sealing a chassis? >
sealing a chassis?
Like Tree5Likes
sealing a chassis?
Old 10-11-2009, 06:03 PM
robsryd's Avatar
Default sealing a chassis?
What does it exactly mean to seal a chassis and how is it done, to what advantage?
robsryd is offline
Old 10-11-2009, 06:07 PM
Blackstring's Avatar
It involves coating the trimmed edges of the carbon with a thin film of 2part epoxy or CA glue. It keeps the carbon plies from splitting when it gets hit.
Blackstring is offline
Old 10-11-2009, 06:09 PM
stiltskin's Avatar
Trader Rating: 103 (100%+)
Sand the edge of the chassis and seal it with CA glue. I hold the chassis upright and put a drop of glue on the edge and let it run down. Follow the drop and put another one on before it runs out until the entire chassis edge is coated. The benefit is that your chassis edge will not cut into the carpet if you roll too much and it will help prevent the chassis from splitting or splintering if you are in a collision. It also makes the car look better.
stiltskin is offline
Old 10-11-2009, 06:11 PM
Trader Rating: 36 (100%+)
Check this out.
http://www.teamcrc.com/crc/modules.p...article&sid=16
EVILGRAFX is offline
Old 10-11-2009, 06:30 PM
Trader Rating: 38 (100%+)
Or do it the easy and better way. File the sharp edges slightly and use blue threadlock on the edges.
or8ital is offline
Old 10-11-2009, 06:36 PM
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
not followin the blue loctite thing. loctite only becomes solid in the absence of air. perhaps i'm missin somethin there.
clear nail polish or dripping CA (carefully) so it runs down the edge and works its way all around. usually 2 coats (sand the 1st). make a real nice piece.
1 thing though
You sand that chassis, hang your ego up on the shop door, and WEAR A MASK!
R
UltegraSTI is offline
Old 10-11-2009, 07:42 PM
robsryd's Avatar
Very cool. Thanks to all. I have just bought a second TC5 and want to do some customizing as well as a few "must do's", like sealing the edges. I also plan to lightly file the inside edges of the bulkheads to show a little silver, and give it a custom look like some of the other kits I have seen. Thanks again!!!
robsryd is offline
Old 10-11-2009, 07:46 PM
1 thing though
R
It gets absorbed into the carbon fiber. Ive done it for a while but the Exotek chassis instructions say to use that method because CA can cause the flexing characteristics of the chassis to change. The loctite has a nice look to it without all the effort to CA.
or8ital is offline
Old 01-07-2019, 02:52 PM
Bumping this thread instead of creating a new one. Times have changed, and how we run our cars have changed since the creation of this thread.
Most modern touring cars have quite a bit of flex tune by means of the chassis. Are you all still sealing your chassis with CA? Are you only sanding? Let me know your thoughts.
TurboDrifter is offline
Old 01-07-2019, 03:39 PM
Trader Rating: 16 (100%+)
I have never sealed a chassis. I don't do it because of the fear that the flex will be affected, I don't do it because I'm lazy! Life is too short to sand and glue carbon graphite parts. And I have never had a carbon graphite part de-laminate.
glennhl is offline
Old 01-07-2019, 05:16 PM
If you never seal the chassis then you have definitely cut your carpet. Outdoor, do what you want but if you race on carpet, sand and seal the chassis. You aren't the only one using the track. Added benefit is it protects the chassis too. Not buying the flex characteristic argument.
dman18t is offline
Old 01-07-2019, 05:54 PM
Trader Rating: 24 (100%+)
I stopped sealing mine, but I sand it round with 150 like the CRC guide shows, and then smooth it out with 600 and call it a day.
fenton06 is offline
Old 01-07-2019, 07:15 PM
Carpet is for your living room, dirt is for farming, and asphalt is for racing. 😀
ScottE1776 and gigaplex like this.
glennhl is offline
Old 01-07-2019, 07:30 PM
Billy Kelly's Avatar
Unfortunately for Midwest and east coast we get this thing called winter. Indoor carpet is becoming the best chance for tracks to stay viable.
Billy Kelly is offline
Old 01-07-2019, 10:41 PM
LzREngineering's Avatar
Try to use a rubberised CA glue if possible, it flexes better and is tougher.
LzREngineering is offline
