LOSI XXX-S, Tips and Tricks, Open Mod, etc >
Like Tree5Likes
Old 12-14-2014, 03:42 PM
  #766
skater-deez1's Avatar
Trader Rating: 79 (100%+)
Thumbs up
Originally Posted by fathead
Would the aftermarket belts benefit from a bigger pulley or smaller pulley?, I thought I read something about a mod needed with them.
I'm thinking of something a bit more exotic than just straight delrin is all, even with the stock 23T pulley there is very little meat left for the spur screws to screw into, so was thinking about doing alumiunium 'backplate' with delrin pulley fitted to that, would allow easy changing of the pulley size.
A smaller pulley would eliminate the need for the mod!
skater-deez1 is offline
Old 12-14-2014, 03:43 PM
  #767
fathead's Avatar
1 tooth less?
fathead is offline
Old 12-14-2014, 03:44 PM
  #768
nf_ekt's Avatar
Trader Rating: 115 (100%+)
It's alive!
Make it trick, basic, whatever. Just glad these are in the works and the belts are being made as well.
nf_ekt is offline
Old 12-14-2014, 03:49 PM
  #769
Thumbs up
1 tooth less?
1 or 2 would be fine. 2 would probably put it right in the wheelhouse. The jhnissan belts have worked fine for me with just using the 41t pulleys.
Old 12-14-2014, 03:52 PM
  #770
Exclamation
Most of the belts that came out after Josh made his are the standard size but then they could be run loose at the regular tension point which wouldn't be a bad thing either. Anyways thanks for the update!!!
Old 12-15-2014, 01:05 AM
  #771
fathead's Avatar
Sweet, definitely need to do the delrin/alloy combo for smaller number of teeth I think, also finished the first proto piece, ready to send tomorrow for test fit.
Damn the HDR pic really shows up any scraggly bits, hard to get a really clean finish on the very top of the teeth, and it's realllllly hard to cut off because its wafer thin and flexible, rest of the tooth is clean as a whistle just that top edge.
/edit big mark in the top is from a mishap I had when I didn't have the blank held good enough and it flung it out, broke my 1.6mm bit too!
fathead is offline
Old 12-15-2014, 03:27 AM
  #772
Thumbs up
Thumbs up man,looks great!
Old 12-15-2014, 11:29 AM
  #773
bigfatslob's Avatar
Absolutely the work of an artisan. Aluminum & Delrin combo is the way to go.
bigfatslob is offline
Old 12-15-2014, 11:32 AM
  #774
bigfatslob's Avatar
And those Ebay belts from Bulgaria are nice and strong but a bit on the short side, in fact almost the identical length as Josh's belts, so a tooth off might be great as Bulgarian & Josh's belts are the strongest out there at the moment.
Old 12-15-2014, 11:33 AM
  #775
fathead's Avatar
What spurs are those? I assume that is an adapter?
fathead is offline
Old 12-15-2014, 11:35 AM
  #776
fathead's Avatar
Looking very likely that I will do alloy main part with changeable delrin pulleys, easier to machine the pulleys themselves that way too, and gives the flexibility of different tooth counts
fathead is offline
Old 12-15-2014, 11:36 AM
  #777
fathead's Avatar
Any other xxxs parts people are wanting?
fathead is offline
Old 12-15-2014, 11:50 AM
  #778
nf_ekt's Avatar
A lot of the common-wear parts are still floating around, like arms, hubs, ect.
Trinity had the MF line of hop-up parts, such as different Roll Center options. Those are some things that would be nice to have access to. Easy to produce I would guess as well.
I would like a gear diff for the rear Though to be honest the sealed drivetrain does make the ball diff last pretty long.
nf_ekt is offline
Old 12-15-2014, 01:14 PM
  #779
Thumbs up
I have a beautiful set of carbon fiber shock towers,I'd be willing to ship them to you if you'd be interested in that project!
Old 12-15-2014, 01:29 PM
  #780
fathead's Avatar
Carbon towers is right up my alley actually!
fathead is offline
