Old 06-06-2011, 04:26 PM   #1831
When a rotor is exposed to too much heat it reduces its magnetic strength. I'm sure if you put in a new motor it would work. The question which is hard to calculate is how weak will that rotor be? If there was enough heat to damage the stator, then the rotor in a new motor will likely be noticeably less powerful.
Banshee8530 is offline   Reply With Quote
Old 06-06-2011, 11:10 PM   #1832
waOscar's Avatar
My experience tells me that overheated rotors are stuffed and only make good fridge magnets.
The remainder of the motor will probably be ok, put a new rotor in and off you go.
Also, when using overheated rotors you can end up chasing your tail. Rotors which have been overheated will feel great for about 2 minutes on the track and then die off (overheat again). So you turn down the Boost/Gearing and it feels great for 2 minutes and then overheats again. You can turn down the boost/gearing all you like, but it will still feel good for 2 minutes then overheat. This is because a rotor which has been overheated tends to draw around 20-25amps, as opposed to a good rotor which draws about 9-12amps.
Watch your temps very closely, because once a rotor has been cooked there stuffed. Differant motors have differant "cook" temps too, they are not all the same.
Xray T3 2011 - my asphalt chassis
Xray T3 2011 - my carpet chassis
waOscar is offline   Reply With Quote
Old 06-06-2011, 11:25 PM   #1833
Charlie's Avatar
Howdy folks,
We posted 1.4.3 Kinetic firmware.
Addressed some brake issues with the ultra fast frame rate radios, and should help with cap temps.
Any questions, please feel free to email me anytime. [email protected]. Thanks!
Novak Electronics Tech Support
Charlie is offline   Reply With Quote
Old 06-07-2011, 01:57 AM   #1834
fantastic
amagad is offline   Reply With Quote
Old 06-08-2011, 03:02 AM   #1835
Originally Posted by Charlie View Post
Howdy folks,
I currently have my brakes set to 50% on the ESC and transmitter EPA is set to 60% due to some issues with the capacitors.
I have now updated to 1.4.3.
Is it safe to up the brakes with this update as they are a little weaker than I would like.
Even at 50% the caps were almost getting to 60c.
I'm really starting to love the kinetic. Broke my Personal best on Sunday and just keep getting more and more speed out of it. It's super smooth and very driveable.
dvaid852456 is offline   Reply With Quote
Old 06-08-2011, 09:33 AM   #1836
Charlie's Avatar
The Default EPA setting on the ESC has been lowered from 10 to 8, so simply reset your radio to 100/100 on the TH/BK EPA, redo the One Touch Setup, and give it a wirl. You probably won't need any more brake then that. Typically, drivers lower the Brake EPA further yet.
Old 06-08-2011, 10:21 AM   #1837
Coolio - Next race Sunday so I'll give it a try.
Old 06-08-2011, 02:18 PM   #1838
Charlie's Avatar
So I had a chat with SkyPilot last night about a little quirk he found and we came to a fix, well, at least I think we did.
I've had guys report they get locked out of the RPM range, what we did to fix was simple. Reset the one touch, re-did the firmware update, reset the one touch again, and Bam, it works like magic.
For the most part, the one touch clears the ESC out, so if you run into goofy issues, it's a good idea to very simply re-do the one touch and start fresh. Takes all of a few seconds.
Some more detail as to what 1.4.3 has:
Updated Brake operation for Fast Rate Radio Systems.
Brake EPA updated - Works just like radio EPA - now Defaults to setting 8.
Operational changes to reduce the power capacitor temps.
If you have an ESC that is 1.4 anything, fine to update via the Firmware Updater.
If you have an ESC that is 1.3 or older, please email us with your Serial Number to receive a brain board.
Also, the NovaLink was found to have a minor bug in the Throttle/Brake curve - This has been Fixed and posted. The NovaLink that was simply replaced, no changes to the version. Simply uninstall what you have now, and Download what is posted.
Also, if anyone out there has Brain Boards they haven't returned (the old ones) please do. We can recycle them. Regular Post is fine.
And by all means, if you have any questions directly for us, that we've not addressed, or you don't get speedy forum answers, email me directly anytime. If I get internet, I usually answer emails daily.
