Old 11-02-2010, 09:51 AM   #1066
Hi, i hope there is somebody who can help me on this one.
I installed a new Novak kinetic 2s in my Mi4lp together with a ballistic 13.5t motor.
I also got the novalink programming interface but for some reason i can't get things to work.
When i plug the novalink into the speedcontroller i get the following error messages:
- Start rpm out of range
- End rpm out of range
- Boost rate out of range
- Applied timing out of range
- Turbo mode out of range
If i try to update the settings of the speed controller i get the following error message:
- An error occured when converting data for transmit. Please reset values and try again. Lenght can not be less then zero.
Parameter name: Length
And after that the software seems to "hang" until i disconnect the speed controller.
It's also strange that the date and time in the novalink screen stays at 1-1-1970 0:00 UTC.
When do the novalink connection check everything appears to be oke and every test is passed.
The installed novalink software is version 1.3 and i updated the speedo to firmware version 1.3.
Any suggestions?
Magneto is offline   Reply With Quote
Old 11-02-2010, 03:11 PM   #1067
Hi, i hope somebody can help me on this one,
I installed a new Novak kinetic 2s speed controller in my Mi4lp together with a ballistic 13.5t motor.
If i try to update the settings of speed controller i get the following error message:
And after that the software seems to "hang" until i disconnect the novalink from the speedo.
When i do the novalink connection check everything appears to be oke and every test is passed.
Programming with the switch works fine.
Old 11-02-2010, 03:56 PM   #1068
Johnny Wishbone's Avatar
Have you tried to pre-build a program and then load it to the Kinetic? All those messages are legitimate errors if your settings are out of range. OR try to hit the reset setting and re-adjust your settings from start. The only weird message I ever get refers to the Lipo selection, and thats a system fault.
Your screen date is the same as mine, another glitch in the software, but non-effecting.
Old 11-03-2010, 04:23 AM   #1069
nerdling's Avatar
got an interesting error on the weekend.
Pluged the Novalink in, got a message to update to version 1.3. I've allready done this. Is this a sign of an underlying problem?
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
Old 11-03-2010, 04:49 AM   #1070
xtraman122's Avatar
Trader Rating: 42 (100%+)
I get that all the time, just unplug and plug it back in. I noticed I always get that if I leave the battery plugged in while doing it.
xtraman122 is offline   Reply With Quote
Old 11-03-2010, 05:41 AM   #1071
I was advised by NOVAK to never leave the main battery plugged in when using novalink as you can damage the brainboard as I did on mine. I believe the online manual has been updated to this effect.
I also get the 1.3 message from time to time. I only saw the out of range error the very first time I connected the Kinetic to the PC. Until recently when playing with the throttle curves.
Try one touch setup and connect the novalink again. This seems to sort most problems and always make sure you disconnect the main battery, it won't always kill the ESC but it can.
dvaid852456 is offline   Reply With Quote
Old 11-03-2010, 06:02 AM   #1072
I've just checked and it isn't mentioned anywhere. It really should be as it can brick the ESC leaving the main battery connected.
Old 11-03-2010, 06:25 AM   #1073
xtraman122's Avatar
I know I've seen it mentioned somewhere, Tekin says the same thing for their stuff.
Old 11-03-2010, 07:08 AM   #1074
Company Representative
Default Kinetic 1S Update:
Yesterday, we uploaded the interim SW patch for the Kinetic 1S esc for users with the NovaLink:
NovaLink Downloads
For those of you without the NL, we can send you a new plug-in "brain" board with the micro programmed with this new firmware update. Those of you who would prefer the brain board option, please PM me your mailing address and I will get one out to you.
NovakTwo is offline   Reply With Quote
Old 11-03-2010, 09:30 AM   #1075
macdude's Avatar
NovaLink Downloads
How much is a brain board for the 2S version? I think I fried mine. Another victim of battery while updating. Although everything appears to work except the brakes. Even after resetting doing the one touch set up they are very weak. The only thing I haven't tried is reloading the 1.3 firmware to the device.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 11-03-2010, 09:36 AM   #1076
I suggest emailing all of your symptoms to [email protected] and they can assist you with your problems. We don't currently sell brain boards, but as these products mature, it might be a good idea....
Old 11-03-2010, 10:46 AM   #1077
Suspended
try in this order - reload 1.3 and then redo 1 touch and then reset settings with novalink.
Also make sure brake frequency is set to the lowest number - maybe try this one first
I lost all brakes too at one time and was not very happy until I realized I had the brake frequency set too high when playing with the settings.
Pimp Formally Known as OG
PFKAOG is offline   Reply With Quote
Old 11-03-2010, 02:49 PM   #1078
macdude's Avatar
I'll give this a try when I get home. Like I said before everything in the Nova link seemed to work and I even made adjustments to the drive frequency that I could feel. But the break where just really weak compared to how they where acting before the "oops"
Old 11-03-2010, 02:55 PM   #1079
Suspended
I forgot to unplug the battery a few times myself and may have gotten lucky by escaping damage. If you were playing with the drive frequencies I'll bet that's the problem.
Old 11-03-2010, 03:06 PM   #1080
Thank you Johnny for your answer, i tried to upload a pre-build program but still the same result.
As soon as i hit the update button, this message: "An error occured when converting data for transmit. Please reset values and try again. Lenght can not be less then zero. Parameter name: Length"
On the background the running circle is present but nothing is happening, and it can only be stopped by clicking the disconnect button.
When i program the esc by use of the switch everything works fine and run perfect.
I'm i still doing something wrong here?
Dyno, Homemade, Using a Novak Sentry Data Logger, Continued, The Experimental Thread. John Stranahan Electric On-Road 344 12-30-2016 05:22 PM
Novak Kinetic racer1812 Radio and Electronics 254 02-04-2013 08:52 PM
Novak Sentry as Brushless Dyno mattnin Electric On-Road 132 01-29-2010 05:53 PM
2009 i-hobby show b-man777 Electric On-Road 7 10-22-2009 09:35 AM
Spintec Battery Manager Erik Jonk Electric On-Road 999 03-26-2009 03:07 AM
Tags
brushless, gtb, novak kinetic, onroad, rc cars
