L8r.
Stay cool USAGI!
V-Dezign 4.0
Old 10-23-2001, 05:29 AM   #200
dtm
dtm's Avatar
Send a message via ICQ to dtm
The likes of the TC3 and MR4TC have the benefit of having the weight of the motor to balance out the weight of the batteries. The Xray does not because the motor can is on the centre line.
The weight of the end housing is also adding to the weight of the batteries. If the electronics are on the left hand side you can benefit from having neater wiring and a slightly better weight distribution. You would still have to add a fair amount of weight especially when using smaller components.
Actually while I'm typing this I've figured that if Xray does this right and push the batteries further into the centreline of the car then it could work! Maybe, I'm talking my way out of my original descision
dtm is offline   Reply With Quote
Old 10-23-2001, 05:37 AM   #201
Positioning the batteries dead center or nearer to it would benefit us. It would mean a narrower chassis and lower overall weight.
V-Dezign 4.0
Old 10-23-2001, 08:48 AM   #202
Usagi's Avatar
Take your on advice son..........
Old 10-23-2001, 09:34 AM   #203
Ignorance still prevails. I have replied with apologies that you have not accepted. I will simply look past your post since they have had little substance of worth and lack proper usage of grammer and vocabulary. We all make mistakes and I am sorry the issue has ballooned beyond my post dated 10-19-2001 06:24 AM when I first acknowlegded my error in understanding your post.
Fat clumbsy fingers is not an excuse for mis-spelling words, this site has provided a spell check function. I also make spellings errors but in most cases reflect upon my comments for proper usage of words. I also reflect upon my intent and meaning of the message so that the audience understands. Spelling is not your only fault. It is your intellect that prevents you to let this die and it is beyond your capability to understand that you were ahead.
This all began when I felt that the tone of your message was condescending. I guess that is true. I am 31 years old and I am not your SON.
I tried to mend things by stepping back and observing the big picture with respect to you. Go ahead and delete all your past errors and attacks. I will leave my posts for others to observe as I feel that my actions were just. I made a mistake and I tried to repair it. It is your loss.
Good day and good luck to you Usagi. Come back when you are good and ready to.
V-Dezign 4.0
Old 10-23-2001, 09:54 AM   #204
Regional Moderator
Darkseid's Avatar
dtm: I raised the same issues on this thread when i first saw the new chassis for the Xray. Heck me and you almost said the exact same things. Most of the people just blew me off, but it is good to see someone else raise the question. Maybe you'll get a better response.
I still don't see how it could work unless the moved the battery in as far as posible. Left as is in the pics we have seen, I don't see how you could ever balance the chassis. As I said here a long time ago, its hard enough to balance the Yokomo, Associated and now Losi style chassis with all the electronics opposite the battery. Especially with heavier 3000 cells and lighter electronics. So I figured it would be near impossible to do with the motor in a neutral position like it is on the Xray. Some one suggest that you just add weight to the electronics side, but imagine how much you would have to add if cars that have the motor fully opposite the battery still aren't balanced!
Finally someone just said "I'm sure Xray knows what their doing", so I just left it at that.........well until now of course.
TLR 22...Tamiya F104...
Old 10-23-2001, 09:58 AM   #205
dtm
dtm's Avatar
Usagi: Everyone has read your post about being clumsy with your fingers.... also everyone has read RCCadet's apology, that should have been enough to settle the matter.
I think you are being a little childish on this one. I don't know you nor do I know RCCadet... but from a third party point of view... I think you should lighten up a bit!
Old 10-23-2001, 10:01 AM   #206
dtm
dtm's Avatar
Darkside- Maybe Xray will also come out with a 'LEAD' half chassis to balance out the other side!
Old 10-23-2001, 10:02 AM   #207
Double post, that was odd. Deleting this post.
V-Dezign 4.0
Old 10-23-2001, 10:03 AM   #208
Regional Moderator
Darkseid's Avatar
dtm: thats a good one!!! ...LOL!
I just thought that cars like the Xray and Corally have excellent battery mounting positions, so why change it?
Old 10-23-2001, 10:04 AM   #209
In reference to adding weight to counter the battery weight, I had to with my TC3. I was pushing badly and I was forced to add 14 grams opposite the battery. My electronics are micro in size and I can see the XRAY sharing the same characteristics.
V-Dezign 4.0
Old 10-23-2001, 10:06 AM   #210
Regional Moderator
Darkseid's Avatar
RCCadet: but, think how much you would have to add if the TC3's motor was right down the middle of the chassis! You would have to replace nearly all the motors weight on that side!
