LOSI XXX-S, Tips and Tricks, Open Mod, etc >
Like Tree5Likes
Old 12-03-2014, 05:16 PM
  #751
skater-deez1's Avatar
Trader Rating: 79 (100%+)
Thumbs up
Originally Posted by fathead
Will be machining some early next week
If you need anymore dimensions feel free to pm me!
skater-deez1 is offline
Old 12-03-2014, 06:52 PM
  #752
nf_ekt's Avatar
Trader Rating: 115 (100%+)
Want.... must.... have...
Eagerly standing by
nf_ekt is offline
Old 12-06-2014, 03:27 PM
  #753
bigfatslob's Avatar
Ok, I need more too.
bigfatslob is offline
Old 12-06-2014, 09:38 PM
  #754
johnr2262's Avatar
Me too
johnr2262 is offline
Old 12-08-2014, 09:57 AM
  #755
I found this forum because I am planning to buy my son a brushless upgrade for his Losi XXX-S for a Christmas present. From reading the forum, I have determined that he will need one of the Spur Adapters that Fathead is going to manufacture as well as the Brushless motor and speed control. I am new to brushless in cars, but have experience with brushless motors in RC planes. Does anyone have any recommendations for a brushless motor setup in the Losi XXX-S? What is the recommended pinion and spur gear, the motor KV rating, the number of turns, etc.? I am leaning towards a sensored motor to smooth the acceleration (should be easier on the belts).
prcarbin is offline
Old 12-08-2014, 10:42 AM
  #756
Thumbs up
I'd say check out the Speed Passion 17.5 combos,very affordable and really good performance. They're sensored and very smooth. As far as how to gear it,get the adaptor and a small spur/big pinion combo. You'll need to get somewhere around a 3.5- 3.8 fdr. To get your fdr it's spur divided by pinion times the internal(xxxs is 1.83 internal)ratio. Any questions feel free to ask away!
Old 12-08-2014, 11:31 AM
  #757
fathead's Avatar
Still here guys, just had other big jobs take precedence, still hopeful for this week.
Thanks for being patient.
fathead is offline
Old 12-08-2014, 02:33 PM
  #758
Thanks for the advice! I am finding several Speed Passion 17.5 combos on eBay, some with a 70 amp ESC, and some with the 40 amp ESC. Which ESC will I need for the XXX-S?
prcarbin is offline
Old 12-08-2014, 02:51 PM
  #759
Thumbs up
Either would work just fine,as long as you only run a 2s lipo.
Old 12-09-2014, 08:33 AM
  #760
What size of 2S lipo will fit the XXX-S chassis? Will the 5000 mah fit? Should I use hard case or soft case?
prcarbin is offline
Old 12-09-2014, 09:02 AM
  #761
Thumbs up
I run hardcase 2s 5000's with no problem,just gotta dremel out some of the little tabs on the topside of the chassis that were there to hold the sub c cells in place.
Old 12-11-2014, 12:44 PM
  #762
I would like to order one of the spur adapters when they are ready.
prcarbin is offline
Old 12-14-2014, 12:38 AM
  #763
fathead's Avatar
Started work on first prototype tonight
fathead is offline
Old 12-14-2014, 04:14 AM
  #764
Thumbs up
Sweet!
Old 12-14-2014, 11:33 AM
  #765
fathead's Avatar
Would the aftermarket belts benefit from a bigger pulley or smaller pulley?, I thought I read something about a mod needed with them.
I'm thinking of something a bit more exotic than just straight delrin is all, even with the stock 23T pulley there is very little meat left for the spur screws to screw into, so was thinking about doing alumiunium 'backplate' with delrin pulley fitted to that, would allow easy changing of the pulley size.
fathead is offline
