Old 10-20-2009, 02:08 PM   #1
Exclamation difference between tc5 slipper spool kit and regular spool kit???
ok so i am setting up my tc5 for drifting and i was told to get a spool for the rear. so i go to amain to order it and they have two different types of spools??? one is called Team associates slipper spool kit pn ASC31174 and the other is called team associated spool kit pn ASC31179. which one of these do i need for drifting? and what exactly does it do?
RC10GT2-ALL HOPPED UP!
RC10B4-TEKIN!!
TC5-TEKIN!!
ALL ON DX3S
iraqsucks is offline   Reply With Quote
Old 10-20-2009, 02:15 PM   #2
MikeXray's Avatar
Trader Rating: 73 (100%+)
the slipper spool will have pads inbetween the pulley so that one side can clip under hard impact or load, but should be locked the rest of the time. The ther one is solid and it will either break, or a driveshaft will break with his hard enough. Drifiting offers little load on a spool, so I'd use the slipper.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 10-20-2009, 02:17 PM   #3
Trader Rating: 38 (100%+)
Most likely just the blade will break. I like the slipper spool. The only issue is you really need to use the TC3 diff screw and nut in my experience or it will loosen up over time.
or8ital is offline   Reply With Quote
Old 10-20-2009, 02:26 PM   #4
ok, so get the slipper spool. got ya. and to lock it, what do i do, just tighten it all the way? and could you post a link to the tc3 parts your talkin about plz.
RC10B4-TEKIN!!
TC5-TEKIN!!
ALL ON DX3S
Old 10-20-2009, 02:40 PM   #5
Yep, just tighten it. You build it just like a diff except you use the slipper pads instead of the diff rings and no diff balls.
http://www3.towerhobbies.com/cgi-bin...&I=LX2869&P=FR
Make sure you use blue loctite thread lock on the diff screw. You need just the screw and the large white nut from the package. You can discard everything else.
Old 10-20-2009, 02:57 PM   #6
im already placing an order with amain so i searched that pn on their website and it says its for the gt2? same thing tho?
RC10B4-TEKIN!!
TC5-TEKIN!!
ALL ON DX3S
Old 10-20-2009, 04:00 PM   #7
yes
Old 01-28-2010, 11:51 AM   #8
VonRipper's Avatar
Default slipper spool 5/64 thrust balls
Hey was noticing that the slipper spool kit did not come with the 5/64 thrust balls, is the norm or should I grab them from my old diff????
VonRipper is offline   Reply With Quote
Team Associated TC5 RCknight Electric On-Road 13254 05-12-2017 08:58 AM
