Old 10-15-2009, 08:41 PM   #1
Default 5000 - 40C or 5400 - 25C?
i need a larger battery for my corally phi. i am currently using the orion 3800 30c pack and it just fits under my top deck. i need to get a larger battery and a lipo tray to go with it, so a guy at my track is offering me these two choices. what he mentioned is that even though the 5400mah pack has a lower C rating, it holds the voltage longer since it has a higher mah rating. is this true?
right now, i run a 10.5 on a fairly large track and within the last lap or so i dump. i already geared down to get about an extra 30 seconds, should i lower my low voltage cut off?
(i am running a tekin RS)
edit:
just remembered orion is coming out with a 5000mah 40c and 5400mah 40 pack...any idea how those are going to be?
Double D Donuts is offline   Reply With Quote
Old 10-15-2009, 08:55 PM   #2
adamge's Avatar
Keep in mind that the Thunder Power 5000 40C is actually about 5390mAh.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 10-15-2009, 09:04 PM   #3
Customworksking's Avatar
Trader Rating: 73 (100%+)
Team Xray | RC America| Hudy |Jaco |AKA
Customworksking is offline   Reply With Quote
Old 10-15-2009, 09:06 PM   #4
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
5000mah 40c!
+1
Give the best while u can !
kschu is offline   Reply With Quote
Old 10-16-2009, 03:42 AM   #5
Either of those packs will good. Some new wisdom coming out is that higher capacity along with lower C rating gives better performance over a race. Go for either in Thunderpower or Fantom for best results.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 10-16-2009, 07:22 AM   #6
M-Technic's Avatar
Trader Rating: 15 (100%+)
That is true. However, of the two packs I would probably go with the 40c for 10.5. You should not be using anywhere close to 5,000mAh during a 6 minute run, honestly.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 10-16-2009, 02:13 PM   #7
both of the batteries i was offered were the thunder power packs
stil cant decide....
Team Losi JRXS Type-R Andrew Gray Electric On-Road 13454 07-11-2017 08:26 PM
Tamiya TRF415 JDM_DOHC_SiR Electric On-Road 21094 03-10-2016 12:02 PM
Team Corally RDX Touring Car Kenshin Electric On-Road 10561 11-21-2015 12:54 AM
Should ROAR limit LiPO Capacity in Stock Classes trailranger Electric On-Road 64 05-03-2013 11:19 PM
1/8 electric bharrill Nebraska/Iowa Racing 333 08-01-2010 08:45 AM
SMC 28C 4000/5000 Hardcase Lipo part 2 Danny/SMC Electric On-Road 1598 02-17-2009 08:20 PM
