Novak Pit Wizard Version?????? >
Old 02-13-2004, 06:01 AM
chappi's Avatar
Trader Rating: 17 (95%+)
Lightbulb Novak Pit Wizard Version??????
Hi, Has anyone got a Novak Pit Wizard?
I just wondering what Version does yours one have? (it tells U when U turn it on)
Also, Did anyone usea Novak TC2 on a Tamiya TA02 for On-road Turing race? if so and What is your setting value on your TC2??
Thanks Mate
chappi is offline
Old 02-13-2004, 09:02 AM
Trader Rating: 82 (100%+)
mine reads "v 1.15" but i got it used so it may be one of the early versions.
re. my settings, i usually just set the drive frequency depending on the ff:
slippery track = high frequency (7.80khz and up)
high grip track = low frequency (5.86khz and below)
modified motor (usually 9, 10, or 11 turns) = high frequency
stock motor (ROAR, 23 turn, 540 mabuchi) = low frequency
i havent experimented with the other parameters yet. hope this helps
marvi is offline
Old 02-13-2004, 10:44 PM
chappi's Avatar
Thanks Marvi
My pit wizard is runing @ ver. 1.10 , when do u get yours one?
Also, my TA02 is running a Tamiya Sport Tune Motor, so is it a Stock or Modify motor??
chappi is offline
Old 02-14-2004, 04:03 AM
Hardriven RC's Avatar
The Tamiya Sport Tuned motor is rated as a stock motor. It is however a 23t. Set your drive freq low at 2000Mhz or close to that.
Hardriven RC is offline
Old 03-02-2004, 11:12 PM
chappi's Avatar
I have more details of my TA02:
1. weight = 1560g (with everything)
2. running on Tamiya Sport Tuned motor
3. battery = 1700
4. 66T spur gear + 25T Pinion -> 6.44:1
The car has almost any hop-ups that is avaiable except 1-way diff.
Can anyone give me some i deal of what sort of parameters I should use on my TC2 esc ?
Drive Freq?
Min Drive?
Break Freq?
Drag Break Toggle?
drag Break Freq/ Value?
Also, one more question
If i want to setup the car as a very easy to Driff car, what sort od parameters i should use?
Hope someone out there could answer me
chappi is offline
