Old 10-20-2009, 06:10 PM   #1
RR826's Avatar
Send a message via AIM to RR826
Default Rs-540sd sprint brushless motor brushes
i have the rs 540sd motor and i need new brushes ,i was wondering if anyone knew where i could get them.
This is the motor
http://www.geocities.jp/kamiaraya588...rs540sd001.jpg
These are what they look like
http://img.alibaba.com/photo/2074734...hite_block.jpg
and heres another view
http://www.eflightwiki.com/eflightwi...bonBrushes.jpg
RR826/BRSTC3
RR826 is offline   Reply With Quote
Old 10-21-2009, 09:50 AM   #2
gacjr0's Avatar
Trader Rating: 15 (100%+)
Most likely better to just get a new motor; rather than spending the time and money hunting down brushes, opening a sealed can motor and getting it back together.
There are many 540 sport tuned motors cheap on ebay or in stores.
You may even take the opportunity to go up to a stock, 19 turn, or mild modified motor depending on if your ESC can handle it.
-Dangerous with power tools-
gacjr0 is offline   Reply With Quote
Old 10-21-2009, 06:29 PM   #3
RonF's Avatar
the Black motor Sport tuned there is BRUSHED. If there are 2 wires on it, that says it right there. Brushless motors have no brushes, and have /require 3 wires.
Its a sealed endbell, unless your good at putting it back on, change the motor.
RonF is offline   Reply With Quote
Old 10-23-2009, 08:55 PM   #4
RR826's Avatar
it was my dads old motor,i thought it was an old brushless since it didnt show any rushes on the outside,it was taken out and held by 2 screws.so i was gonna try and wind a 12t single and put it in that can but i just found out today the motor mount on the tc3 inst big enough.i have a 16t 3 ruby motor coming in tho so its all good,i put the 13t armature into an lrp v10 spec motor can modified,im buggin out 2 many motors i took apart
RR826/BRSTC3
Tags
brushes, motor brushes, rs54sd
