Old 06-22-2011, 09:44 AM   #1876
Buzz65's Avatar
Originally Posted by Charlie View Post
It's a standard .05 size hex.
Whew, I guess I was pretty close then... The 1.3 is a nice 'snug' fit
1.3 Millimeters = 0.05118110236 Inches
John Leonhardt
Kyosho Ultima SC-R Novak Kinetic, Ballistic 13.5/Savox SC-1257TG
Kyosho Ultima RT5 MMP/Tacon /Hitech servo - Just for Fun Truck!
Kyosho Ultima RB5 SP2/Novak Kinetic, Thunder Power 13.5/JR z9100s
Kyosho 1987 Ultima Buggy-frankenstien. <-- Thinking about getting it going again.
Buzz65 is offline   Reply With Quote
Old 06-22-2011, 02:39 PM   #1877
MiCk B's Avatar
Ah......
See now. That's good to know.
Cheers.
MiCk B. :-)
Originally Posted by skypilot View Post
Mick, he doesn't say what brand motor he is using only a 13.5, if it is not a novak or other motor with a temp sensor you will get 200 as a default temp reading. This happened to me when using speedpassion and viper motors.
http://www.dublinmodelracing.com
http://www.p-dubracing.co.uk
http://www.msdmodels.ie
MiCk B is offline   Reply With Quote
Old 06-25-2011, 11:46 AM   #1878
Default help Plz!!
Hi i got a new Kinetic with my 4.5R SpeedPassion motor and newest 1.43 Firmware instaled!
My issue is that the esc does not wind out the motor at its potential It did whit my Nosram!
And you say that i cant advace timing the motor!.
I run the esc in stock settings now no timing on it,is there any firmware that does fix this or
does it not get any better than this?
I have tryed many settings (geraings) whit same result!
CAn you help me whid this plz!!
Sorry my bad English
Thx.Niklas.G
Demuz is offline   Reply With Quote
Old 06-25-2011, 10:35 PM   #1879
Johnny Wishbone's Avatar
Thx.Niklas.G
From the desk of CS, I would try this first.
"I've had guys report they get locked out of the RPM range, what we did to fix was simple. Reset the one touch, re-did the firmware update, reset the one touch again, and Bam, it works like magic.
For the most part, the one touch clears the ESC out, so if you run into goofy issues, it's a good idea to very simply re-do the one touch and start fresh. Takes all of a few seconds."
If this doesn't fix it up contact Charlie directly via [email protected]
Gary Lanzer
Old 07-06-2011, 07:03 AM   #1880
Dear all,
I encountered a random issue with the LiPo/LiFe cutoff, as follows:
- randomly, using a fully loaded battery pack , the car would stop very suddenly. The error reported by Kinetic ESC is Red and Yellow blinking LEDs. It would re-engaged after 5 to 30 seconds.
After checking the motor, my Ballistic 6.5T static motor timing was wrongly set to lowest setting "-".
I reset the static motor timing to middle position "N" as recommanded by Novak:
"When using an ESC that features electronic timing advance (boost or power setting) and a Ballistic motor, the static timing setting should be left at the factory set "N" position"
Everything is back to normal, cutoff is very smooth, car is slowing down for few seconds before cutoff.
nicov is offline   Reply With Quote
Old 07-06-2011, 05:47 PM   #1881
Charlie's Avatar
http://www.rctech.net/forum/radio-el...hless-esc.html NEW ESC INFO.
The motor can be set below n or 30, just not off the label on the "-" mark. That is below 0 and will cause severe misfiring. This will cause super high loads, and make the ESC draw lots of current from your battery pack, and trick the ESC into thinking the battery is dead.
Novak Electronics Tech Support
Charlie is offline   Reply With Quote
Old 07-07-2011, 03:04 AM   #1882
29TC's Avatar
Send a message via ICQ to 29TC
I recently installed the new brain board. I am trying to install the novalink and update to the latest firmware. By the way never used a kinetic before. So....
Do i need the esc connected to a receiver, motor & battery source?
I installed Novalink 1.4.3 but cannot update esc. Esc seem not to be detected. Is it due to no power source?
