Old 02-02-2011, 04:54 PM   #1501
Suspended
Originally Posted by Raman View Post
Reduce the pain of application on a PC.. Pain is putting it lightly still wish you had a Mac version, or better yet an IPhone app!
What pain? It works fine.....
Pimp Formally Known as OG
PFKAOG is offline   Reply With Quote
Old 02-02-2011, 05:36 PM   #1502
macdude's Avatar
They are referring to the installation process and firmware update not the actual functioning of the program.
KO Eurus / Orca / MMP / XB2 / 22-4 /
macdude is offline   Reply With Quote
Old 02-02-2011, 06:25 PM   #1503
Suspended
So am I
Old 02-02-2011, 09:10 PM   #1504
macdude's Avatar
So am I
Well I believe the pain exists because at this point you should never have to manually move files around or unistall a program and then reinstall and update. As an example if you happen to have ever used castle's software, it will not only check for device updates (firmware) but will also check for new versions of the program and give you the option to download and install all with little user interaction. It will also allow you to use an older version of the firmware on you device and it does not complain that the firmware is incompatible with the new version of the software. Not saying its perfect, but from an ease of use stand point novaks is a Pain. I believe that in the next version or so they probably will have all the interface and firmware updates ironed out, but for now it's still a pain.
Old 02-03-2011, 09:26 AM   #1505
Suspended
If you have ever used a castle esc and a Kinetic esc back to back you would agree you cant compare the 2 when it come to performance.
Some people just have to come to terms with the fact that they are not very good when it comes to computers and/or they have trouble following directions.
Old 02-03-2011, 09:51 AM   #1506
skypilot's Avatar
Trader Rating: 14 (100%+)
having run Speedpassion for a while (since it came out) I can tell you, every time there is a update or revision you have to uninstall, delete, or drag and drop something. thing is, hardly anyone cries about (anymore) so you wouldn't know.
semi retired..
skypilot is offline   Reply With Quote
Old 02-03-2011, 01:31 PM   #1507
macdude's Avatar
Yes I would agree that some are not very computer literate. However that is not the complaint. I never had a problem getting the software to work either, but the process is less than desirable. And since I have helped people with it I have a pretty good idea of what I am talking about from a usability stand point. Installation is not easy, it is not user friendly and can and will be much smoother in the future. But for now it is not.
As for the controller themselves, the performance is pretty similar. I have done tons of testing with both. I run both pretty regularly, while I will agree that the processing power of the kinetic is more advanced than that of the castle there is a down side to that as the kinetic seems much more sensitive to things like updating with the battery connected. And lets not forget you have to pay a premium for the kinetic and novalink. That aside I think the controller has tons of potential, but for most I don't recommend it. I do however recommend the havok pro SC as that controller offers a lot of the functions for a much lower price point and zero computer knowledge.
Old 02-03-2011, 01:44 PM   #1508
macdude's Avatar
This is pretty much the only controller that I have yet to try. Since horizon just bought Hobbywing (speed passion) I will probably be trying these out too. Have not seen their software yet.
How does it compare in feel to the kinetic?
Old 02-03-2011, 02:10 PM   #1509
skypilot's Avatar
well, I'm runnng a novak now......
semi retired..
Old 02-03-2011, 02:55 PM   #1510
Charlie's Avatar
Been a while since I've posted my email, so here it is again:
[email protected] if you have any issues this forum doesn't address.
And yes, we're working making the installation process much more simple and strait forward.
Novak Electronics Tech Support
Charlie is offline   Reply With Quote
Old 02-04-2011, 08:43 AM   #1511
Company Representative
Charlie's Theme Song
NovakTwo is offline   Reply With Quote
Old 02-04-2011, 10:06 AM   #1512
ed517's Avatar
Originally Posted by NovakTwo View Post
LMAO
ed517 is offline   Reply With Quote
Old 02-04-2011, 10:43 AM   #1513
Larry Brown is offline   Reply With Quote
Old 02-05-2011, 12:18 PM   #1514
Not to be a pain, but I can read the specs listed on your site. I was more interested in the physical differences that prevented reversing the direction of the motor and limiting the current. As both these seem to me be like software things. And to be competitive I would expect the same functions with just a motor limit kind of like some other company that has a pro and non pro version of their controller that will remain nameless.
Kinetic spec will have the motor rotation selection, this feature is completely software function.
Current limiter is mostly hardware function, our current limiter implementation is a true pulse by pulse current limiter so it requires very high speed control loop, meaning it is not easy to do with software and then it would take most of the micro controller bandwidth.
We use the the PCB trace to measure the voltage drop caused by the current flow and to keep the system voltage drop very low the trace length is only 5mm long and that is 8 layers of 2 oz copper, this require a current sense amplifier that has a very low input offset voltage (very expense part).
To complete the circuit one needs a DAC and high speed comparator and then signal is fed into our PWM generator hardware that is in the Kinetic micro.
I am not aware of anyone else in the industry that uses such high speed current limiter to give you super smooth current control.
Adnan Khan
Novak Engineering Dept
escman is offline   Reply With Quote
Old 02-05-2011, 12:24 PM   #1515
We are done with the writing the installer software and are in the process of testing the automatic installation software on different computer and operating systems, and yes it has a function to look for update on installation.
We are also working on simple graphic version to support the small notebooks.
All this takes lots of time and a whole lot of resources!
Adnan Khan
Dyno, Homemade, Using a Novak Sentry Data Logger, Continued, The Experimental Thread. John Stranahan Electric On-Road 344 12-30-2016 05:22 PM
Novak Kinetic racer1812 Radio and Electronics 254 02-04-2013 08:52 PM
Novak Sentry as Brushless Dyno mattnin Electric On-Road 132 01-29-2010 05:53 PM
2009 i-hobby show b-man777 Electric On-Road 7 10-22-2009 09:35 AM
Spintec Battery Manager Erik Jonk Electric On-Road 999 03-26-2009 03:07 AM
Tags
brushless, gtb, novak kinetic, onroad, rc cars
