Old 09-16-2010, 12:23 PM   #856
scoyle's Avatar
Originally Posted by jammincrtjames View Post
Is the software working with windows7?
It works with the 32bit version but not with the 64bit version.
scoyle is offline   Reply With Quote
Old 09-16-2010, 04:01 PM   #857
Raman's Avatar
Trader Rating: 56 (100%+)
My Kinetic headache are finally over. Apparently I had a lemon from the get go. Novak replaced mine with a new one. To think I must installed and uninstalled Novalink 20 + times! LOL.
This is my first ESC with timing advance and boost. Prior to having one, I thought, if you need to gear down, I don't see what the big deal is.
Today I took my car for its first test drive with these settings
Ballistic 17.5
RPM Range 5500-14000
Applied Timing 30'
Boost On @ 300ms
Final Drive 6.1
My first thought.. The 17.5 with those settings was almost as fast as my GTB with 3.5! I'm at present repenting for my doubts
Raman is offline   Reply With Quote
Old 09-16-2010, 04:29 PM   #858
Johnny Wishbone's Avatar
Ballistic 17.5
Applied Timing 30'
Boost On @ 300ms
Final Drive 6.1
If you went to 50* applied timing there should be no doubt in your mind that its as fast as your 3.5.
I can attest that with 50* a 17.5 will run with most of the mods in a straight line, I tested this at IIC. As you change your "boost on" setting it will make the car easier to drive out of the corners, esp if corners are tight or traction is down, definately a option to play with. Also try some of the other acceleration curves for final fine tuning.
Old 09-17-2010, 03:39 AM   #859
Works with 64 bit too.
dvaid852456 is offline   Reply With Quote
Old 09-17-2010, 04:32 AM   #860
xtraman122's Avatar
Trader Rating: 42 (100%+)
Yeah, I've never had any issues with Win7 x64, when it was first released 64-bit support was listed, now everywhere you look it says NO 64-bit support, yet it works fine.
xtraman122 is offline   Reply With Quote
Old 09-17-2010, 06:15 AM   #861
scoyle's Avatar
I did answer this based on version 1 which I installed on my Windows 7 64 bit and had issues. I then created a Windows 7 32 bit Virtual Machine and installed with no problems. Also Novak themselves have said there is no 64 bit support.
Might go back and try version 1.3 and see if it works any better as it would save me starting the VM on my laptop to use Novalink.
Old 09-17-2010, 09:48 AM   #862
Company Representative
When we use the word "support", we mean two things:
~ We have not thoroughly tested the NovaLink on these OSs, so we can't recommend them with confidence.
~ Tech Support is not familiar with them yet, so we cannot help customers who call in for assistance.
We do not have the resources to "teach" phone customers (or emailers) how to install and use the NL on the 64 bit machines. So, we are not recommending them for now. But, we are working on it.
NovakTwo is offline   Reply With Quote
Old 09-18-2010, 01:47 AM   #863
JBM Racing's Avatar
Hi Guys,
I want to try a 5 turn Speed passion with my kinetic ESC, can I add dynamic timing to the ESC? What range and level?
I was thinking of running the timing between 13,000-33,000RPM and starting at 10 deg and checking the motor... Increasing the timing until it gets too hot.
What do you guys think?
JBM Racing is offline   Reply With Quote
Old 09-18-2010, 04:19 AM   #864
blade072's Avatar
Trader Rating: 98 (100%+)
im thinking of going to mod with a kinetic.....the motor will be a 5.5t
whats a good starting point setting wise??????
thanks
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 09-18-2010, 01:52 PM   #865
thanks
I would start at 10-15 degree setting and avoid going above 30 degree as the motor current draw goes up exponentially.
It's quite easy to surpass 50 amp continuous draw with a 4.5 turn motor and 20 degree timing.
Typically one does not see the RPM increase in low turn motors as you would experience in high turn motors application (10.5 to 17.5).
Start low and make small changes, motor and ESC temperature should always be below 160-170 F.
Adnan
Novak Engineering Dept
escman is offline   Reply With Quote
Old 09-18-2010, 03:34 PM   #866
JBM Racing's Avatar
So when will V1.4 be available? Cannot wait until we can start testing...
Old 09-18-2010, 08:14 PM   #867
Tim Smith's Avatar
Send a message via Skype™ to Tim Smith
I just got back from a day of Testing on my dragsters at the track (132 feet) and everything went as good as I could hope.
The Kinetic ran awesome and in the 2 cell car (10.5 Ballistic TSE motor, 2 cell MaxAmps 4200 and Kinetic) I managed to go faster then my current national record with a best run of 1.77 seconds at 73 mph
And in my 3 cell car (3.5 Ballistic TSE motor, 3 cell MaxAmps 4200, Kinetic) I also went faster then the current national record with a best run of 1.36 seconds at 106 mph~!
VIVA NOVAK Kinetic speed controller~!
TimSmithRacing.com MaxAmps.com MKS Servos CowRC TSRspeedshopRCpodcast Evul Empire Dan's RC Stuff
Tim Smith is offline   Reply With Quote
Old 09-19-2010, 05:25 AM   #868
blade072's Avatar
Adnan
thanks for the advice....much apprecited
David Randall
Old 09-19-2010, 10:52 AM   #869
Raman's Avatar
By the way, what's TSE?
Old 09-19-2010, 12:03 PM   #870
TVMRocket69's Avatar
Send a message via AIM to TVMRocket69 Send a message via Yahoo to TVMRocket69
Quick question about the 1s Kinetic. It says it's wired for a 2s receiver pack. Does this mean that no regulator is needed?
Bob Walker Jr.-Sponsor's-
AnswerUSA-RC Team Driver, G's R/C Raceway Team Driver, RBMods Team Driver, Kosmic R/C Fuel Team Driver, MurfDogg Motorworks Team Driver, Serpent S811B, Serpent S811t, MurfDogg Powered V-Desizn Carpet Ripper 5
TVMRocket69 is offline   Reply With Quote
Dyno, Homemade, Using a Novak Sentry Data Logger, Continued, The Experimental Thread. John Stranahan Electric On-Road 344 12-30-2016 05:22 PM
Novak Kinetic racer1812 Radio and Electronics 254 02-04-2013 08:52 PM
Novak Sentry as Brushless Dyno mattnin Electric On-Road 132 01-29-2010 05:53 PM
2009 i-hobby show b-man777 Electric On-Road 7 10-22-2009 09:35 AM
Spintec Battery Manager Erik Jonk Electric On-Road 999 03-26-2009 03:07 AM
Tags
brushless, gtb, novak kinetic, onroad, rc cars
