Old 11-16-2011, 01:14 PM   #1936
Johnny Wishbone's Avatar
Originally Posted by Raman View Post
So is the normal Kinetic going to get the XDrive update as well? Or is it becoming obsolete?
I'm not sure on that as I don't know what all is changed up to enable the Xdrive. The Kinetic line was originally designed with the 2 boards, one with the fets and the other being the brain board. Not sure if Xdrive is different fets, but if the same, one would think this could be a brain board upgrade.........but this is just speculation on my part.
I do know that the Kinetic Spec is a Xdrive speed control.
Gary Lanzer
Old 11-16-2011, 01:37 PM   #1937
Raman's Avatar
Trader Rating: 56 (100%+)
Novak's site, if you go to shop and try to buy a Kinetic 2S, it doesn't even show up. They must be rolling out a new Kinetic 2S or ?
TRF419X USGT, Roche F1 '16, M06 Pro M Chassis
Raman is offline   Reply With Quote
Old 11-16-2011, 08:10 PM   #1938
Suspended
Cool
Maybe the xdrive is not the only thing Novak got in store for us ! 2.5T motor capabilities with boost would be nice too...lol... Anyways I am cancelling my kinetic 2S order until further notice.... Hopefully they'll release their new ESC before summer 2012 ....
bertrandsv87 is online now   Reply With Quote
Old 11-17-2011, 10:46 AM   #1939
Don't know about 2.5...........the Kinetic Spec has the new Xdrive and is virtually the same as the K2S was for computer interface. The Havoc Pro SC is also a Xdrive and has all the same features of the K Spec, but is all done via button on the switch. I think that eventually the plan is to get away from computer interface programming and have it all button input, similar to the blue guys, but with a lot more input adjustments.
Gary Lanzer
Old 11-17-2011, 11:49 AM   #1940
Raman's Avatar
That's how it was before the Kinetic came out. So the computer interface was short lived.
Old 11-17-2011, 11:56 AM   #1941
snellemin's Avatar
Trader Rating: 16 (100%+)
Computer interface is not going away. There are firmware updates, data logging features, and there are settings, which will not be doable with a few buttons.
6 KiloWatt Racer
GTP-1515 2700kv+RX8. GTP-C50-6L Hacker+RX8. CRT.5-C50-Maxx+modded RSpro.
RCM CRT.5 Neu 1506 6800kv+MMM.
snellemin is offline   Reply With Quote
Old 11-17-2011, 01:09 PM   #1942
Guess we will have to wait and see.
If you want data logging use a Sentry, thats been around for a long time, and there is no plans to integrate that into a speed control. The only guys working on some data logging are the SP guys that I know of, and they have been working on that for a long time.
Should be some interesting new things coming out in the near future.
Gary Lanzer
Old 12-07-2011, 04:20 PM   #1943
Raman's Avatar
This thread became quiet suddenly.... Ay updates from Novak?
Old 12-07-2011, 05:04 PM   #1944
tallyrc's Avatar
what is going away is the wires.. the next lrp is going to be bluetooth..
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 12-07-2011, 06:08 PM   #1945
Raman's Avatar
The buy it now link on kinetic site is still a dead link.. Curious if an updates Kinetic is coming or it's discontinued all together.
Old 12-08-2011, 05:59 PM   #1946
tallyrc's Avatar
it's being updated..
Old 12-09-2011, 09:44 AM   #1947
Charlie's Avatar
[email protected]
Let me know directly if you have questions, and I'm glad to answer them directly.
[email protected] and I get all the [email protected] emails now as well.
Novak Electronics Tech Support
Charlie is offline   Reply With Quote
Old 02-03-2012, 04:30 PM   #1948
youwish16's Avatar
Trader Rating: 19 (100%+)
can anyone help me?
i installed the newest software(1.4.3), installed the drivers, updated the ESC and all that. novalink software loads but when i try to change any settings, i get an unhandled exception error. i cant save a profile because that also gives me the unhandled exception error. i've read through this thread and tried a lot of what was suggested but nothing works. im using windows xp 32 bit, .net framework 4.0
funny thing is, im a tech guy and i cant get this thing to work lol
youwish16 is offline   Reply With Quote
Old 02-04-2012, 06:12 PM   #1949
cyljock's Avatar
Email Charlie
cyljock is offline   Reply With Quote
Old 02-05-2012, 11:19 AM   #1950
So my kinetic died last night. It was having some really odd behaviour, stuttering at certain mid-throttle levels and cutting out completely after less than 1 lap. I tried no-timing mode and replaced the sensor wire to no effect. Then after more fiddling it quit running altogether.
The LEDs are solid red+green which according to the instructions indicates signal harness. I've checked from the receiver plug to the underside of the Kinetic board where the signal harness header is soldered. All 3 wires check out at 0 Ohms. Also, the receiver works with another ESC. I can no longer connect via Novalink as well, so it would seem that the signal input has indeed failed even though the wiring checks out.
I bought it in March of 2011 so it's outside the warranty period. However, it only has about 10 race days of 21.5 and 17.5 blinky, so that's pretty disappointing. Last night was the first attempt at 17.5 boosted 1/12. I went through the Novalink Device Update and the ESC firmware update procedures which is about when it started flaking out, so I guess that may be related.
Steve S is offline   Reply With Quote
Dyno, Homemade, Using a Novak Sentry Data Logger, Continued, The Experimental Thread. John Stranahan Electric On-Road 344 12-30-2016 05:22 PM
Novak Kinetic racer1812 Radio and Electronics 254 02-04-2013 08:52 PM
Novak Sentry as Brushless Dyno mattnin Electric On-Road 132 01-29-2010 05:53 PM
2009 i-hobby show b-man777 Electric On-Road 7 10-22-2009 09:35 AM
Spintec Battery Manager Erik Jonk Electric On-Road 999 03-26-2009 03:07 AM
Tags
brushless, gtb, novak kinetic, onroad, rc cars
