Old 08-25-2010, 04:17 PM   #601
Trader Rating: 13 (93%+)
Well, I am a new Team Driver myself coming from Speed Passion. Wow! What a difference. I look forward to an awesome season. This software program is epic.
Chad "The Chad" Cason
Novak Electronics / Airtronics / Pro-Line / Black Label Vinyl / Kustom R/C Graphics
**BLACK LABEL VINYL** -Custom Sponsor Shirts / Custom Paint Masks / Multi-Layer Vinyl Stickers
The Chad is offline   Reply With Quote
Old 08-25-2010, 04:27 PM   #602
xtraman122's Avatar
Trader Rating: 42 (100%+)
I just joined the team as well, and I've been loving everything so far, glad to be a part of Team Novak.
xtraman122 is offline   Reply With Quote
Old 08-25-2010, 06:18 PM   #603
Originally Posted by dvaid852456 View Post
My Novalink and replacement ESC arrived today. After plugging everything in the Novalink connects and seems to update the ESC. But when starting it up it is as if the one touch programming needs to be done???
Doing this obviously wipes the Novalink settings and returns it to onboard settings?
After updating with the novalink software and disconnecting the esc, when everything is plugged back in to go racing the ESC has blue and yellow and red and white lights on. The red light goes out if you apply throttle but no movement from the motor?
Any ideas?
Mine did the same thing the first time I updated it. I blamed myself (which is not a stretch!)
Anyway, it never did that again. I chalked it up to being the same as the first error that came up saying things were out of range.
By the way, isn't this one of the most entertaining products you can possibly buy? I bet i've tried 30 different set-ups.
rcannon409 is offline   Reply With Quote
Old 08-26-2010, 03:22 AM   #604
My Kinetic refuses to work when programmed bythe novalink
Everything is fine when programmed by the lights and the software recognises the ESC and updates the settings it just refuses to turn the motor?
Update - Could it be something to do with the firmware update? When following the instructions to update the firmware I get as far as "Please turn on your ESC" but it doesn't do anything, I never get the updating firmware or update complete messages?
dvaid852456 is offline   Reply With Quote
Old 08-26-2010, 04:30 AM   #605
xtraman122's Avatar
It's not updating then, when you plug it in (what they call turning it on) if all goes correctly it starts counting up to 100% and says it completed successfully.
Old 08-26-2010, 04:54 AM   #606
This is driving me mad! If I change a setting like turn timing off and update the ESC it recognises this and the white light goes out. It reads the settings back from the ESC so I know it's updating it. There is just no drive????
Old 08-26-2010, 06:00 AM   #607
macdude's Avatar
you need to un plug and re plug your ESC to the novalink. I thought the same thing when I tried to up date mine. But that's all it took. It's like the updater needs to reconnect to the ESC and it doesn't care if its on or off, just that you unplug it and then plug it back in.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 08-26-2010, 07:16 AM   #608
Hi, I tried that and when I get the "please turn on your ESC" message I plug in the ESC but the firmware updater windows just closes? Would it do this if I had already successfully updated the firmware?
Is there any way of checking what firmware the ESC is running?
Still no drive despite the ESC successfully storing settings?
Old 08-26-2010, 08:22 AM   #609
xtraman122's Avatar
I had that happen to me the first time I tried updating it, the window just closed when I plugged the speedo in, it never did it again though.
Old 08-26-2010, 08:46 AM   #610
It does it every time I try? I've forwarded the info onto Novak Tech team. See what they say. I hope this isn't a fault with the ESC as I've only just got it back!
Old 08-26-2010, 08:59 AM   #611
Okay I have the firmware updated!
But it still won't drive the motor
By carefully making sure I made contact with all 3 pins at the same time when connecting the ESC it started updating! HA! Unfortunately it still only drives the motor when programmed by the button.
Old 08-26-2010, 10:50 AM   #612
macdude's Avatar
Try uninstalling the novalink and then reinstall it.
Old 08-26-2010, 04:33 PM   #613
JayBee's Avatar
Trader Rating: 31 (100%+)
What is Novak DOING to correct these NovaLink issues??? I have a 2S Kinetic w/a NovaLink, just waiting on the 1S Kinetic.....(I'm thinking out loud here, but) was there any R&D with this device? I'm sticking with Novak, but c'mon guys....way too many issues here.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 08-26-2010, 07:30 PM   #614
jsamarin's Avatar
so i just plugged in my kinetic, and programming went great. i go to drive it and it goes for like 5 seconds then shuts its self off. whats have i done wrong? any advise would be great
jsamarin is offline   Reply With Quote
Old 08-26-2010, 07:35 PM   #615
Trader Rating: 217 (100%+)
The old blinking lights are looking better and better!!!
Andy Koback is offline   Reply With Quote
Dyno, Homemade, Using a Novak Sentry Data Logger, Continued, The Experimental Thread. John Stranahan Electric On-Road 344 12-30-2016 05:22 PM
Novak Kinetic racer1812 Radio and Electronics 254 02-04-2013 08:52 PM
Novak Sentry as Brushless Dyno mattnin Electric On-Road 132 01-29-2010 05:53 PM
2009 i-hobby show b-man777 Electric On-Road 7 10-22-2009 09:35 AM
Spintec Battery Manager Erik Jonk Electric On-Road 999 03-26-2009 03:07 AM
Tags
brushless, gtb, novak kinetic, onroad, rc cars
