Old 09-10-2010, 02:16 AM   #796
As far as I know the Eagle Tree brushless RPM sensor works but I will confirm or deny later as hopefully it's arriving today
dvaid852456 is offline   Reply With Quote
Old 09-10-2010, 07:41 AM   #797
Brum's Avatar
Send a message via ICQ to Brum
Questions??
Hi all still cant work out whats going on with my novak setup.
novak kinetic 2s and novak ballistic 4.5t 550 motor.
I finally got power to my esc again after leaving it unplugged overnight.
when i turn my esc on all the lights come on go through there sequence
and show no errors. i pull the throttle and the motor runs for about 3seconds
then stops and all the lights go out and esc will not switch back on.
i have to diconnect the battery wait 1-2 hours hook it back up and esc works again pull the throttle and it does it all over again what am i doing wrong i have tried sevaral battery packs and recievers makes no difference
my sevo is new ace 1015 please help thanx.
Mugen eco 6,Castle Mamba.Kopropo.EX-1.
Shumacher cougar svr..tekin rs pro,redline 8.5t.Kopropo.EX-1
Shumacher K1 tekin rs pro,redline 7.5t, Kopropo,EX-1
member of Logan Offroad LORRCCC inc.
Brum is offline   Reply With Quote
Old 09-10-2010, 08:03 AM   #798
Regional Moderator
CarbonJoe's Avatar
Does it do the same thing with the servo disconnected?
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 09-10-2010, 08:04 AM   #799
Brum's Avatar
Post
yes
Old 09-10-2010, 08:21 AM   #800
Regional Moderator
CarbonJoe's Avatar
Does it do it with a different motor? Did you try a different sensor wire? If yes to both, sounds like the ESC has an internal soldering or component issue.
Old 09-10-2010, 08:27 AM   #801
Suspended
Didnt I see another thread you started talking about having the same problem with a Novak GTB?
Pimp Formally Known as OG
PFKAOG is offline   Reply With Quote
Old 09-10-2010, 08:30 AM   #802
Brum's Avatar
Post
yeh i think i stuffed up the posting.
Old 09-10-2010, 08:32 AM   #803
Suspended
Redo a 1 touch setup. If the problem remains then it sounds like a radio/reciever issue because you have the same problem with 2 different ESCs. Do you have the transmitter set to the right reciever type?
Old 09-10-2010, 09:03 AM   #804
pejota's Avatar
That sounds like your voltage cut-off is incorrectly set or not working. According to the instructions, the cut off voltage for a 2S LiFe battery is 4.75v. Any chance your ESC is set to the wrong battery type?
pejota is offline   Reply With Quote
Old 09-10-2010, 09:17 AM   #805
Company Representative
It would be helpful if you could confine your requests for assistance to one thread. I have suggested that you contact Novak tech support for the assistance you need in solving your problem. I will post this again for your information:
Because I am not part of Novak's technical support group, I suggest you email [email protected] with your question, Our regular CS/Tech Support hours can be located here. Before emailing, take a moment to review the instructions (trouble-shooting guide) originally included with your Novak Item:
Novak Instruction Downloads
Trouble-shooting TeamNovak's One Touch™ Speed Controls
Please make your initial email as detailed as possible. Include:
~ speed control (brand/model)
~ motor (brand/wind)
~ number/type of cells
~ battery, brand (c rating/capacity
~ rotor (old/new)
~ connectors used
~ servo (brand/model)
~ radio system (receiver/transmitter)
~ vehicle & gearing
~ warranty claim?
~ lipo cut-off, on/off
~ any external modules (BEC/brand, Glitch Buster)
~ other important info: water damage, corrosive chemical sprays, excess heat, etc
The more information you provide in your first email, the more quickly tech support can offer you assistance.
NovakTwo is offline   Reply With Quote
Old 09-10-2010, 09:47 AM   #806
Brum's Avatar
Post
running a 2s lipo and i think the default cutoff is 6.2v .
Old 09-10-2010, 09:58 AM   #807
pejota's Avatar
Understood, but you can go into the Custom Settings of the ESC and change battery type it recognizes. Have you messed with any of those settings on purpose or by accident?
Old 09-10-2010, 10:55 AM   #808
michaelpaul74's Avatar
I believe there is an internal short. My Kinetic had exactly the same problem. I had raced with it for almost a month with no issues. Then, the last race I ran 2 problem free heats, and in the main my esc just stopped working. Switching it on and off doesn't help. I had to unplug the battery, and plug it back in. Then, when the esc turns on and I try and give it throttle, it just shuts down. I have also tried different batteries, and motors. I sent mine in for warranty repair, so I will find out soon if it is a manufacturing problem.
Michael Paul Yates
Kyosho RB5 SP2 WC
Bremerton RC Raceway
Tacoma RC Raceway
michaelpaul74 is offline   Reply With Quote
Old 09-10-2010, 11:44 AM   #809
skypilot's Avatar
Trader Rating: 14 (100%+)
it may be something as simple as a bad motor sensor board
semi retired..
skypilot is offline   Reply With Quote
Old 09-10-2010, 12:08 PM   #810
I always suggest that customers contact Tech Support and include all of the details I have posted above along with a complete explanation of the problem. If the TS guys can determine the problem, we may be able to offer a much quicker solution than returning the items to the factory.
For example, if we can narrow the problem to a bad brain board, rotor or a motor timing assembly, we can send a replacement part immediately. This is one way it comes in handy to have products that can be serviced by the user---especially the Ballistics. But our Kinetic brain board replacements just plug in for a quick repair.
Dyno, Homemade, Using a Novak Sentry Data Logger, Continued, The Experimental Thread. John Stranahan Electric On-Road 344 12-30-2016 05:22 PM
Novak Kinetic racer1812 Radio and Electronics 254 02-04-2013 08:52 PM
Novak Sentry as Brushless Dyno mattnin Electric On-Road 132 01-29-2010 05:53 PM
2009 i-hobby show b-man777 Electric On-Road 7 10-22-2009 09:35 AM
Spintec Battery Manager Erik Jonk Electric On-Road 999 03-26-2009 03:07 AM
Tags
brushless, gtb, novak kinetic, onroad, rc cars
