Gearing Help
I know nothing about gearing. I have research but still... I'ma little lost.
I have a : TB-03D (locked Rear/Front One Way) -64T Spur -22T Pinion -Novak Ballistic 3S 8.5T Brushless System The directions recommended 10T-15T Pinion. I want a little more toque out of it. My Brushless System runs warm but not hot. I used a Intellect 5000mah NIMH Battery w/Deans connectors. What would you guys recommended? What type and where do I get Tamiya pinion gears as wide as my stock one at? |
Well, I was hoping if you guys can let me know what type pinions above in the links are compatable with my TB-03D. I heard 48P and 64P reqwuired changing the spur. I want to know which pinion I need without chaing the spur.
My motor runs real cool so I feel I can safley get some more torque out of it. Maybe move down to 19T-18T maybe 20T it's only a small drop. Unless chaning the pinion is real sensitive on the motor. |
Going to a smaller pinion will only cool the motor down more so there is no worries there. youll need to buy tamiya pinions. give jeff at speedtechrc a call he'll get you set up with them
