Old 10-01-2002, 07:24 PM   #1801
stormperson's Avatar
Send a message via AIM to stormperson
a few weeks ago, lol. we race on sundays starting at noon, racing is free (yes free, no strings attached) and we support personal transponders, and run j-lap software. also there is a fully stocked (no xray parts thoug ) hobby shop, but alot of other stuff. so far we run a stock, 19t pro stock, and mod class. and a novice, but i dont think that applies to you.
stormperson is offline   Reply With Quote
Old 10-01-2002, 08:09 PM   #1802
Kenneth Tan's Avatar
Originally posted by STLNLST
TO ALL EVO DRIVER'S- Have you guys tried running your packs all to one side yet? The reason why I'm asking is because Xray offered this option but I haven't seen anyone using it yet. Is it because all Evo owners had the original T1 and their packs are already split or is the split position the better overall feel? Any info that you guys can give me will be greatly appreciated.
The problem with the '6 a side' configuration is that the motor is still placed in the rear center of the car. Cars like the MR-4 and TC3 have all the electronics, including the motor, on one side of the chassis and the batteries on the other side. To balance the '6 a side' batteries on the T1, you would probably need a lot of weight on the electronics side.... Comments?
Kenneth Tan is offline   Reply With Quote
Old 10-01-2002, 09:30 PM   #1803
STLNLST's Avatar
Trader Rating: 21 (100%+)
I kind of figured that but wasn't too sure. I just needed to hear it from people who have experience with the car. I guess It's time to make a few saddle packs.
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 10-01-2002, 09:33 PM   #1804
Wolf's Avatar
Send a message via ICQ to Wolf
If you use 6x1 configuration, forget about the balance. Instead, take advantage of the different weight distribution. It make more sense this way. Otherwise, why not use 3x2 battery to achive a better balance.
Wolf is offline   Reply With Quote
Old 10-02-2002, 05:06 AM   #1805
dtm
dtm's Avatar
Send a message via ICQ to dtm
Because the 6x1 pack will give you more 'front' weight distribution.......
dtm is offline   Reply With Quote
Old 10-02-2002, 05:13 AM   #1806
dtm
dtm's Avatar
Look at the stack of weights required on this 6x1 Xray!!!
Picture as found on the TSN site.
Old 10-02-2002, 05:36 AM   #1807
STLNLST's Avatar
it looks as if it's better to keep the packs 3+3 form. That sure is alot of weight required on the right side of that car.
Old 10-02-2002, 05:47 AM   #1808
Wolf's Avatar
Then, how about 3x2 battery in this way? 3 in the upper left corner, 3 in the lower right corner
We got many slots to try.
Old 10-02-2002, 06:20 AM   #1809
mike5009's Avatar
Send a message via AIM to mike5009
wolf that battery set up is good for your low turn mods as it wiil set your car entering the corner and it will rotate pretty fast from the center out for stock it just scub to much speed through the corners
mike
if your not drive a x-ray you should just go home
mike5009 is offline   Reply With Quote
Old 10-02-2002, 08:57 AM   #1810
Default I need a good starter set-up
Hey guys does anyone have a good starter set-up for the following:
Xray EVO2 with C-Hub - Running in Mod Foam Carpet
I am kinda shooting in the dark right now and have not been to sucessful with my attempts. Any help would be appreciated. Thanks!
Shawn
simulatedwood is offline   Reply With Quote
Old 10-02-2002, 09:09 AM   #1811
GregH's Avatar
Send a message via AIM to GregH
simulatedwood, can you post were the car is now, set-up wise?? Then we can go from there and give better suggestions on what to change next.
GregH is offline   Reply With Quote
Old 10-02-2002, 09:11 AM   #1812
GregH's Avatar
I should have read your post alittle closer. I'm not currently running the c-hubs as of yet.
Old 10-02-2002, 09:38 AM   #1813
mike5009's Avatar
simulatedwood go to the stock set up add weight to the left and right rear stand the shocks up in the rear to provide the nessisary rear traction. now the c-hub provides a ton of steering entering and from the center out so go 2 holes rear and one hole in front with the shocks. try that and if the car rotates throuhg the corners to fast fine tune the front and rear droop. go with white springs at first then try the next hardest after that to tune to your driving style this is a good nuetral starting point for tires i use speedmind 28mm 45shore front 40 or 42 rear depending on how much traction the track has hope this gets you going in the right direction good luck
mike
Old 10-02-2002, 01:47 PM   #1814
stormperson, ill have to plan a trip down there before the end of october then. i think ill bring down my xray, is there many of those that run there. im going to the track tonight to work on my set up so i should probaly have a pretty decent carpet set up by then.
of course not, hehe
Jarrod Langlois is offline   Reply With Quote
Old 10-02-2002, 01:52 PM   #1815
With the small & light electronics being used right now, the weight was "disguised" as an ESC, servo, & receiver....so the weight must stick it's ugly head out in the form of real weight.
Don't let your eyes fool you....just because weight is added, look at the reasons. If anything, having the small & light electronics, now you have that many more tuning options and placing the weight exactly where the car needs it....use this to your advantage....don't listen to the "mind's eye" ...listen to your stop watch! hehe
acloco is offline   Reply With Quote
