Old 10-20-2009, 06:34 PM   #16
According to this month's machinedesign article, steel bearing microwelds itself onto the race as it rotates causing heat build-up. That also cause increase friction.
http://machinedesign.com/article/ceramic-bearings-save-energy-extend-life-1005
Ceramic also spins much longer.
benmlee is offline   Reply With Quote
Old 10-20-2009, 06:35 PM   #17
Jackster's Avatar
Trader Rating: 19 (100%+)
Uh, what do you think heat dissipation means?
Originally Posted by niznai View Post
Actually it's not heat dissipation but heat buildup. Ceramic balls have lower friction coefficients therefore less friction, therefore less heat buildup. That plus higher hardness means longer life.
Jackster is offline   Reply With Quote
Old 10-20-2009, 06:52 PM   #18
Head dissipation means to remove heat from an object...lower friction of ceramic prevents much of that heat from occurring in the first place.
Old 10-20-2009, 09:22 PM   #19
wiscnitro's Avatar
Trader Rating: 22 (100%+)
I will get to the point of having to replace all my berrings hopefuly not till the end of the season but when I do I would like to get good quality and low maintiance berrings. I know Stock (Economy) berrings can be verry restrictive so you have to pull the shields and de grease them I know (as been talked about) ceramics is the best way to go but what is my 2nd best? there are so many choices I don't know what im getting. the berrings would go into a Associated TC3.
Hold my beer and watch this! :)
wiscnitro is offline   Reply With Quote
Old 10-21-2009, 12:57 AM   #20
niznai's Avatar
There you go Jack.
Thank you, inspector. You guys do know something about heat in Hawaii there sitting on one of the hottest geological features of our planet.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Confused about diff. balls... suparajicon Electric Off-Road 12 07-19-2009 03:42 AM
Letís talk about diff balls DustinR Electric On-Road 21 01-25-2006 07:06 PM
Ceramic Diff Balls!! Si3n4 Grade 5 $1.25/ball rayhuang R/C Items: For Sale/Trade 101 01-23-2006 04:36 PM
ceramic bearings and diff balls Rasmus TbEvo IV Electric On-Road 20 12-13-2005 08:23 AM
Next Best Bearings To Ceramic Bearings????? J Smith Electric On-Road 47 08-21-2003 03:26 PM
