Old 10-20-2009, 02:17 AM   #1
Default some questions about brushed motors
Been out of the hobby for long time and recently back in. I always thought the lower the turn a motor has the quicker it is. Can someone kinda give me the low down on how brushed works... turns,springs,brushes ect... I tried searching for a thread but have come up empty. I know brushless is the way to go but I'm not fully ready to toss everything aside to replace all my cars. thanks in advance
DeputyDad78 is offline   Reply With Quote
Old 10-20-2009, 02:18 AM   #2
louis flood's Avatar
Send a message via AIM to louis flood
whats a brushed motor? lol
powered by venom-group , atomik and evolution sports in Redlands CA paintball airsoft and R/C (909)792-9898
my rides atomik v2mr ae b44.2 tlr 8ight 2.0
louis flood is offline   Reply With Quote
Old 10-20-2009, 08:48 AM   #3
joe of loath's Avatar
Replace all your cars? all you need to do is replace the brushed motor/ESC in a couple with brushless...
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 10-20-2009, 08:52 AM   #4
niznai's Avatar
Everything you knew back then is still true today about brushed motors. The only news is that they are old technology. Not necessarily obsolete, but old.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 10-20-2009, 10:54 AM   #5
I plan on getting either a Slash or SC10 that I will make brushless and more than likely the F1 cars. But I'm not changing the others over. Just don't see alot of lower turn motors but alot of 27t for example so was curious as to if things changed.
You know its bad when your digging through the closet and garage to Ebay ANYTHING to pay for your "Hobby"
Old 10-20-2009, 11:12 AM   #6
Send a message via Skype™ to slotracer577
I think what you see is that anyone running "modified" has gone brushless. I think they have down to 1.5 T brushless. Around here only the entry level people are still running brushed and I think it is a preceived budget issue. If you are racing, brushless and lipo are cheaper after even a few months. Price of entry is higher, but you are not replacing things as often or having to have as many packs.
Team Epic
slotracer577 is online now   Reply With Quote
Old 10-20-2009, 11:15 AM   #7
I just read a big article about brushed/brushless that answered all my questions. Looks like I gotta break the piggy bank
Old 10-20-2009, 11:23 AM   #8
Regional Moderator
CarbonJoe's Avatar
If you are just "bashing", go for it. However, if you plan on racing the Slash, it is best to check with the track you will race at, since most places that race Slashes run a "stock spec" class. This means you have to use the stock ESC and motor.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 10-20-2009, 02:30 PM   #9
RC Dad's Avatar
Trader Rating: 26 (100%+)
Send a message via MSN to RC Dad
Here it is oversimplified.
Motor winds:
Lower winds = more power, more RPM's
Multiple winds (double, triple) generally give a smoother feel but attain fewer RPMs due to increased mass.
Brush springs:
More brush pressure = more torque, less brush pressure (up to a point) = more RPMs
As a default; red positive/green negative is still a good universal recipe on 27T motors. Some brands, like Fantoms seem to prefer more pressure so run purple pos/red neg. For on-road I usually run green pos/blue neg for more RPM's. For off-road always red/green as the softer springs sometimes allow brushes to hang when they get dusty.
Brushes:
There are lots of new compounds in brushes in the past decade, I like the high-silver ones (4499)from Trinity for stocks and Reedy 767 (offroad) and 769 (onroad) for 19T.
Laydown brushed motors have more torque and generate more heat, standup brushes (mod only) usually make higher RPM's.
GV2 Pro, XXX4G+, Blitz SCT, CRC GenXL
RC Dad is offline   Reply With Quote
Old 10-20-2009, 05:40 PM   #10
I highly doubt I will ever race any of them since the nearest track is 2+ hrs away but thats awesome that everyone has to use the stock equipment. Makes me wanna go watch some of those one day.
Ok so in the Bandit I have a Quartz 19t (double) and its fun in the little track my daughters and I built. Having trouble getting the Sledge up to par though. I'm thinking its gearing cause no matter what motor I throw in it's not enough torque. Any suggestion for it?
