Old 04-13-2012, 01:00 PM   #2026
If you mean a one-touch setup, I did that many times. Spent the whole evening trying to get this to work. It seems to get hosed as soon as I open the custom ramp window, even if I don't modify any values from the default ramp.
Steve S is offline   Reply With Quote
Old 04-13-2012, 03:26 PM   #2027
Johnny Wishbone's Avatar
Without the NovaLink hooked up are you able to make the changes and have them stay in the window? I'll try it on my K1S/rxr pack speed control when I get home and let you know.
Gary Lanzer
Old 04-13-2012, 03:39 PM   #2028
Yes, that's no problem, it just doesn't seem to apply the timing to the motor. I also noticed some weirdness in the config files when I save the setup:
Code:
<startRPM>2000</startRPM>
<endRPM>4500</endRPM>
<appliedTiming>45</appliedTiming>
<boostRate>100</boostRate>
<turboMode>1</turboMode>
<RPM1>37500</RPM1>
<RPM2>28571</RPM2>
<RPM3>25531</RPM3>
<RPM4>23076</RPM4>
<RPM5>21052</RPM5>
<RPM6>19354</RPM6>
<RPM7>17910</RPM7>
<RPM8>16666</RPM8>
<timing1>5</timing1>
<timing2>11</timing2>
<timing3>16</timing3>
<timing4>22</timing4>
<timing5>28</timing5>
<timing6>33</timing6>
<timing7>39</timing7>
<timing8>45</timing8>
<customTiming>1</customTiming>
The timing values look way wrong, and ramp the wrong direction. I produced this with the following steps (ESC never connected):
1. Open Novalink
2. Create new profile
3. Go to Advanced tab
4. Set timing level to 45 degrees
5. Click Timing Ramp Up
6. Click OK
7. Save current profile
Maybe those RPM numbers are by design, and are some strange representation of the correct RPM values. Or maybe it's related to my problem. If you have a working custom ramp, could you save it and see what the file looks like? Thanks.
Old 04-13-2012, 10:32 PM   #2029
Code:
<RPM1>37500</RPM1>
<RPM2>28571</RPM2>
<RPM3>25531</RPM3>
<RPM4>23076</RPM4>
<RPM5>21052</RPM5>
<RPM6>19354</RPM6>
<RPM7>17910</RPM7>
<RPM8>16666</RPM8>
1. Open Novalink
6. Click OK
Ok I checked my K1S with rxr pack, then I changed the timing ramp rpms and timing amounts and it did not change the timing to 0, and the ramps and timing changes where kept in the profile. I then tried everything out, ran it, then went back into the speed control and did a reset of the timing ramp, back to the default settings, again the settings applied and did not effect the final timing to 0, the 55 degrees I had remains there.
I also did the save profile and and then looked at the numbers print out and my rpm numbers are the same as yours with high to low, and the timing the same as well.
The only time that the top end felt soft was when I turned the boost off so it did not get that final rpm snap.
Not sure why yours defaults to 0, i did the ramp changes both ways, with straight number inputs and using the up and down arrows and it always seemed to work.
Not much help here, but if you want me to check something else let me know.
Gary Lanzer
Old 04-13-2012, 11:27 PM   #2030
Very strange. Everything seems to be working in the interface, but the motor is obviously just not being given any timing.
Oh well, I'll see what Charlie says. Thanks for checking it out!
Old 08-11-2012, 10:37 PM   #2031
dirtman71's Avatar
looking for a good starting point for the Kinetic
got a slash 2wd with a balistic 17.5
76t spur
23t pinion
8.9 FDR
Min drive 6
timming set point 4000
max timming 5000
timming 40*
boost on
current limit 1
Ran it for a few min on the street and nothing got hot motor was 120 esc was 92. Not sure how it will do on the track. Been looking for other's set ups but havent found any. Dont have a fast track more technical but do need top end, getting killed on the straight
This setting has more than enough top end I think. know nothing of setting this up right...give me some pointers thanks
Kyosho SC-R, RC8Be, Jammin X1CRe, Jammin SCRT10, RC10GT2, T4.1
Slash 2wd ChuckWorks slice B2, E-maxx, RC10T3, Tamiya M-05, TA-05
dirtman71 is offline   Reply With Quote
Old 08-15-2012, 02:59 AM   #2032
nerdling's Avatar
Hi Guys,
looking for some guidance with the Kinetic.
