Old 01-13-2010, 05:17 AM   #1351
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Anyone know if the L1/L2 camber link position will make the car rotate better through a corner than the Standard ones from the 009? I curently have the 009 ones instanled and the car is pretty good, just needs that bit quicker rotation into and through the corner. I changed to the 009 one's with a lot of other setup changes and the car went good, now i just need to slightly improve the car.
Thanks in advance,
Antoni
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 01-13-2010, 05:58 AM   #1352
Trader Rating: 38 (100%+)
Originally Posted by Benzaah View Post
Interesting. Let us know how that goes can you please. What surface are you running on and whats traction like? i was told the Ltc was the body to have for this car. I like the speed6 so i will have to punch some more holes in one i have to see how that works.
I will let you know. Our track is a 90X45 CRC-HD Ozite carpet track. The carpet it on bare concrete so the traction depends on the temp outside. Lately it has been medium traction since its been so cold. It's really only tail happy on the technical parts of the track (like the back to back 180 degree turns). When the traction is like it is now the Mazda 6 is just a tad pushy for me and the LTC-R is a tad loose. I'm hoping the Speed6 frees the car up a bit and splits the middle. We will see tonight.
I really liked the LTC-R on my TC5 but it just seems too aggressive for me on the Xray. I could turn slightly faster lap times with it vs the Mazda6 but more often then not they were slower b/c it was harder to drive so my overall times we worse.
or8ital is offline   Reply With Quote
Old 01-13-2010, 06:03 AM   #1353
lowcel's Avatar
Trader Rating: 80 (100%+)
I can't wait until I get enough experience that I can tell a difference in the way by car handles with different bodies. I've obviously got a long way to go.
Team Whopperjawed Racing
This hobby is going to $5 me to death.
lowcel is offline   Reply With Quote
Old 01-13-2010, 06:48 AM   #1354
It took me several years to get to this point. Also your car has to be pretty close in setup for you to notice a difference. If you car is setup to push it will likely push no matter what body you have on there. Once you are driving mostly consistently it becomes obvious when something changes on your car.
You heading to Cincinnati this weekend with the OVRCCC crew?
Old 01-13-2010, 07:15 AM   #1355
Hey Tim,
We had the same issue. We did 3 things to fix it you can try them in any order to see what works for you.. More rear camber. A little more droop, and if that doesn't work lengthen the chassis. So if you have your rear arms in the middle move the shims forward. Not sure how many holes open you are running for pistons. We have three, don't use the clickers either, run pistons clickers are too unreliable for maintaining the number of holes you want open.
See ya this weekend.
visit Hurricane Motorsports: www.teamhurricane.net | RCAmerica www.RCAmerica.com | HUDY | JACO
bigdog xxx-s is offline   Reply With Quote
Old 01-13-2010, 07:24 AM   #1356
Yeah I got rid of the clickers after my first shock rebuild when 3 of them had shifted to the wrong setting and one of those 3 lost one of it's clicks. Went to the static 3 hole. My car is actually handling pretty well. I could have setup around the LTC-R handling but I wanted to run the same body as Jim. We are trying to keep as much stuff as possible the same so we can share setup info better. See you Friday (Jim and I won't be there until the evening session).
Old 01-13-2010, 07:45 AM   #1357
lowcel's Avatar
Nope, I'm skipping it. I'm still in recovery mode from Christmas.
Old 01-13-2010, 08:40 AM   #1358
There is still time to change your mind
Old 01-13-2010, 09:40 AM   #1359
What starting setup would you recomend for the birds ?
____________________
www.RCActionPics.com
Rojna is offline   Reply With Quote
Old 01-13-2010, 10:50 PM   #1360
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
http://forum.teamxray.com/xform/inde...=1200&setup=t3
Ok here is my set up currently. Trying to cure a bit of tail happyness off power. Thoughts anyone?
Looks to me like your biggest problem with the rear being a little loose is the 2 degrees of rear toe. Like he said above, go to the longest wheelbase in the rear and put the 1.5 shim back in with 0 deg blocks or at least put the .75 black shim on the back with your current 1deg blocks and see if that helps. You will probably be able to go back to the 2.6 rear spring with the added toe. And softer shock oil in the rear will allow the weight to transfer to the rear faster- which from what you described is your problem- weight transfer to the rear in quick transitions.
BigDogRacing is offline   Reply With Quote
Old 01-14-2010, 06:45 AM   #1361
Skiddins's Avatar
Have you tried the kit setup?
Looking at the shims (or lack of) under the rear camber link, you will have alot of possitive camber as the car rolls, as you apply the power the weight will move to the back and load up the tyre which is running on the tyre shoulder.
Try 3.5 or 4mm under the link instead.
Don't try and copy a 009 setup, the rear links are now higher than the 009 by 2 or 3mm (in fact they are now the same as the front, on the 009 the rears were lower).
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 01-14-2010, 07:13 AM   #1362
Phoenix82's Avatar
Default XRAY t3
Originally Posted by pcar951 View Post
What??? The T3 carries more speed in the corners (out of the box) than any other TC I've driven including T2,007,008,009.
Hey Jim. I agree. I ran my T3 for the first time this week and all i can say is WOW. It was very good out of the box for set up. It has better corner speed and better weight transfer. I cant wait to see it in action this weekend vs the big dogs.
Nick
Phoenix82 is offline   Reply With Quote
Old 01-14-2010, 07:41 AM   #1363
nitrobeast's Avatar
Trader Rating: 41 (100%+)
In no order
Add shims under the rear link
Add camber
Add toe
Lower the shock. You might be able to go back to the stock spring.
On asphalt i would try L1/L2
Can you run a softer tire? 36 are really hard
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 01-14-2010, 07:54 AM   #1364
nitrobeast's Avatar
Thanks in advance,
Antoni
No, the L1/L2 make the link a little longer.
Rui Goncalves
Old 01-14-2010, 10:10 AM   #1365
RLMW VQ's Avatar
l1 l2 will give you more conner speed as you will be able to get back on the gas sooner. also will be easyer to drive. use the l1 l2 up front and the 009 on the back.
Hotbodies-HPI Racing- Hara Products-Team Fantom Driver-True RC-Rc Hobby and Track
RLMW VQ is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