Old 10-20-2009, 07:56 PM   #11
RR826's Avatar
Send a message via AIM to RR826
Wink
I can definitely argue that lower the turn doesn't mean faster speeds.when i got my tc3 i was looking for lower turns because i was told the lower the better.so i bought a 13t orion sv2 hoping it would outrun my dads rc10l with a 16t motor.in disbelief he went right past me.so i buy a modified 12t LRP v10 spec 4 and change the timing and he still zips past me doing like 50mph.A 16t x3 out running a 13 and a 12t motor.trinity speed gems ruby motor has an rpm of 46k vs my 13t(39k Rpm & 12t 41.1k RPM motor).Its all about the rpms,dont buy becuase of winds buy becuase of rpms...trinity speed gems ruby 16T x3..it has secrets to it.its defiantly a gas car eater.I just got one from ebay myself,hard to find good luck.just switch the armature and magnets onto a brushless motor can for speed. i have a new project call the RSS12 prototype hybrid motor.multiple motor parts from otehr motors into one rs540sd BL can.
RR826/BRSTC3
RR826 is offline   Reply With Quote
Old 10-20-2009, 08:48 PM   #12
Regional Moderator
CarbonJoe's Avatar
If all you are doing is switching out the motor, you may not like the results. You will also have to change the gearing to suit the motor. In general, the lower the winds, the smaller the pinion you should use (if you stay with the same spur). Just dropping the number of turns on the motor with the same gearing will more than likely cause the motor to run very hot, harming the magnets in the can or smoking the motor.
Old 10-21-2009, 10:44 AM   #13
RC Dad's Avatar
Carbon Joe is right, there's more to going fast than slapping in a lower turn motor. Gearing makes a huge difference as does maintenance. I have 19T's that will easily outrun other's 12 or 13T mod motors on the track, but I rebuild them every 4 runs and dyno tweak them. Likewise my son runs a Tekin 13.5 combo that, when boosted/timed correctly, will hang with 8.5's on the same track.
Different speed controls and profiles also count. For instance, if you're running a stock profile on your speedo it will not allow the lower winds to hit their high RPM's because the frequency is too low and it will make the low end so punchy it's almost undrivable. If you run a mod profile on stock motors you'll lose your low-end torque but get better RPM's and lose your drag brake.
Batteries also make a huge difference. If you're running Nimh cells it's still worth the trouble to re-peak them immediately before running.
Old 10-21-2009, 11:27 AM   #14
niznai's Avatar
All that is true, but as some have already noticed it's the track that ultimately decides. Some tracks simply do not allow lower turn motors to come into their best efficiency range unless geared down to a point where you can't take advantage of their rpm, so you're back to square one. Off road even more so since grip comes into play and no matter what rpms you pull, you just can't make it stick so it's useless.
But for the initial poster, be careful with brushless. In the long run they win cost wise, but you have to be careful. If geared incorrectly, they go up in smoke a lot quicker than brushed motors, and then it's another 300$ (a speedie) or about 100$ a motor. A lot of people can tell you their story of woe (if only they would admit it).
Lipo is the same. Be careful with the batteries as they don't have clearly visible markers to tell + from - and reversing the wires in the heat of the race costs a speedie again. I dunnit.
Team Greasy Weasel
Old 10-21-2009, 11:46 AM   #15
paraletic's Avatar
Hence I run deans connectors lol
Losi XXX-S G+..................Tamiya M03.......................TOP Photon
Losi XXX-4 G+.................HoBao ST Pro electric........Losi Micro SCT
Losi XXX-CR....................Losi Mini Baja.....................Losi XX-4 W/E
ASSociated RC12L4
T.O.P PHOTON EX & Tamiya M05 - currently undergoing rigorous crash testing!
paraletic is offline   Reply With Quote
Questions about a drifter element92788 Electric On-Road 8 07-02-2009 04:14 PM
Should Stock Brushed Motors go away in higher level events? Dawn Sanchez Electric On-Road 157 01-01-2009 05:43 PM
Some random questions for on-road R/C xjman Rookie Zone 12 10-06-2007 09:01 AM
Thinking about Going to Brushless: I have questions Elboogie Electric On-Road 37 05-25-2007 11:00 AM
Best brushed motor and ESC knucklebusta Electric Off-Road 6 01-06-2006 12:40 PM
