Old 12-19-2009, 03:53 PM   #1201
Trader Rating: 36 (100%+)
For getting screws out, I use a left hand threaded drill bit, usually 1/16". Usually the bit will catch and spin the screw right out. If it doesn't spin it out, after you've drilled into the screw, use an easy-out.
Works great.
EVILGRAFX is offline   Reply With Quote
Old 12-19-2009, 03:54 PM   #1202
veecee's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Sith Lord View Post
However with the Front Mounts (Pic 2) shows Toe In and (Pic 3) shows Toe Out. That can't be right???
That doesn't surprise me. Maybe this pic explains it... Shouldn't these holes line up?
SMOKEM --- XPRESS --- MONTECH --- SRT
veecee is offline   Reply With Quote
Old 12-19-2009, 04:40 PM   #1203
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Yeah, my "locating holes" are different distances from the edge of diff cut out. One is 5.21mm. The other is 5.49mm.
I won't know till I get this holder out (undamaged hopefully), but I wonder if I'll be able to tighten them with the arms installed, so they stay staight???? If not, will the one piece holder solve my issues? I doubt xray will give me a new chassis.
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 12-19-2009, 04:42 PM   #1204
Joey4875's Avatar
Come on people the reason they don't line up is because the car has toe in built in it.
Xray,Hudy,RC America
Joey4875 is offline   Reply With Quote
Old 12-19-2009, 04:44 PM   #1205
rcterp's Avatar
Trader Rating: 35 (100%+)
Not in the front. Only in the rear.
Φ
Glitter Lidz - "My driving doesn't shine but my lid does!!"
rcterp is offline   Reply With Quote
Old 12-19-2009, 04:50 PM   #1206
Sith Lord's Avatar
And if so, they would be the same distance...... not different.
Old 12-19-2009, 05:10 PM   #1207
Joey4875's Avatar
Yes the front should line up but the rear has toe in built in the car
Old 12-19-2009, 06:26 PM   #1208
Brennan Elwell's Avatar
Off topic but this has been bothering me. What does the EU and US stand for as far as the Rubber and Foam specs go? (Europe and United States?? that can't be so...) I know rubber spec uses and thinner chassis is this so it can flex because of non carpet tracks being rougher, or is it because you need flex to make up for less traction with rubber tires? If it is to obsorb bumps would it be wise to use a thicker chassis if your running rubber on carpet? Thanks for helping me understand this.
Thunder Tiger ST-1
Carpet Noob (investing soon)
Brennan Elwell is offline   Reply With Quote
Old 12-19-2009, 06:38 PM   #1209
trerc's Avatar
Trader Rating: 89 (100%+)
You got it, US is USA and EU is European. Foam is US spec, Rubber is EU spec. The EU edition allows for more flex with the thinner chassis and thinner top plate to compensate for less traction on rubber tires. The US is quite rigid being traction on foams isn't usually a problem, but too much definitely is. I would suggest using Rubber for rubber spec and foam spec for foam tires.
If it smells burnt up.. it's more than likely hot.. you don't have to touch it..
trerc is offline   Reply With Quote
Old 12-19-2009, 06:39 PM   #1210
rcterp's Avatar
Yes, Europe and United States. More flex is for more traction for rubber tire races, which was more popular in Europe (hence the EU). The flex isn't really for bumps, that's all suspension. Stiffer for carpet with foam tires, more popular in the US.
Φ
Old 12-19-2009, 06:49 PM   #1211
Johnny Wishbone's Avatar
Even if the holes don't line up, but you don't have any arm bind issues and equal toe in on each side, you're really only playing with shims to adjust width and toe. It would be interesting to see if other chassiss are drilled the same, could be to help torque off the line?
Old 12-19-2009, 06:58 PM   #1212
losithrasher's Avatar
i think in a few years there wont be a us version anymore, not in kit form anyway. The problem with the eu edition is, on high bite carpet and high bite asphalt, it makes to much traction, now on low bite, the rubber car is silly. In future high bite situations with the rubber car, im actually going to be using a foam top deck so i can use the standoffs to take more traction out.
ONE THINGS FOR SURE ABOUT THE STINGER, NOTHINGS FOR SURE!
losithrasher is offline   Reply With Quote
Old 12-19-2009, 07:02 PM   #1213
Thanks guys its just confusing that they would label them eu and us when both versions are available here in the US. Anyone who buys an x-ray for asphalt is going to get the eu version, right?(or is foam used outdoors also?) Tons of people race rubber in the US and it seems that rubber is the popular choice for tc carpet racing also. Am i right or just confused here?
Thunder Tiger ST-1
Old 12-19-2009, 08:30 PM   #1214
rcterp's Avatar
You're pretty much on. You buy the EU if you're going to run rubber tires (asphalt or carpet).
Φ
Old 12-19-2009, 08:41 PM   #1215
RCFREAK's Avatar
Trader Rating: 17 (100%+)
not only is the chassis thicker for US it comes with 2 diffs. The EU comes with front spool rear diff.... rubber tire racing is about the spool perhaps some instances of a one-way...
Arv.
EA MOTORSPORTS// KO PROPO// ORCA// 180 RACEWAY
RCFREAK is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
