Best rubber tires for carpet >
Old 02-17-2004, 11:57 PM
  #31
Trader Rating: 31 (100%+)
there goes sydwinder.....hiding out in sportmans again!
Hey you gonna make it out Hobbytown this season sydwinder?
Did you see what they are doing to fix the evo 3 front problem on the thread?Wish I had mine still.That fix is the trick.Pinning the front pinion to the drive shaft.
racenut123 is offline
Old 02-18-2004, 12:05 AM
  #32
Hey racenu123
I'll be at Htown from time to time. When is night racing starting? How about tomorrow night in the rain? heh.
Yes I'm that sportman kinda guy.
Evo3 POS. Stripped a front pinion every qualifier. Ended up 2nd for the main and didn't even get to run because I ran out of those dagnabit pinions. I'll talk to you more about the pinning trick when I see you.
Sorry thread starter for hijaking your thread.
Sydewynder is offline
Old 02-18-2004, 08:08 AM
  #33
STLNLST's Avatar
Default Re: Re: Re: Re: XXX-S Bill
Originally posted by XXX-S Bill
On my XXX-S, the rims are barely touching the RPM rod ends (using short ball ends) on the rear of the car...Can't use the outer position for the ball ends on the rear uprights. Gotta believe the scraps on the inside of the rims happen under cornering conditions.
Thanks.
are you running the titanium (sp) balls in the rear? They raise the ball cups slightly. Other than that I don't have a clue as to what the problem could be. I won't be at the carpet track until March 12 the friday before the big two day race.
STLNLST is offline
Old 02-18-2004, 07:44 PM
  #34
Trader Rating: 16 (100%+)
Default Re: Re: Re: Re: Re: XXX-S Bill
I won't get to Stockton until the big race on March 13-14 either.
Don't have titanium balls on the car. Just got some really small diameter wheels on the Takeoffs. Just looking at the alternatives.
Probably get to Newark or Speedworld for some outdoor when the weather allows.
Thanks.
Still Bill is offline
Old 02-19-2004, 12:13 AM
  #35
This seems fairly obvious, so forgive me if you've already got them on, but have you got the wide TC-3 hubs on ??? they generally solve most (but not all) clearance issues...
sleek the elite is offline
Old 02-19-2004, 07:48 AM
  #36
Good thought. It seems that just about any hub, other than what has come on my last few Takeoffs, will cure the problem. Thanks.
Old 02-19-2004, 11:52 AM
  #37
Cole Trickle's Avatar
Originally posted by Hardriven RC
If you 're not allowed to use tractioncompound, go for Tamiya M2 radials. I know it sounds weird but we've been using them in a winter series for the last three years and nothing came even close. Temperatures were between -4 and +10 degrees celcius. It was a carpet track. I won that series the last three years so i know what i'm talking about. PeterCR knows the series to cause he partissipated to.
If you are allowed to use tractioncompound go for PitShimizu D20 or D25.
Regards
The temperatures you mention, is it track temperature or air temperature?
Thanks.
Cole Trickle is offline
Old 02-19-2004, 11:56 AM
  #38
Hardriven RC's Avatar
That is the temperature inside the hall where the races are held. I would imagine that the carpet temp won't differ that much from the ambiant temp seeing that it is a permanent track.
Regards
Hardriven RC is offline
Old 02-19-2004, 11:58 AM
  #39
Originally posted by zgeist
Harddrivin - so, do you know of anywhere in the US to get those Tamiya tires? Google turned up only overseas vendors.
I wouldn't know where to point you as I live in Belgium Europe.
Sorry
Regards
Old 02-19-2004, 02:56 PM
  #40
What is the web address for Take-Off tires?
JWATT is offline
Old 02-20-2004, 04:11 PM
  #41
Korey Harbke's Avatar
Anyone know what sorex insert is closest to an hpi red or an hpi green? They have 3 thicknesses, but I dont knwo which one will give about the same airgap. Any help would be apreciated.
-Sushi Boy
Korey Harbke is offline
Old 02-20-2004, 04:25 PM
  #42
IH
IH's Avatar
Guys, what inserts do you recommend for CS-27 tires running on carpet?
IH
IH is offline
Old 02-20-2004, 04:27 PM
  #43
Originally posted by PeterCr
Yes Harddriven is right.
I used them too in the same series!
I used Tamiya M2 Radials in the back and Tamiya M2 slicks in the front. Good thing is that they last very long and even get better when they wearing out.
Hi Peter
Very long lasting, can you please give some indication? Like 10, 20, 30, 40 or maybe even 50 batteries?
Old 02-20-2004, 04:30 PM
  #44
Well, i did 4 race weekends wit 1 set, so i guess thats about 40 packs.
Regards
Old 02-20-2004, 04:38 PM
  #45
Sounds good ! And fast response !
