Old 09-25-2002, 08:26 AM   #1741
GregH's Avatar
Send a message via AIM to GregH
RCCadet, let us know how it works. I'd like to know if it's better or worse.
GregH is offline   Reply With Quote
Old 09-25-2002, 08:46 AM   #1742
RC Nitro's Avatar
Greg: You caught me in a hurry Had someone waiting on me and I did an incomplete type I use -10% exp as I tend to oversteer sometimes. Was at 35% Goal is 0%, Radio is a 3PJS. Use delay on my servo also (S9410) 10% I think, at work. Use dual rate on the steering. What I meat was I has the dualrate is at 15% below full or 85% C-Hub gives you a lot of steering. I have just started noticing the scrub on the steering. I have noticed as you get better you notice more things on the car that change. TidewaterRC track is an oval with the TC doing the infield in addition to the oval. The transistion from the banking to flat and tuning 180 is tough. I also like a car loose, but the rear C-Hub was to lose for me. Like the car was at -2 camber or cold tires and no tire tack. I could drive the car, but I did not like it. To much oversteer. Hate a tight car!!!!!!
RC Nitro is offline   Reply With Quote
Old 09-25-2002, 09:00 AM   #1743
GregH's Avatar
John, I understand now, thanks. Have you had any problems with the lower arms?
Old 09-25-2002, 09:13 AM   #1744
GregH's Avatar
Sorry, I should be alittle more spicific. dtm posted some pics a ways back of the c-hub front lower arms. Shows some damage were the hole is. Have you had any problems?
Old 09-25-2002, 09:13 AM   #1745
RC Nitro's Avatar
Yes Greg. I cracked the right front one. Bought 3 from Buster before he left. They are $3.75 ea. Them hard plywood walls we have do not forgive you! dtm has also had problems with his arms.
Old 09-25-2002, 09:20 AM   #1746
GregH's Avatar
Have you tried putting a aluminum screw in the hole to help support the arm? This should stop the arm from colapsing.
Old 09-25-2002, 09:24 AM   #1747
RC Nitro's Avatar
Greg, broke mine in the same area. But not the hole, cracked the web 90 degrees to the hole. I need to try the screw and reinforce this area. I think the arm takes a hard hit on the wall
Old 09-25-2002, 10:40 AM   #1748
dtm
dtm's Avatar
Send a message via ICQ to dtm
Default #rd Front Body Mount
Has anyone else tried to put a 3rd front body mount post off the C hub front shock tower? Don't know how legal it is for races?? But try it....you'll love it!
dtm is offline   Reply With Quote
Old 09-25-2002, 10:46 AM   #1749
GregH's Avatar
dtm, does that come with the c-hub kit or is a dtm made mod?
Old 09-25-2002, 10:48 AM   #1750
dtm
dtm's Avatar
haha......no mention of the use for those 2 additional holes in the instructions....so I figured I'll make use of a spare body post!
Old 09-25-2002, 10:55 AM   #1751
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: #rd Front Body Mount
Oh MRT MRT !! how do you like the MRT ??
Manticore is offline   Reply With Quote
Old 09-25-2002, 01:17 PM   #1752
Thumbs up
I do have a third body post! Yes great. Does make the body a lot more stable.
Arnoud is offline   Reply With Quote
Old 09-25-2002, 01:54 PM   #1753
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
The locked front should work like a one way of sorts. It will have the roll and pull of the one way. with more initial turn in.
I run my diffs at 1 1/4 turn out on foam carpet. Lets car grab well all over the track. I use a dual rate of 55 percent as well with that
I just dont like the steering in my cars so i am not going to the c-hub.
Thanx for the measurements as well guys. just wanted to know because i was doing some geometry of shocks type things with the rear swisscheese tower.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 09-25-2002, 02:41 PM   #1754
On Trinity Tech Talk, there's a good thread about locked front diffs. Seems like most guys who have tried them say the car pushes more on corner entry, but on corner exit the front end really bites hard, car launches better and has more steering.
That's in XXXS's and TC3's, don't see why the XRay would respond any differently.
JeffC is offline   Reply With Quote
Old 09-25-2002, 08:05 PM   #1755
IRS is looking at building an aftermarket solid front axle for the XRAY touring car. They already make this part for the TC3 and have looked at it for the Losi. Any interest?
davidl is offline   Reply With Quote
