Old 12-18-2009, 09:52 PM   #1186
niznai's Avatar
Originally Posted by Cpt.America View Post
This is close to one of the more retarded things iv ever seen typed here on rctech. Heck, I would bet we are somewhere around 20 009s at my local club alone over the last year. I would venture to guess that xray has sold thousands of 09s.
Could it be that a lot of Xrays have been private imports rather than sold through the authorised importer?
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 12-18-2009, 10:56 PM   #1187
Trader Rating: 3 (80%+)
Originally Posted by dodgeguy View Post
Yeah, if you remove the snap ring it is always a good idea to use a new one. If they bend at all you will have a high and low spot for the thrust bearing to ride on.
Because I have yet to take the diff apart , is it possible to take apart the diff without removing the circlip? Or is it an absolute must too remove that circlip everytime?
traitor is offline   Reply With Quote
Old 12-19-2009, 01:00 AM   #1188
Originally Posted by EVILGRAFX View Post
Has anyone (thought bought an original T3) received their front suspension mount yet?
Ralph told me a couple weeks a couple weeks ago and I've seen them for sale on web sites already.
Anyone?
we all have ours in Europe !!
mine was added to my kit at my LHS
i didn't even fit the 2 piece mountings
sidecarphil1 is offline   Reply With Quote
Old 12-19-2009, 02:31 AM   #1189
Just finished building mine and all went together great.
Only thing I found was both rear arms tight after tightening up mounts.
Found I needed to file 0.2mm off the 2mm shims, was spot on after that.
The previous suggestion about loosening the crews underneath helped the front, but not the back.
Looking forward to running first time tomorrow.
He who dies with the most toys wins, if it's a tie, then it's he with the best.
sjh28 is offline   Reply With Quote
Old 12-19-2009, 02:35 AM   #1190
niznai's Avatar
I would have filed the arm, not the shims as these are likely to be used in the future with new arms which may be molded better and therefore be too loose.
Team Greasy Weasel
Old 12-19-2009, 03:30 AM   #1191
Sith Lord's Avatar
Trader Rating: 21 (100%+)
Default Arm Mount Problems
Thought I'd start to build the T3 before I got the 1 piece suspension mount. I fugure there wouldn't be as much of an issue with the thicker US chassis, so I'll put the 2 pieces on for now.
Now (Pic 1) for the Rear Suspension, I understand there is built in Toe In - hence the angled 1 piece mount.
However with the Front Mounts (Pic 2) shows Toe In and (Pic 3) shows Toe Out. That can't be right???
The next problem, after seeing the To In/Out issue, I decided to take off the mounts, but seeing as I tightened them up pretty well (like the video with the vice/hammer) I stripped the hex screw. Now I have to buy a screw extractor kit or something. I tried the slotting with a dremel, but I don't want to slice up the chassis.
Any thoughts on the Toe issue and how to get my stripped screw out?
Thanks.
Tamiya XV-01 Rally :: Tamiya FAV 2011 :: Proline Pro2 SCB
Sith Lord is offline   Reply With Quote
Old 12-19-2009, 04:54 AM   #1192
Trader Rating: 38 (100%+)
Thanks Kevin, is it the same snap ring the RDX used? I think I have some of those around still.
or8ital is offline   Reply With Quote
Old 12-19-2009, 05:12 AM   #1193
the clip holds the thrust race in place so if you want to do just teh plates you wont need to take it out, i would advice doing the thrust race aswell tho its just as important
Burney is offline   Reply With Quote
Old 12-19-2009, 05:35 AM   #1194
Trader Rating: 36 (100%+)
Thanks.
I don't think that's toe in the front, I think the smaller mounts are just twisted. In one of the instructions I read, it definitely said to make sure to keep that mounts straight when tightening.
EVILGRAFX is offline   Reply With Quote
Old 12-19-2009, 07:44 AM   #1195
mjc168's Avatar
Trader Rating: 25 (100%+)
Anyone?
I get mine today...first run my T3...awesome car ...
http://www.pprcc.com/
1/10 On-road Touring: Schumacher MI3 + Tekin RS Pro + Orca RX-1 11.5t BL Motor
1/10 On-road Touring: Xray T3 2011 + Tekin RS Pro + Tekin Redline 10.5t BL Motor
mjc168 is offline   Reply With Quote
Old 12-19-2009, 08:30 AM   #1196
Joey4875's Avatar
Thanks.
That will cause the arm to bid up, you might have to loosen up the screw and adjust it with the arm on. Once you get the arm free from binding it should be straight
Xray,Hudy,RC America
Joey4875 is offline   Reply With Quote
Old 12-19-2009, 09:25 AM   #1197
IIGQ4U's Avatar
Trader Rating: 53 (100%+)
Thanks.
Drill it out.
IIGQ4U is offline   Reply With Quote
Old 12-19-2009, 10:51 AM   #1198
ChristopherKee's Avatar
Trader Rating: 28 (100%+)
Loosen screws, install arms, tighten screws. Like Joey says, you crank those down without the arms installed and you'll cause binding. Same goes for rear.
ChristopherKee is offline   Reply With Quote
Old 12-19-2009, 02:35 PM   #1199
Sith Lord's Avatar
Originally Posted by IIGQ4U View Post
Drill it out.
Down to the hardware store today to see if there's a small enough screw extractor kit, if not - Drill it out and hope I don't damage the holder.
If I can get that out, then I'll tackle the angle of the suspension mounts.
Old 12-19-2009, 03:11 PM   #1200
You can drill the head off the bolt, use a small drill bit to remove the remains of the hex in the screw. Then use a drill bit where the tip of the drill has the same taper as the countersunk. Then you are left with a little bit of screw left to get some pliers onto.
Xray XB4 | Kyosho RB6 | Kyosho Rudebits DB2
Chris-s is offline   Reply With Quote
Xray T2'008 Drew_Cat Electric On-Road 1941 01-25-2016 12:36 PM
Xray T2'007 Joep Electric On-Road 4185 07-07-2014 09:22 AM
XRay T3 (spy pics) syndr0me Electric On-Road 33 07-13-2010 04:43 PM
where to get xray?? 2qwik Northwest Racers 20 10-10-2009 03:02 AM
New Xray T3!!! Jammin'Trey Electric On-Road 39 10-09-2009 12:40 PM
