Old 10-13-2009, 11:54 PM   #1
Slashmaster51's Avatar
Default HELP!! Calling all Novak Slydr USERS
I have the Novak Slydr 6.5 System. Here's the deal.. I run the car for about 5 minutes then the car dies. I only get a servo response. No throttle. I turn the ESC off & turn it back on & the car comes to life again. I thought it was something thermal.. But the system is only warm not excessively HOT. I'm a newbie at brushless & this is my first system. So go easy on me
Tamiya F350 Ext Cab Crawler
Tamiya TA03F Full Option x2
Tamiya TRF415
Tamiya M05
Slash 4x4
Slashmaster51 is offline   Reply With Quote
Old 10-14-2009, 12:15 AM   #2
louis flood's Avatar
Send a message via AIM to louis flood
are u running lipo or nimh? if ur running nimh u need to turn lipo cutoff off and then check the error code that flashes when it happens and compare the lights to the error code manual and c which 1 it is
powered by venom-group , atomik and evolution sports in Redlands CA paintball airsoft and R/C (909)792-9898
my rides atomik v2mr ae b44.2 tlr 8ight 2.0
louis flood is offline   Reply With Quote
Old 10-14-2009, 01:04 AM   #3
I'm running a 5000nimh 6 cell.
I think its setup for Lipos cause the dude I bought it from used lipos on everything he owned. He kept swearing by them..
Thanks for the reply! Much appreciated.
Tamiya TRF415
Tamiya M05
Slash 4x4
Old 10-14-2009, 01:39 AM   #4
just shut lipo cutoff off and that might do the trick if not tell me what it is and ill try and help u there as well i like novak products and know them quite well
Old 10-14-2009, 12:14 PM   #5
Yeah I'm going to do that tonight when I take her out. I'll let you know how it goes. I swear by Novak & Tekin. Only ESC's i'll use.
Thanks,
Tamiya TRF415
Tamiya M05
Slash 4x4
Old 10-14-2009, 03:12 PM   #6
Thumbs down
I fail to understand why Novak has not fixed this problem for good with not only this speed controller but with the Havoc's as well.
I had this same issue with two Havoc's LAST FEBRUARY!!!!! and STILL they are having the SAME issues.
After using Novak's for over 26 years, I gave up and switched to the LRP's and now maybe to the Tekin.
Bob Oaks
bob o is offline   Reply With Quote
Old 10-15-2009, 01:05 PM   #7
Bob Oaks
What problem is that Bob?
Novaks are awesome! Even if you do get a bad apple every once in awhile. I've only had one Novak Explorer II go out on me. I think its cause I hooked up a 10T to it lol.
Tamiya TRF415
Tamiya M05
Slash 4x4
Old 10-15-2009, 09:36 PM   #8
Alright.. Here's the deal.. I turned off the lipo cutoff but i'm having the same issues. Also, I turned reverse on & it does not work. Only has forward. Now when the car dies there is a red & amber light on.
Any help greatly appreciated!
Tamiya TRF415
Tamiya M05
Slash 4x4
Old 10-16-2009, 07:33 AM   #9
Company Representative
Because I am not part of Novak's technical support group, I would advise to email [email protected] with your question. Before emailing, take a moment to review the instructions originally included with your Novak Item:
Novak Instruction Downloads
Please make your initial email as detailed as possible. Include:
~ warranty claim?
~ speed control (brand/model)
~ motor (brand/wind)
~ rotor (old/new)
~ connectors used
~ servo (brand/model)
~ radio system (receiver/transmitter)
~ vehicle & gearing
~ battery, brand (c rating/capacity)
~ any external modules (BEC/brand, Glitch Buster)
~ other important info: water damage, corrosive chemical sprays, excess heat, etc
The more information you provide in your first email, the more quickly tech support can offer you assistance.
NovakTwo is offline   Reply With Quote
Old 10-16-2009, 11:46 AM   #10
Slashmaster51;
Had the same problem you are having with the controller shutting down after 3-4 min.
This happened on not one, but two Havocs. They were used in a USVTA car with the Novak 21.5 motor. Never got the motor above 130.
Really didn't want to spend even more money on the postage to get these fixed and have the additional down time while waiting for them to be returned so a friend bought them and was going to send them in.
This was back in February of this year and now some 9 months later the same problem is still hapening!!!
Bob
Old 10-17-2009, 01:31 AM   #11
I don't have a slyder but a gtb spectrum esc and 6.5t velociti and had a very similar issue. this worked for me but it may have been a coincidence... I had my drag brake at full and I adjusted it down two levels and no more sudden lost of power.
TheVIP is offline   Reply With Quote
Old 10-17-2009, 11:40 PM   #12
Slashmaster51;
Bob
Thanks Bob,
I kinda figured this would be common with a $300 system
Tamiya TRF415
Tamiya M05
Slash 4x4
Old 10-17-2009, 11:42 PM   #13
I'm reprogramming the Slydr now
I really hope this works.. I paid alot & this is no bueno lol
I wanted to buy the cheaper ez-run ebay system.
Thanks!
Tamiya TRF415
Tamiya M05
Slash 4x4
Old 11-03-2009, 08:38 PM   #14
Trader Rating: 26 (100%+)
Send a message via AIM to kriiiss
I have an 8.5 novak motor and got the novak velociti heatsink and put it on but I put it on too much one way and now I cant rotate the motor to fit smaller pinions
and this heatsink is way too hard to move it or rotate it
is there anything I can use to make it lubricated or oiled up so its easier to rotate?
its too far to the right and when its mounted it hits my chassis
kriiiss is offline   Reply With Quote
Old 11-03-2009, 10:38 PM   #15
anyone?
Need help on what to do to rotate this heatsink I already tried heating it up with the hair dryer and heat gun but that doesnt work
