Old 09-15-2010, 08:03 AM   #76
Originally Posted by haywood View Post
Anyone have one for sale?
Haywood,
The cars are back on the CEFX websight. Keep in mind that the kit is a conversion.
You will need an Associated FE
Center Shock (I like the Hotbodies)
Associated pivot ball assembly and side links
I have been running the car all summer. Been running red cars for years. This car is sooooo much more consistant from the start of the run tell the end. Geomentry of the car, as well as the quality and thickness of the of the carbon fiber being used generates crazy corner speed.
It is the best kept secret in 1/12 scale racing. Not for long though...
Jeremy Otis is offline   Reply With Quote
Old 09-15-2010, 08:17 AM   #77
tobamiester's Avatar
Trader Rating: 283 (100%+)
Send a message via AIM to tobamiester Send a message via Yahoo to tobamiester
Still building my Griffin 12. Taking me a while as I've been busy finishing up with outdoors.
I put the HB center shock in last night and wondered if anyone did anything to limit the travel of the shock as the rear seems to sag when off the ground ? Or maybe I screwed something up ?
Here is a picture of the rear http://i884.photobucket.com/albums/a...ket_15862_.jpg
Also, does anyone have a part number for the AE Med ballstud used on the rear shock mount (instead of the supplied one) ?
Thanks again in advance
Can't wait to complete this build and get it on the track..
tobamiester is offline   Reply With Quote
Old 09-15-2010, 08:33 AM   #78
Shock Length is 76mm to 79mm overall lenght cut the long plastic ball cup down. Try that with 40 weight shock oil & blue center spring. This is what Josh and I ran at the IIC race.
Kelly
windix606060 is offline   Reply With Quote
Old 09-16-2010, 08:18 PM   #79
Thanks for the info so far. Is there a reason the Servo Mount/Standoff is not included with the Griffin 12 Conv. kit ?
Was pretty surprised and the 12R5 ones don't work.
Have people been using these ? http://www.cefxspeedshop.net/?mainUR...2_On_Road.html
Thanks in advance.
Old 09-16-2010, 09:13 PM   #80
Josh Cyrul's Avatar
tobamiester - We didn't include them because some people may prefer different ways to mount their servo or use a different size servo and we were trying to keep the kit price to a minimum.
I think the center shock lenght we used at the IIC was around 76.5mm. I'll check my car tomorrow and post exactly where it was.
hussel7 - I ran a KO 951 servo, KO speedo, R5 front end, Hot Bodies center shock w/ AE Blue spring and Losi 40wt oil and AE Gold side springs.
I'll get some pics of my car up asap. Here's my basic set-up that was on my car, Kelly's car and Andy Moore's car.... Same set-up used to TQ and win the ROAR Nats, Snowbirds, Novak Race and now IIC:
AER5 front end:
5 degree blocks
thick castor shims in the front, thin in the rear
1 degree camber
.020 front springs
10k-15k on the kingpins (yellow 15k Kyosho)
3.5mm ride height
1.62-1.58 front tires Parma Magenta
HB center shock:
stock piston
40wt oil
AE blue spring
76-77mm overall lenght
AE gold side springs w/no pre-load
15k in side tubes - Kyosho yellow
1.72-1.68 rear tires Parma Magenta
4.0mm ride height
Protoform AMR-12 body centered or back a little in the wheel wells
Battery forward
Kimbrough Med servo saver
Speed Passion V3.0 3.5 Turn Motor
Speed Passion Super 7 Rotor
23/96 with KO Speed Control
Destiny, Ko Propo, Hobby Wing, Ulti Racing Tires, Protoform, Xenon Racing, Pivothead, Vizon, TQ Wire & Hella Graphics
Josh Cyrul is offline   Reply With Quote
Old 09-16-2010, 09:20 PM   #81
AER5 front end:
5 degree blocks
1 degree camber
.020 front springs
3.5mm ride height
HB center shock:
stock piston
40wt oil
AE blue spring
4.0mm ride height
Battery forward
Josh, Thanks so much for the info.
-toby
Old 09-17-2010, 05:29 PM   #82
Figured I'd post a pic of my Griffin 12 if others need references as other pics people have posted were invaluable for my build.
Old 09-17-2010, 05:40 PM   #83
whynot's Avatar
Trader Rating: 18 (100%+)
Doesn't look like you have much room for adjustment on the shock collar, is that spring really short or is the shock really long. or is it just me lol the car looks really nice great job on the electronics. lets see it with the body now
whynot is offline   Reply With Quote
Old 09-17-2010, 05:48 PM   #84
JayBee's Avatar
Trader Rating: 31 (100%+)
Does the antenna/frt shock mount moves? If so, it seems to me that it should be moved towards the rear pod to give yourself more shock collar adjustment for droop/sag. I know also with the HB shock, we cut about 1/8" off the shaft to shorten it a bit.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 09-17-2010, 05:55 PM   #85
Great feedback guys. I have the antenna/shock mount as far back as it goes (three holes I believe). I did cut the long ball cup down 5mm as Kelly suggested. But the outcome as "whynot" mentions is little adjustment left in the shock collar. Cutting the shaft does feel like a good solution.
Old 09-17-2010, 06:01 PM   #86
whynot's Avatar
Is it possible to just use another shock shaft from another brand? is the a eclip groove on one end and threaded on the other? how would you make this shorter? how much rear pod droop do you have now?
Old 09-17-2010, 06:16 PM   #87
JayBee's Avatar
Just dremel the shock shaft with a cutting wheel.
He might have to go back to the long ballcups though...
Old 09-17-2010, 06:17 PM   #88
You can see the shaft here http://www3.towerhobbies.com/cgi-bin...?&I=LXUNN1&P=Z
Old 09-17-2010, 06:22 PM   #89
whynot's Avatar
oh ok I see am an idiot haha I just built basically the same shock with my copperhead 12 how much does this car weigh when it is race ready? with a receiver pack
Old 09-17-2010, 06:33 PM   #90
1lb 7.5oz without body and transponder. I'm using a booster rather than receiver pack as I'm too lazy to maintain a pack right now. maybe when the season gets going I'll put a LIFE pack in there.