Any help will be appreciated.
Thanks.
29TC is offline   Reply With Quote
Old 07-07-2011, 06:53 AM   #1883
29TC's Avatar
Its working...Its working.
Finally after hours installing and uninstalling and installing again.
It finally works!!!
Old 07-07-2011, 10:37 AM   #1884
Charlie's Avatar
my email is [email protected] feel free to use it anytime for tech support. I'm pretty familiar with all the Hickups.
Old 07-15-2011, 03:36 AM   #1885
Default How does the kinetic stack up?
I run 13.5 and wanted to know how this speedo stacks up against the following:
HOBBYWING (WHICH I HAVE)
LRP/NOSRAM STOCK SPEC V2
ORCA
GM
TEKIN
I am thinking about getting a new esc.
Lohan is offline   Reply With Quote
Old 07-15-2011, 09:04 AM   #1886
The Novak Kinetic is the most adjustable in the bunch. It's footprint, although not the biggest in the bunch, is on the large side. If you get the NovaLink with it you find it to be the most useable and most versatile.
Banshee8530 is offline   Reply With Quote
Old 07-15-2011, 09:37 AM   #1887
Suspended
ORCA
GM
TEKIN
Tekin and then LRP are the best of the 5 on your list. I run 13.5 and have used both prior to using a Kinetic's. I prefer the Kinetic
Pimp Formally Known as OG
PFKAOG is offline   Reply With Quote
Old 07-27-2011, 11:31 AM   #1888
Default Timing set points
Okay so I've got to the following setup with my Kinetic and TCX with a 10.5 GM motor.
Timing 50
Start RPM 9000
End RPM 22000
No Boost
current limiter 3
FDR 6.8
The fastest 10.5 guys are still ripping past me on the straight.
I was thinking of moving towards the following as this is what they tell me they're running and it's nearer the team Novak settings posted way back.
Timing 50
Start RPM 4500
End RPM 12200
No Boost
current limiter 1
FDR 7.2
I'm going to test it a lot first and perhaps start with a lower timing value. It kind of feels wrong putting the start RPM and end RPM so low but I simply need more speed down the straight.
I know it comes down to driving but recently I set a new PB and nearly all of my laps were as good as I could make them My fastest being 16.32, most in the A final are setting 14.52 as their fastest laps. I'm sure some of it is to do with the speed they are able to get down the straight.
Anyone have any thoughts to the proposed new settings?
dvaid852456 is offline   Reply With Quote
Old 08-08-2011, 05:14 AM   #1889
Timing 50
Start RPM 9000
End RPM 22000
No Boost
current limiter 3
FDR 6.8
Timing 50
Start RPM 4500
End RPM 12200
No Boost
current limiter 1
FDR 7.2
I have one word....TURBO.
I tried the settings above and didn't really go any faster it just created more heat as I guessed it would.
So I went back to 55 timing start RPM 9000 End RPM 18000 and FDR of 7.04 and enabled Boost with a delay of 1200ms. Bingo! The speed down the straight was excellent and the snap on the infield was great plus temps were much better. ESC was 80c and motor was 74c after a 5 minute run.
I reduced the boost delay to 800ms and the speed was even better down the straight with no increase in temps. I felt I could probably gear down to 7.24 and benefit on the infield and get better pace down the straight with the turbo.
So happy with the kinetic now
Old 08-08-2011, 09:47 AM   #1890
Charlie's Avatar
Dyno, Homemade, Using a Novak Sentry Data Logger, Continued, The Experimental Thread. John Stranahan Electric On-Road 344 12-30-2016 05:22 PM
Novak Kinetic racer1812 Radio and Electronics 254 02-04-2013 08:52 PM
Novak Sentry as Brushless Dyno mattnin Electric On-Road 132 01-29-2010 05:53 PM
2009 i-hobby show b-man777 Electric On-Road 7 10-22-2009 09:35 AM
Spintec Battery Manager Erik Jonk Electric On-Road 999 03-26-2009 03:07 AM
Tags
brushless, gtb, novak kinetic, onroad, rc cars
