LOSI XXX-S, Tips and Tricks, Open Mod, etc >
Like Tree5Likes
Old 06-14-2015, 06:57 PM
  #931
how do you mod the motor plate
quickta is online now
Old 06-15-2015, 09:22 AM
  #932
Instead of using screw holes in the motor that are directly opposite of each other as is the norm, you can take one screw out of the motor and move the motor further out and away from the spur gear and then drill another hole to utilize another screw hole in the motor that is not opposite, but actually closer together. I hope this makes sense. I am not the best at explaining things and I don't have a photo of it.
I made a crude image to explain it. The approximate area the new hole would be made is shown in red. I hope this helps.
microed is offline
Old 06-19-2015, 09:54 AM
  #933
loosewheel's Avatar
Doesn't appear all motors have an extra hole in that location? I'm a bit confused?
loosewheel is offline
Old 06-22-2015, 06:48 PM
  #934
Most brushed motors don't, but most brushless motors have the extra holes.
microed is offline
Old 06-22-2015, 07:32 PM
  #935
got a new belt from jhwnissan, and the belt looks good, but having trouble mounting it, has any one run into this before, got an original belt tension off of eBay and original pulley, but still not even close to getting it mounted, picture shows full tension on the belt
Attached Thumbnails LOSI XXX-S, Tips and Tricks, Open Mod, etc-xxx-s-belt.jpg   LOSI XXX-S, Tips and Tricks, Open Mod, etc-xxx-s-belt-2-.jpg
Old 06-23-2015, 09:24 PM
  #936
Anyone have any ideas, do i need a longer belt
Old 06-24-2015, 07:23 AM
  #937
loosewheel's Avatar
It should have come with instructions on modifying the tensioner slot. They are a tight fit, but they do stretch after a little running.
Old 06-24-2015, 09:19 AM
  #938
There is no more stretch to the belt, that's as far as it will go down , motifing the tension slot will not help if it want go down to it
Old 06-24-2015, 12:37 PM
  #939
Originally Posted by jhwnissan
Got it. Ships today.
I feel a little renewed vigor seeing people still racing. Maybe I won't quit but just adjust my belt selling to seasonally. When do most of you race? Here in Michigan, it was always fall through winter because of the weather. When do you most think about buying for your race seasons?
Sent you an email for belts. Spur adapter would be nice for me also. Where are you guys getting overdrive pulleys. Parts on eBay seem limited
gordonmoney is offline
Old 06-24-2015, 01:35 PM
  #940
sent a pm to you
Old 06-24-2015, 07:00 PM
  #941
Okay, I'll take a stab at it. Could be several reasons. If you have the over sized diff pulleys and run the spur gear that has the larger belt pulley on it, well that could be a possible cause. Something in your drive train is out of the ordinary as in maybe not stock, but an option part.
microed is offline
Old 06-24-2015, 09:10 PM
  #942
has the original white pulleys and the red 86 losi spur gear, every thing is stock
Old 06-24-2015, 09:56 PM
  #943
QuickTA
I ran into the same problem. Could not get it to fit either with stock spur gear or spur gear adapter. No room to modify the slot for the screw. As you probably noticed. The fix is to modify the tension arm extending the part the screw fits.
Or buy another belt (I did) from a guy in New York it just fits w/o modfication
Anyone interested in a Losi XXX-S G+? mine is available lotta spares
Watchman is offline
Old 06-25-2015, 04:28 AM
  #944
Originally Posted by Watchman
QuickTA
do you have a picture of the modified tension arm that you did
Old 06-25-2015, 05:07 AM
  #945
Quickta...
Wish I did, but I took the easy way out! Main reason is that I did not have a piece of aluminum big enough or thin enough to cut one out. Need to extend the arm where the 2 factory screw holes are to make it longer and add hole for new screw.
May 8, I got a belt from Scott Jaster ([email protected]) cost 23.49. Do not know if he has anymore.
Watchman is offline
