Old 08-19-2010, 05:37 PM   #496
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by JayBee View Post
Also...what's the status on the 1S Kinetic?
Novak....anyone....Bueller???
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 08-19-2010, 06:24 PM   #497
Just ordered mine. Thanks buddy
Now, the sad part is we have to sleep with EVERYONE from a-main due to my past comments! Mine shipped today so I should get it Saturday.
Mick, I programmed mine last night with the receiver disconnected form the control....no problems at all. Oddly enough, it was a no-go when the rec was plugged in?????? I'm now blind from the lights, but I DID IT!!!!!!!!!!
rcannon409 is offline   Reply With Quote
Old 08-19-2010, 07:01 PM   #498
JayBee's Avatar
Btw....Tower has NovaLinks as well
Old 08-20-2010, 01:06 AM   #499
Maybe it's the case that 2.4g is sending a lock signal to the esc when conneceted but not bound to the tranny, 2.4g users should try unplugging from receiver to one touch programme esc when the tranny is not available.
As for bright lights, unless you're a mogwai, it shouldn't be much of a problem but sunnies can help and as a bonus you'll look cool when programming your kinetic.
Steve UK is offline   Reply With Quote
Old 08-20-2010, 02:24 AM   #500
Originally Posted by Steve UK View Post
Timing settings etc for 10.5
From our experience, and weve had some.
Try the settings I gave earlier to Scoyle for 10.5, it's a very agressive setting but I've been running it now for quite a few meetings and not had 1 meltdown yet, strong power and excellent top end, however I strongly advise you take into account my reccommendations on fixed endbell timing and FDR. I am running 6.7 to 7.0 depending on circuit size, I went into specific detail of equipment used track style and speedo settings in earlier mail recently so as to avoid any meltdowns for users.
Novak have produced a speedo which is very adjustable, with adjustments available that can cause damage if used without proper caution, if the speedo was not capable of over stretching other items in the circuit , ref motors. then customers would always believe it's not capable of pushing equipment to it's limits.
However thats the nature of the RC Beast currently, pushing equipment to within an inch of it's life, especially On-road Electric. Used correctly it's a fantastic piece of kit,
If you want to go in at the top, and go hard immediately, Take note of the excellent advice given on here from trusted users, ( Novak reps )and you won't go far wrong.
Otherwise if time is on your side and you wish to sort it out yourself, be cautious and approach the limits from below. Enjoy learning this equipment and save yourself some bucks on the way.
With regards to one touch programming without the transmitter, It's my belief that if you use 2.4g then you need the transmitter available and switched on. The speedo needs to recognise a receiver attached and 2.4g don't supply the required signal to the speedo unless it's receieving a signal from the tranny. However, 40 meg etc receivers don't require the connection to the tranny and as such the esc can be programmed without the tranny in attendance, hence why some people can programme the esc with out the tranny on.
Steve
Team Novak/CML UK On-Road rep.
Good advice. My fault for over gearing. I've not had enough experience to notice the subtleties of an over geared car. I guess 5.6 is quite alot higher than 6.9. It's just 6.9 sounded way low after running 4.52 normally.
I'm a bit nervous trying the 55* and boost again but with the higher gearing on a large tarmac track do you think it will be okay then. Can you damage brushless motors from under gearing them?
dvaid852456 is offline   Reply With Quote
Old 08-20-2010, 05:18 AM   #501
I'd like to see the turbo setting made adjustable.
It would be nice if you could set the timing level to be say 20* and the boost be 40* instead of 60*.
Is this likely to be a software update in the future?
Also with the novalink is it possible to set timing level at 20* but still enable the boost? If so I presume the boost is still 60*. Is this correct?
Old 08-20-2010, 08:48 AM   #502
Company Representative
We are still on target for EOM shipping of our Kinetic 1S controller.
NovakTwo is offline   Reply With Quote
Old 08-20-2010, 08:50 AM   #503
The NL operating instructions include an email address to send future upgrade suggestions to our developers.
Old 08-20-2010, 07:05 PM   #504
JayBee's Avatar
Sweet!! Now what was the EOM shipping date again?
Old 08-20-2010, 07:08 PM   #505
xtraman122's Avatar
Trader Rating: 42 (100%+)
End Of Month...
xtraman122 is offline   Reply With Quote
Old 08-21-2010, 05:10 AM   #506
Jay_P's Avatar
Originally Posted by Jay_P View Post
Looking for some help, Im pretty new to these advance timing speedos
Will a TC with a 13.5 GM, 30 deg advance, 9.5k timing point with a 5.10 fdr cause any problems?
Anyone?
Jay_P is offline   Reply With Quote
Old 08-21-2010, 08:46 AM   #507
macdude's Avatar
Default HEAT!!!!!!
I am not sure why, but the kinetic produces way more heat to the controller than either the tekin or mamba. Same settings and FDR and the motor with the novak is 20-30 degrees higher than the Tekin. The mamba is closer but still seems to run cooler.
Did quite a bit of testing yesterday, and the only thing that I notice that may make things hard is that the drag brakes according to the lights produce a ton more braking than say, when you program what should be the same value via the novalink. Not sure why this is but it seems that the values do not match.
I also notice the drive frequency, seems softer from the novalink than when you set it via the lights. 13.8 with the lights is closer to 11 via the novalink in feel. I tried it a bunch of times to make sure that it wasn't just my mind, but even other drivers noticed a big difference.
Tomorrow I am going to try running closer to 7 for a FDR and see if I can't get the temps down. This seem a little high but others are running this with their mamba's and Tekins with full boost. I never liked pushing the motors this hard so I always run a little lower FDR and less boost because I like how that drives in the in field.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 08-21-2010, 10:06 AM   #508
ed517's Avatar
try setting the current limiter to 3. for me this has dropped my temps 15* or more on average with no loss of power. Are u running TC or offroad. In TC choose the custom Thr. curve default 2. min drive at 10 drag start at 6. this has helped keep my temps near 140* on hot days in Sac. Ca where our track temp is usually 120*+. it gives the car good snap as well. if you are running 17.5 i have a killer set up let me know i will post up
ed517 is offline   Reply With Quote
Old 08-21-2010, 12:09 PM   #509
You can't compare three different ESC's with the same settings and expect them to run the same. Regardless of how similar they are you should treat them all as completely different.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 08-21-2010, 01:52 PM   #510
xtraman122's Avatar
I can't comment on how the lights/NovaLink compare, as I've only changed settings through the NovaLink thus far, but I did notice that all the values are double the braking that it would be on like a Tekin. 50 is max, but it's really like 100%, because on my Tekins I was always around 37-42% drag brake, and with my Kinetics I'm in the 18-20 range. I don't get why it's called percent, because 50 "%" on the NovaLink is really 100% of the total brakes.
Dyno, Homemade, Using a Novak Sentry Data Logger, Continued, The Experimental Thread. John Stranahan Electric On-Road 344 12-30-2016 05:22 PM
Novak Kinetic racer1812 Radio and Electronics 254 02-04-2013 08:52 PM
Novak Sentry as Brushless Dyno mattnin Electric On-Road 132 01-29-2010 05:53 PM
2009 i-hobby show b-man777 Electric On-Road 7 10-22-2009 09:35 AM
Spintec Battery Manager Erik Jonk Electric On-Road 999 03-26-2009 03:07 AM
Tags
brushless, gtb, novak kinetic, onroad, rc cars
