Old 10-18-2009, 02:11 PM   #1
dave05's Avatar
Trader Rating: 30 (100%+)
Default Corally F1 NGX vs Tamiya F104 ??
has any one a opinion on these and which they think is better etc
i no some of the guys at our track say the available foam for the Tamiya F104 is not as good as the foam available for the Corrally F1's
or is there another brand that works well on ashpalt
dave05 is offline   Reply With Quote
Old 10-18-2009, 03:36 PM   #2
Trader Rating: 45 (100%+)
Who says that you have to run Tamiya foam on Tamiya rims. Jaco rubber fits just fine...
Apex is offline   Reply With Quote
Old 10-23-2009, 11:49 AM   #3
liljohn1064's Avatar
Trader Rating: 17 (100%+)
The Corally F1 is a pan car with much wider tires. The F104 uses scale width tires. The Tamiya foam is pretty darn good. The Corally's can use any 1/10 pan car tires.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 10-23-2009, 12:32 PM   #4
ShaunMac's Avatar
The availability of 1/10 pan car tires makes things a lot easier. Glueing up your own tires can be a pain in the butt sometimes.
I'm running an Alpha MK-1 on carpet. The tire choices are endless and the wide rears make for some really nice traction. On asphalt the new Alpha MK-2 would be dialed. It has a lower centered wide pod design that is better suited for today's brushless motors. Plus, each car comes with your choice of compound in BSR tires so whether you're running on carpet or asphalt you'll be getting good tires that work. Not some cheap kit tires you just throw away.
ShaunMac is offline   Reply With Quote
Old 10-23-2009, 12:46 PM   #5
SteveM's Avatar
Trader Rating: 142 (100%+)
A local club racer has the Corally and it did very well last weekend against two new Tamiya F104 cars. Looked great on the track too!
SteveM is offline   Reply With Quote
Old 10-23-2009, 01:58 PM   #6
Of course the Corally would do well just from the fact that it's track front and rear is much wider than the F104.
Old 10-23-2009, 03:00 PM   #7
robk's Avatar
Trader Rating: 22 (100%+)
The straight up pan cars like a Corally or the old HPI Super F1 will have an advantage since they are not making compromises to look like a scale car, and they are designed 100% with racing in mind. Not that Tamiya cars are not good, but the tire situation alone will make the pan cars better.
