Old 01-25-2010, 12:35 PM   #16
Originally Posted by dameetz View Post
From room temp when I switch it on (the iron is in the holder), I would say like 10 sec temp rising to 200C. From 200C to max 480C (when you pick the iron from the holder) I would say like 5-7 secs
Thank you, really good rates!
I have noticed that according to the manual the 1.2 and 5.0 mm tips are supplied with the station, not 0.5mm. So it should be suitable for a "hard" soldering works too, right out of the box. Plus all the Quick 202D numerous tips should fit.
vm_spb is offline   Reply With Quote
Old 01-26-2010, 10:42 PM   #17
Stein Tumert's Avatar
Apparently not exclusive to LRP, can get the same one now from Graupner in black....http://shop.graupner.de/webuerp/servlet/AI?ARTN=94411
Stein Tumert
Tamiya TRF, Sanwa M12, SpeedPassion, Much More, LRP
Stein Tumert is offline   Reply With Quote
Old 02-03-2010, 09:41 AM   #18
Trader Rating: 23 (100%+)
how the hell do you read all of that.....lol
tdt1805 is offline   Reply With Quote
Old 02-03-2010, 10:52 AM   #19
Its German, just a language like English also is...
Stein Tumert
Old 04-19-2013, 01:54 AM   #20
rbarciko's Avatar
does anyone know what the black rubber is for that comes in the LRP solder station box?
-== Robert Barcikowski ==-
TFTR TC6 F104v2 RC Parts Search
rbarciko is offline   Reply With Quote
Old 07-11-2013, 08:10 AM   #21
Thanks for the info guys! Old thread but I picked up the QK202D......$90 cheaper than the LRP and it is the exact same machine
cormier33 is offline   Reply With Quote
Old 07-11-2013, 04:18 PM   #22
olhipster1's Avatar
Trader Rating: 98 (100%+)
Send a message via Yahoo to olhipster1
Cool
I do have this LRP soldering station, I bought mine at my LHS which is also an LRP distributor for my region. I ve been using it a little less than a year. I can't compare it to the ohter top brand soldering station as this is my 1st proper R/C orientate solder station. (Before this all my solder were the cheapo ones ). I m not actually a heavy soldering user , so far I have used it to replaced ESC wires from their PCB, motor wires, working on my Miniz MosFET and replacing batt connectors only.
What I really like about it?
1. The temp rises to your set temp very quickly.
2. When you put the solder iron onto the holder, it will automatically reduce the iron temp to pre set temp of 200C, which I think will prolong the life of the tip. When you pick it up the temp rises very quickly.
3. It has a safety feature which will switch off the station if its idle for a predetermined time...( I set mine to 10 mins )
4. The included 2 tips are perfect for my soldering application, I don't know if I need more sizes in the future.
5. The iron can be hold like you are writing with a pen,(unlike my cheapo solder which the distance from the tip to the holder is a bit apart so I have the tendency of hand vibration when soldering) so I can do my solder job precisely....esp for my MiniZ mosfet replacement.
What I dont like?
None so far....
all stated is 100% the build quality is tops.
tips included one fatty and a pinpoint tip.
it heats up in seconds.....the magnetic sensor determines if its being taken off stand and heats it up by the time u make the solder point.
there is also a sub calibration set to allow heat shift as to not waste energy....etc.
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
