LOSI XXX-S, Tips and Tricks, Open Mod, etc >
Like Tree5Likes
Old 01-05-2018, 08:44 AM
  #1066
Alexv2024's Avatar
I got a xxx-s off a friend of mine and of course the yellow belt was disintegrated. I figured it was just a shelf queen until I googled xxx-s belt and found the ebay listing. Didn't like the shorter tooth count though and the "remove tensioner" part.
I also picked up a 22-4 2.0 last week and when I took it apart to clean it I googled the numbers on the rear belt "S3M 384" which is a standard size. S3M is the tooth profile and is a 3mm pitch. The other two belts are S2M or a 2mm pitch. Also its about 4.3-4.3mm wide.
The XXXS shares the 3mm size but is about 3.6mm wide. Stock length seems to be 250mm/750 tooth and losi had the optional 259 tooth or 777mm length.
I bought two belts from beltzoom dot com a 750mm 250t and a 771mm 257t belt to test fit. They are a slight wider 6mm belt, but we'll see their exact width measurements. My 22-4 gears are 5.65mm wide and I didn't measure the xxx-s when it was apart.
If those are too wide I'll try some belts from polybelt dot com they have 4 and 5mm wide belts to try out in 250t and 270t lengths.
Just thought I'd experiment and let the community know there are lots of belt options still! I'll figure out later what to do with this thing, probably get some Datsun/nissan bodys to match my real cars. Donno but it'll be an interesting experiment! Im surprised you guys still have XXXS's, I ran one for a while back when they were newish but raced mainly off road back then.
Alexv2024 is offline
Old 01-05-2018, 02:37 PM
  #1067
Kajman's Avatar
3M makes belt which suits, just have to make tensioner move few mm more up, easy dremel work. It is 4mm , 753T. Costs here in Poland 2.5$.
Kajman is offline
Old 01-05-2018, 03:40 PM
  #1068
loosewheel's Avatar
Do you have a link to these?
loosewheel is offline
Old 01-06-2018, 05:07 PM
  #1069
Alexv2024's Avatar
Huh I haven't seen that in my searching but Im here in the states. All I've really seen is the belt on ebay.
The xxx-4 long belt conversion said with the additional belt wrap you can run less tension freeing up the drive train though, so thats what I'm going for if the long belt works with the xxxs.
We'll see when my belts get here
Old 01-07-2018, 05:25 AM
  #1070
skater-deez1's Avatar
Trader Rating: 79 (100%+)
Thumbs up
The hd belt and tensioner with 2 41t pulleys really helps free things up. The 41t pulleys being a little smaller helps the belt from rubbing on the belt cover.
mariob62 likes this.
skater-deez1 is offline
Old 10-20-2022, 10:31 PM
  #1071
Originally Posted by tmail55
In VTA the XXX-S holds it's own against the modern carbon chassis cars. Make sure it rolls smooth and easily. (set belt tension correct)
Gearing option with the XXX-S, get two diff gear sets and use the overdrive gear front and rear
Hi:
Does anybody know the part numbers for the diff gear set? Or where to buy them?
Thanks in advance
F1jet_ is offline
Old 10-20-2022, 11:50 PM
  #1072
Kajman's Avatar
LOSA3211
Kajman is offline
Old 10-26-2022, 03:47 PM
  #1073
LOSA3211
Thanks, but that part number appears to be pulleys for the ball diff.
Does anybody even know if Losi made a gear diff?
F1jet_ is offline
Old 10-26-2022, 09:14 PM
  #1074
Fast XXXS's Avatar
Trader Rating: 51 (100%+)
No gear Diff for the XXXS.
Fast XXXS is offline
Old 10-27-2022, 04:30 PM
  #1075
Thanks for feedback
F1jet_ is offline
Old 04-02-2023, 07:47 PM
  #1076
emreyzc53's Avatar
Losi xxx-s have GEAR DIFF, Please look horizon hobby tx-01 (losi xxx-s) series.
But I don't now part number or how can I find this gear diff.
I've written many times but haven't received a response from Losi and Horizon Hobby.
emreyzc53 is offline
Old 04-06-2023, 02:59 PM
  #1077
emreyzc53's Avatar
It's have but I can't find anywhere.. You can check horizon Team Losi TX-01 (Losi xxx-s)
Old 04-11-2023, 01:23 AM
  #1078
Wazza22's Avatar
Trader Rating: 29 (100%+)
Hey XXX-S fans!
I am on the lookout for a Spur Gear Adaptor so I can run generic spurs. Can anyone help?
Cheers
Wazza22 is offline
Old 04-11-2023, 10:41 AM
  #1079
emreyzc53's Avatar
Hi, I use fastrax spur and adaptor. I try xray spur and it's fit.
Old 04-11-2023, 02:52 PM
  #1080
Wazza22's Avatar
Are any about? I have not come across any.
Cheers
Wazza22 is offline
