Old 11-02-2002, 09:14 PM   #2041
littledog's Avatar
R/C Tech Charter Subscriber
Oh!They have actualy come off back order now?I made an order for them bout 4weeks ago for someone in the shop and was told then that they had to pass through customes.And I still wait for them.
littledog is offline   Reply With Quote
Old 11-03-2002, 09:42 AM   #2042
mike5009's Avatar
Send a message via AIM to mike5009
Originally posted by rcfiend
I just purchased the C-hub conversion kit, f/r. Anyone have a decent setup for asphalt/rubber tires. The track is medium sized and high bite. I applied the standard setup that came with the kit, is this a good place to start. Oh by the way, I'll be running mod with this setup.
Thx.
rcfriend the set up that comes with the c-hub kit is a very good starting point for carpet. but real close for asphault. two thing you'll have to change depending on the track condidtion. one droop you'll have to put a little sag in the arms a little more if the track is bumpy. two change the dampning again this is more to the track and your driving style. but just remember to keep a very nuetral feel in the car and you'll be fast.
mike
mike5009 is offline   Reply With Quote
Old 11-06-2002, 08:23 PM   #2043
RandyB's Avatar
Rob love racing an xray should have known hey I just ordered mine know any body who's looking for a pair of tc3's??
RandyB is offline   Reply With Quote
Old 11-06-2002, 08:42 PM   #2044
hey guys, ran my evo2 on carpet tonight. i tryed 55wt oil up front with assoc. purple springs and 50wt w/assoc. red in rear. it seemed to work well on the pretty open course, but i like the front end a little more aggresive. i stood up the front shocks and helped a little. i tryed loosening the center onway and made the rear end rotate a little to much. any comments on what i should try next. running completly stock evo2.
Jarrod Langlois is offline   Reply With Quote
Old 11-06-2002, 09:16 PM   #2045
mike5009's Avatar
spaz you running stock or mod, and what compound tires
Old 11-06-2002, 10:47 PM   #2046
littledog's Avatar
I've learned the hard way that the AE springs do not work very well in the rear of the car.Plus they are too short for the new shocks on the evo2.And did you use the externaly ajustable piston or the fixed piston.If you used the fixed piston which ones did you use?
Old 11-07-2002, 04:40 AM   #2047
im running stock, foams purp rear and double purple up front. the associated springs seemed a little short but i still need to buy some xray springs, so theyll have to do for now. thanks for any help.
Old 11-07-2002, 07:16 PM   #2048
AMGRacer's Avatar
I am having a small problem with the rear springs of my XRAY. Basically they are too tight in the spring retainers (both top and bottom) and basically prevent the arms from falling all the way down to the droop stops. This is preventing me from dialling in as much droop as I would like. Anybody else encounter this?
AMGRacer is offline   Reply With Quote
Old 11-07-2002, 08:20 PM   #2049
mike5009's Avatar
spaz switch to plaid front and purple assco spings front and rear match the dampnig to your driving style hard braking drifting or floating. set the droop to where the spring is just off the adjusting coller. this should get you going also dont forget radio adjustments!!!!!!!! big time over looked adjusting tool
Old 11-07-2002, 09:04 PM   #2050
re springs being too tight you could use a dremel and lightly sand the insides of the springs to get rid of any excess paint so that they come off the spring retainer.
How much droop are you running? to need that much dropp your car would feel very lazy, i would think that it would not change directions easily. Even at Kambah which is very bumpy my droop screws are virtually backed out and i dont think the springs come off their pirches.
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 11-08-2002, 05:03 AM   #2051
stormperson's Avatar
Send a message via AIM to stormperson
thats why i used AE spings! lol. jk, but i do use AE springs since i already have alot of them. i have found that on carpet (since i normally run my tires low) that i am on the lower set of holes on the rear tower, with the collars towards the top, and in the front (i wish they made a tower for the fron similar to the back one...) i run the colars near the bottom.
i have yet to have any problems with binding springs, and the AE ones are almost the exact same size as the stock silver ones, or at least the xray springs, i dont know about the serpent ones.
stormperson is offline   Reply With Quote
Old 11-08-2002, 08:08 AM   #2052
RBLove's Avatar
Trader Rating: 72 (100%+)
RandyB,
I've only been running the car for a couple of weeks, but have had great success. It is a GREAT car.
I don't know anyone looking right now.
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 11-08-2002, 11:47 AM   #2053
thanks mike and others, i was thinking of increasing rear droop a little. i will try the purple springs in the rear, and i was planning on getting a new set of foams in a couple weeks so i will either go for plaids or purple oranges. i have no experiece with plaids i have used purple oranges though and they are close to plaids. i was messing around with adjustments on the radio a little, i run just enough dule rate so that my car isnt very twitchy, i like to be smooth with the steering. im still getting used to my digital ko servo as well. thanks for the comments.
Old 11-08-2002, 12:53 PM   #2054
RandyB's Avatar
yeah, i drove a guy's car here in toledo and I thought it wwas unbeleivable it brings a whole new meaning to touring car my opion the car just excells in all departments
Old 11-12-2002, 11:27 AM   #2055
hey guys i was just wondering if on the evo2, do you guys go by the instructions and build the shocks with no rebound. i have always built my touring car shocks with rebound. its a pain to get just the right amount of oil in the shocks so you have no rebound. thanks
