Old 02-05-2011, 01:28 PM   #1516
I'm running mod so pretty much everything I need is on the Speed control. Been doing the updates just for the challenge...
My Novalink has a blown trace on the board for some reason so I'm waiting on a new one. I had it do some pretty funky stuff before I installed a switch inline so it was probably something I did.
Fred_B is offline   Reply With Quote
Old 02-06-2011, 12:14 AM   #1517
skypilot's Avatar
Trader Rating: 14 (100%+)
not getting a temp read out on the graph, says the same thing after each run, and btw, I just noticed it only goes up to 120 degrees, shouldn't it read higher. O changed sensor wires, could it be something bad in the motor, I have a spare sensor board is that where the temp reading comes from?? thanks in advance. this is on ballistic 17.5 btw
semi retired..
skypilot is offline   Reply With Quote
Old 02-06-2011, 06:25 AM   #1518
macdude's Avatar
scale changes as the motor and speed control temps change. I have had mine over 140.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 02-06-2011, 06:29 AM   #1519
Leithal's Avatar
not getting a temp read out on the graph, says the same thing after each run...
This is a known bug in either the software or firmware (can't remember which), which will be fixed in the next release, I was told by support.
Leithal is offline   Reply With Quote
Old 02-06-2011, 09:30 AM   #1520
I got a chance to run my Kinetic for the first time this weekend and it worked flawlessly. Super easy to program with the Novalink. Thank you Novak for a great product!!
04Xterra is offline   Reply With Quote
Old 02-06-2011, 08:53 PM   #1521
You are correct, we have a bug in the esc firmware and we will be releasing a fix very soon.
Adnan Khan
Novak Engineering Dept
escman is offline   Reply With Quote
Old 02-06-2011, 10:06 PM   #1522
Jochim_18's Avatar
How smooth is the kinetic on boosted class... I'm pretty fed up with "T" it is fast but I don't like how the power is being delivered way too aggressive I already tried everything.
Localrcracing.com - Your premiere source of Radio controlled Racing in central California.
Visaliahobbies.com * SkyRC * casterracingparts.com
Old 02-06-2011, 10:10 PM   #1523
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Butter smooth In all classes
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 02-06-2011, 10:14 PM   #1524
Jochim_18's Avatar
So you wanna buy my tekin...
Old 02-06-2011, 10:29 PM   #1525
skypilot's Avatar
ok that makes sense, I know I had a higher reading scale in the past.
semi retired..
Old 02-06-2011, 10:30 PM   #1526
skypilot's Avatar
k
semi retired..
Old 02-06-2011, 10:32 PM   #1527
Jochim_18's Avatar
Ok guys I'm ready to make the switch back to NOVAK... So I will be asking question...
First question:
What type of timing profile the kinetic has?
Old 02-06-2011, 10:33 PM   #1528
BrodieMan's Avatar
Default Kinetics prone to smoking??
At the track yesterday a guys Kinetic smoked and melted the case. He said they are known to do this but I wasn't sure if this was actually the case. He thought he was having motor issues than poof, up in smoke.
Mark Richardson
Kawartha Radio Controlled Racers
Lakefield Hobby & Game. ExtremeRCforum
Schumacher Mi4cx CRC Gen-X 10 LE
BrodieMan is offline   Reply With Quote
Old 02-06-2011, 10:35 PM   #1529
Johnny Wishbone's Avatar
First question:
Not sure what you mean by that, please explain/expand question.
Gary Lanzer
Old 02-06-2011, 10:39 PM   #1530
Can you give more info, class, motor, where on track?
Gary Lanzer
Dyno, Homemade, Using a Novak Sentry Data Logger, Continued, The Experimental Thread. John Stranahan Electric On-Road 344 12-30-2016 05:22 PM
Novak Kinetic racer1812 Radio and Electronics 254 02-04-2013 08:52 PM
Novak Sentry as Brushless Dyno mattnin Electric On-Road 132 01-29-2010 05:53 PM
2009 i-hobby show b-man777 Electric On-Road 7 10-22-2009 09:35 AM
Spintec Battery Manager Erik Jonk Electric On-Road 999 03-26-2009 03:07 AM
Tags
brushless, gtb, novak kinetic, onroad, rc cars
