Old 12-23-2009, 12:53 PM   #1246
adamge's Avatar
orbital, the last step has to be bleeping the air and oil from the bottom cap. That's the only way I'm aware of to build these shocks with no bubbles.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 12-23-2009, 04:14 PM   #1247
Cribbin's Avatar
when you take the bottom cap off instead of pumping the shaft try pushing it in about half way and holding it there. i find that when you pump the shaft it only allows air to get into the shock. then put the cap back on while holding the shaft in the same spot. works perfect every time for me, ive never had any trouble building them
Bro-Kin Racing Group
X-Ray T3
X-Ray T2 '007
Castle Hill Raceway
Futaba LRP Tekin
Cribbin is offline   Reply With Quote
Old 12-23-2009, 04:55 PM   #1248
i do something similar i rock it in the middle of the motion
if i go full length air come in and if i go all the way in air comes in so i kinda rock it in the middle ultra slowly
and after a small while lock it back up and generally get about 50% reound thats without drilling a hole in the cap. if i wanted more i think i would have to do that because getting any lower is just not possible for me yet i guess there is a knack to it and just takes practice
Burney is offline   Reply With Quote
Old 12-23-2009, 10:47 PM   #1249
pcar951's Avatar
Trader Rating: 19 (100%+)
Anyone else noticed that the shock T3 bladders are different material than previous xray shocks? Used to be like silicone, now they seem like rubber or something. Wonder why?
pcar951 is offline   Reply With Quote
Old 12-24-2009, 12:01 AM   #1250
JamesReilly's Avatar
Trader Rating: 58 (100%+)
The new bladders don't swell as much if at all.
Reilly Paint ([email protected])
JamesReilly is offline   Reply With Quote
Old 12-24-2009, 06:49 AM   #1251
Trader Rating: 38 (100%+)
Thanks for the tips everyone. I will give them a shot soon. That said, I did take my car out for about 20 practice laps yesterday. I am a believer in Xray now. I bested my fastest lap (which was the track record until a couple days ago) about 10 laps in and matched it several times after that will ease. The fit and finish of an Xray might be a little overstated but the on-track performance I am extremely pleased with! Very easy to drive.
or8ital is offline   Reply With Quote
Old 12-24-2009, 08:20 AM   #1252
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
What I did to build the shocks was use the shock pump multiple times. I found that if I only removed the air one time that it wasn't sufficient. I now use the air remover tool until I see no more bubbles surfacing while I pump.
IIGQ4U is offline   Reply With Quote
Old 12-24-2009, 09:02 AM   #1253
niznai's Avatar
Originally Posted by or8ital View Post
I'm building up my T3. I've never built Xray shocks before. I tried to follow the instructions to a T but my shocks seem squishy like they have air in them. I got all the bubbles out with a shock air remover pump. Any tips?
Also I found that it seems to take a lot more in and outs of the shock to bleed them at the bottom for rebound than the instructions say. What am I doing wrong?
I think the quickest way to learn is to ask someone who really knows what they're doing to show you. It's pretty easy once you get the idea, but it can be difficult trying to read and do stuff at the same time.
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 12-24-2009, 10:03 AM   #1254
gashuffer's Avatar
Trader Rating: 48 (100%+)
They are emulsion shocks. Air is part of the equation.
gashuffer is offline   Reply With Quote
Old 12-24-2009, 02:59 PM   #1255
Sounds great! Someone post a video for me!
Old 12-24-2009, 03:06 PM   #1256
trerc's Avatar
Trader Rating: 89 (100%+)
They're a bladder shock, there shouldn't be any air in the shock.
Emulsion shocks do not contain bladders, such as old Yok, Associated shocks.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 12-25-2009, 05:48 PM   #1257
Skiddins's Avatar
I have always found this.
I pull the shock rod down so the piston is at the bottom, then use the shock pump.
Now push the piston so it's near the top (but make sure it's still below the surface of the oil) and use the pump again.
I repeat the above a few times until I'm getting no air at all out.
Now it should be sorted
Skiddins
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 12-25-2009, 06:03 PM   #1258
gashuffer's Avatar
I stand corrected.
Old 12-25-2009, 11:41 PM   #1259
Benzaah's Avatar
Trader Rating: 21 (96%+)
Ive only ever bought second hand Xrays and have never built one new. I've got a Question about bearing's and a new kit. It says in the manual to oil all the bearings before install. Are people taking out the blue seals and oiling them that way or just giving them a light smear and in they go? Also, does anyone rebuild the diff from factory? Or just install that and away you go?
Adelaide RC - XRAY Xb216de & Xb416
Walter Rc Hobby - Serpent 4X
Nosram - R1wurks - Sanwa - Hudy - Muchmore
Benzaah is offline   Reply With Quote
Old 12-26-2009, 12:43 AM   #1260
Cribbin's Avatar
with the bearings just drop a bit of oil on the blue seal and let them sit for a little bit, the oil will seep through.
and yes, i would rebuild the diff. i dont think many people do, but i like to make sure everything is right, and you can build it much better than what it comes like anyway
cheers
ben
X-Ray T3
X-Ray T2 '007
Castle Hill Raceway
Futaba LRP Tekin
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
