Like Tree3Likes
Xray T1
Old 08-30-2002, 07:24 AM
  #1576
David Galdo's Avatar
Trader Rating: 15 (100%+)
The stock (silver) springs are how many lbs? I thought I read about it some where in this thread but can't find it.
Car went together perfectly.
David Galdo is offline
Old 08-30-2002, 07:41 AM
  #1577
Dragon Slayer's Avatar
RCCadet....Hey bro...dont be a stranger...come by the Shreveport site and say hi once in awhile...how do you like the XRAY?
Dragon Slayer is offline
Old 08-30-2002, 07:55 AM
  #1578
I finished building the kit yesterday....I will try to make it out to a local track very soon and let you know.
Nothing happens in the thread anymore......hopefully more happens at the track.....already lost one carpet track, don't wan't to see another go in this area.
Old 08-30-2002, 10:39 AM
  #1579
HYDRAMATIC99's Avatar
Originally posted by stormperson
quick question: I got a belt tensioner, but i am not 100% sure how to install it. i currently have it set up on drivers right, on the rear right bulkhead, and its going through the hole near where the layshaft is (right infront of it, and a little below it i think), and it seems to be okay there, but is this the correct position for it? any help would be great thanks!
Here is a pic where I run mine.
HYDRAMATIC99 is offline
Old 08-30-2002, 01:30 PM
  #1580
Shop Owner
nnick's Avatar
The kit silver is the same as white shown at the picture
Have Fun
Nick
nnick is offline
Old 08-30-2002, 04:04 PM
  #1581
RCCadet.....i agree about he thread...ever since summer arrived. no one comes out to race....none of the Longview locals ever showed up??????.....I think once winter gets here it will pick back up.What fun is smack talk if you're not doin' it on the track first......lolol.....guess i could just make up some crap........
Old 08-30-2002, 04:10 PM
  #1582
Just keep that carpet track alive and kicking!!
Old 08-30-2002, 04:13 PM
  #1583
I think I am hooked on the EVO2, I am buying one as soon as I can. do you guys have a good setup for high trac ashpult.(socalraceway)? and for carpet how do I need to change the setup to get a starting point?
Thanks.
teamAE is offline
Old 08-30-2002, 07:15 PM
  #1584
stormperson's Avatar
okay good, i am running the tensioner in the right place, lol.
i found though that it is too far to the driver's right, thus i placed a few shims to space it closer to the center, since the left of the belt was rubbing on the flange of the bearing in the stock position (unshimmed).
also i currently have figured out a nice carpet set up with the c-hub conversion (up front only though), incase anyone is interested, i have yet to race it, but it handles very well and in practice i have quite a bit of speed in the turns compaired to the other guys.
stormperson is offline
Old 08-30-2002, 08:50 PM
  #1585
Team EAM
Trader Rating: 79 (100%+)
I am currently running a little conserivativly (sp, lol). I have been runnning tc3's for a little while now, so i might be slightly tight, but it didnt seem to affect how easily the drivetrain rotated when i tried to spin it, which wasnt that much, which leads me up to a question:
-how free are the draintrains when everything is broken in? my tc3 (with foam tires trued almost down to the rim) was able to spin for at least 5 seconds, and will rubber tires it was more like 15-20. i cant even get one rotation with foam tires, and albeit i have only run a pack or two.... but i noticed that the topshaft was kinda tight, but the entire rest of the drivetrain was very smooth, has anyone else noticed this?
-also is there any accurate way of measing the degree of the front sway bar? since its taking me a few tried to make sure both sides are even. and i would like a accurate way to measure how much angle i am actually running.
thanks!
The layshaft should spin very free in the bulkheads. The problem you are having is the bearing in the plasctic cup on the left side of the car (opposite the spur) is not seated all the way in the plastic cup. Take the left bulkhead off and check that bearing. It should fit all the way down in the cup. I had to get a nut driver and carefully persuade (tap) it in all the way.
After one week of racing on mine the wheels would spin about 5 revolutions before stopping. It was very free.
eric a
EAMotorsports is offline
Old 08-30-2002, 09:10 PM
  #1586
Talking XRay Springs, all the info needed
For those of you wanting to know everything about the new springs but do not have access to the MyTSN VIP Room:
New Spring set #308390 XRAY Selected Ultimate Racing Springs (24)
Ultimate high-performance racing springs, which provide precision tuning for your XRAY model racing car! Developed from extensive testing and racing experience, these racing springs were designed and precision-crafted to have a unique spring characteristic. The XRAY spring sets were designed to give you an optimum range of choices to fine tune your car. Each spring set contains four identically-matched springs, and are designed to work with the new XRAY shock absorbers. All four springs in a set are the same length, and all springs are color-coded for easy identification.
#308393 XRAY Spring-Set D=1.4 (14 LB) Yellow - Super-Soft (4)
#308394 XRAY Spring-Set D=1.5 (17.5 LB) White - Soft (4)
#308395 XRAY Spring-Set D=1.6 (22.5 LB) Blue - Soft-Medium (4)
#308396 XRAY Spring-Set D=1.7 (28 LB) Violet - Medium (4)
#308397 XRAY Spring-Set D=1.8 (33 LB) Purple - Medium-Hard (4)
#308393 XRAY Spring-Set D=1.9 (38 LB) Red - Hard 4)
Additional springs for fine tuning:
#308384 XRAY Spring-Set D=1.5 (15 LB) Blue-Green (4)
#308385 XRAY Spring-Set D=1.6 (20 LB) Light-Blue (4)
#308386 XRAY Spring-Set D=1.7 (25 LB) Dark-Blue (4)
#308387 XRAY Spring-Set D=1.8 (30 LB) Light-Purple (4)
#308388 XRAY Spring-Set D=1.9 (35 LB) Light-Red (4)
Arnoud is offline
Old 08-31-2002, 05:49 AM
  #1587
i dont want to sound offensive here or anything, but all of the springs you would run on carpet are "girly" colors. i would of liked to see a neon green, blue, yellow, etc instead of violet, or purple, which if you look at these colors in the manual one even looks like a pastelish pink, infact the colors of the three hardest of the original evo 2 springs looked liked they were copied from the Easter M&M's.
anyone else sorta possibly see where i am coming from here?
anyway, in the meantime i have been using TC3 springs, since i couldnt find a xray spring set, and they fit fine, and are actually the exact same size as the xray springs, or at least very close to.
Old 08-31-2002, 09:06 AM
  #1588
Default Colors
Neon is way to 80's
Winning with these colors will even more show how masculin you are!
Arnoud is offline
Old 08-31-2002, 12:36 PM
  #1589
lol, maybe i should of said "flourescent". but think about it, when was the last time you saw a paintjob with these colors? the spring colors dont go with anypaint job, which i know is not a huge thing, but if i spend hours and hours painting a body, and then to have the springs stick out like a sore thumb...
Old 09-02-2002, 06:37 AM
  #1590
dtm
dtm's Avatar
Easy....just spray your springs the same colour as your shell!
dtm is offline