[email protected]
Charlie
Old 06-09-2011, 08:10 AM   #1839
Hello Charlie,
I just installed v1.4.3, and I get some mixing between buttons and associated description , as follows:
Throttle Curve / Linear : displays "Dead Band" description
clicking on "custom" => no change, "Dead Band" description
clicking on "Linear" => displays "Brake Curve" description
clicking on "Custom" => displays "Throttle Curve" description (finally)
Brake Curve / Linear => displays "Lipo cutoff" description
Independant Drag Brakes / No => displays "ESC Temp Protection" description
Reverse/ off => displays "Independant Drag Brakes" description
ESC Temp / On => displays "Throttle curve" description
Motor Rotation / CCW => displays "Reverse" description
Is it on my PC only ?
nicov is offline   Reply With Quote
Old 06-09-2011, 10:00 AM   #1840
Charlie's Avatar
I don't see that happening with mine. Strange.
If you "leave" your mouse over what you're reading on, it works.
If you move the mouse after you click on it to read the description, the description will change to what ever the mouse is over.
Old 06-09-2011, 12:39 PM   #1841
HB Moose's Avatar
Default Smoked Sensor Wire
Charlie, I had a new failure mode this weekend. Driving with a Kinetic and a brand I 21.5 motor. I jumped a dot and the car rolled to a stop with a small puff of smoke. When trouble shooting the Kinetic looked ok but I got flashing leds. The motor checked out Ok on my dyno. Replaced the sensor wire and was back in business. I took the flex wrap off the sensor wire and one wire had burnt the insulation off it. I believe it was one of the end wires on the connector. Any ideas as to what gave me that kind of power surge that would melt a sensor wire?
ps. how many days to IIC in Vegas?
Bruce "Moose" Riedinger
HB Moose is offline   Reply With Quote
Old 06-10-2011, 10:21 AM   #1842
Charlie's Avatar
MOOOSE!
That's a new one for me. Shoot me an email. I'd like to take a look at that one.
[email protected]
Oh, and "too many"!
Old 06-10-2011, 02:57 PM   #1843
HB Moose's Avatar
MOOOSE!
dang, I tossed the wire
Old 06-13-2011, 12:30 PM   #1844
I ran 1.4.3 at the weekend and was very pleased.
Temps seemed much lower and I was able to push the timing up to 50 degrees. The brakes felt stronger too and no capacitor problems running brakes at 60%.
Well done Team Novak!
Old 06-14-2011, 08:16 AM   #1845
Here's my story...
I bought the Kinetic 2s for my B4.1 a few weeks ago and after reading (thoroughly) the documentation tried to config the ESC's boost. It worked well so I decided to buy the Novalink interface kit. After following the instructions and installing (and trying to connect) the interface my ESC was still working and after upgrading the firmware it just stopped.
I email Novak and Charlie.
Brent Newman (thank you sir) gave me quick reply saying he will replace and ship the brain board to me (on its way here, thank you again).
A day or 2 after Charlie emailed me to download the 1.4.3 and Kinetic firmware. I did it awhile ago and it finally worked! Yahoo!
It was the first time I was able to connect to the software and configure some stuffs. However, the boost mode was not highlighted so I could not configure it.
I did a test run of the buggy awhile ago and sure enough there was not boost (unlike before). I already emailed Charlie just waiting for a reply.
I was wondering if it happened to anyone here. I am using a 13.5t motor on the ESC. Prior to the issue with the Novalink I was running the boost around 50 and the temp was only reaching 40-42C.
Any feedbacks are appreciated.
Thanks =D
PowerPee is offline   Reply With Quote
Dyno, Homemade, Using a Novak Sentry Data Logger, Continued, The Experimental Thread. John Stranahan Electric On-Road 344 12-30-2016 05:22 PM
Novak Kinetic racer1812 Radio and Electronics 254 02-04-2013 08:52 PM
Novak Sentry as Brushless Dyno mattnin Electric On-Road 132 01-29-2010 05:53 PM
2009 i-hobby show b-man777 Electric On-Road 7 10-22-2009 09:35 AM
Spintec Battery Manager Erik Jonk Electric On-Road 999 03-26-2009 03:07 AM
Tags
brushless, gtb, novak kinetic, onroad, rc cars