Running a 21.5 powered Touring car in a tight in carpet track with foam tyres.
Current setup:
rollout = 39mm
Timing start 2000 end at 10000
timing = 20
boost delay = 500ms
Motor is a reedy sonic with maximum can timimg.
Here's the problem, with the boost disabled the car is ssllooww..... with the boost enabled its compettive in a straight time but the throttle curve sucks, the boost was comming on at all the wrong times, the other problem is it came off at 139deg C (really hot!!)
The other thing I noticed was that I could not change the timing value off 20, that gives?
Please help...
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
Old 08-15-2012, 05:51 AM   #2033
Essnowyt's Avatar
Send a message via AIM to Essnowyt
Originally Posted by nerdling View Post
Hi Guys,
Current setup:
rollout = 39mm
timing = 20
boost delay = 500ms
Please help...
When I ran boosted 17.5 I also coupled the kinetic with a Novak Sentry. The data logging told me that my infield RPMs were still at 6000. So I'm thinking part of your problem is the timing starting way to early.
My set up for boosted rubber 17.5
6500 start
18000 end
50 degrees of advance
motor timing of 30-35
5.6 ratio
I hope that helps.
Snowy.
Team XRay, RCAmerica, Motiv, Gravity RC, Schacht Design Works.
Drive it, Dont slide it!
Essnowyt is offline   Reply With Quote
Old 08-16-2012, 05:36 PM   #2034
nerdling's Avatar
6500 start
18000 end
5.6 ratio
I hope that helps.
Snowy.
Thanks Snowy. I guess the main problem I have is that I can't change the ESC of 20deg of boost. Im can change the number in the field but when I hit update it reverts to 20.
Old 08-17-2012, 01:47 AM   #2035
Skitee's Avatar
The software has a quirk or two,if I remember correctly you need to press enter/return after you've entered the value and then hit update.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 08-20-2012, 01:45 AM   #2036
nerdling's Avatar
... I'll check that out
Old 08-27-2012, 03:56 AM   #2037
nerdling's Avatar
That worked. Thankyou.
Old 08-27-2012, 05:37 AM   #2038
Skitee's Avatar
Old 10-08-2012, 04:33 PM   #2039
Default Novalink Profiles
I am running a Novak Kinetic ESC with Novak Ballistic 8.5 brushless motor in my B4.1, anyone know any good Novalink profiles or have any they are willing to share?
ssimonson764 is offline   Reply With Quote
Old 11-10-2012, 10:09 PM   #2040
redbeard87's Avatar
Trader Rating: 36 (100%+)
I recently purchased a used Kinetic and Novalink, got all the software installed and it won't read the esc. I've tried on 3 computers and checked all the wiring to make sure it's correct. The green light comes on on the link but it says "ESC Diconnected". I would really appreciate some guidance on this. Also, the esc functions normally, I'm only having trouble with the programming.
redbeard87 is offline   Reply With Quote
Dyno, Homemade, Using a Novak Sentry Data Logger, Continued, The Experimental Thread. John Stranahan Electric On-Road 344 12-30-2016 05:22 PM
Novak Kinetic racer1812 Radio and Electronics 254 02-04-2013 08:52 PM
Novak Sentry as Brushless Dyno mattnin Electric On-Road 132 01-29-2010 05:53 PM
2009 i-hobby show b-man777 Electric On-Road 7 10-22-2009 09:35 AM
Spintec Battery Manager Erik Jonk Electric On-Road 999 03-26-2009 03:07 AM
Tags
brushless, gtb, novak kinetic, onroad, rc cars
